Ostatnio dość często mój laptop (MSI vr-630) się zawieszał. Popatrzyłem w logi i było tam coś takiego:
Jun 2 18:27:18 marcin-MSI kernel: [ 1367.793722] atkbd serio0: Unknown key pressed (translated set 2, code 0xf1 on isa0060/serio0).
Jun 2 18:27:18 marcin-MSI kernel: [ 1367.793731] atkbd serio0: Use 'setkeycodes e071 <keycode>' to make it known.
Jun 2 18:27:18 marcin-MSI kernel: [ 1367.799943] atkbd serio0: Unknown key released (translated set 2, code 0xf1 on isa0060/serio0).
Jun 2 18:27:18 marcin-MSI kernel: [ 1367.799950] atkbd serio0: Use 'setkeycodes e071 <keycode>' to make it known.
lspciKod: Zaznacz cały
00:00.0 RAM memory: nVidia Corporation MCP78S [GeForce 8200] Memory Controller (rev a2)
00:01.0 ISA bridge: nVidia Corporation Device 075e (rev a2)
00:01.1 SMBus: nVidia Corporation MCP78S [GeForce 8200] SMBus (rev a1)
00:01.2 RAM memory: nVidia Corporation MCP78S [GeForce 8200] Memory Controller (rev a1)
00:01.3 Co-processor: nVidia Corporation MCP78S [GeForce 8200] Co-Processor (rev a2)
00:01.4 RAM memory: nVidia Corporation MCP78S [GeForce 8200] Memory Controller (rev a1)
00:02.0 USB Controller: nVidia Corporation MCP78S [GeForce 8200] OHCI USB 1.1 Controller (rev a1)
00:02.1 USB Controller: nVidia Corporation MCP78S [GeForce 8200] EHCI USB 2.0 Controller (rev a1)
00:04.0 USB Controller: nVidia Corporation MCP78S [GeForce 8200] OHCI USB 1.1 Controller (rev a1)
00:04.1 USB Controller: nVidia Corporation MCP78S [GeForce 8200] EHCI USB 2.0 Controller (rev a1)
00:07.0 Audio device: nVidia Corporation MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio (rev a1)
00:08.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Bridge (rev a1)
00:09.0 SATA controller: nVidia Corporation Device 0ad5 (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Express Bridge (rev a1)
00:12.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Express Bridge (rev a1)
00:13.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Bridge (rev a1)
00:14.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Bridge (rev a1)
00:15.0 PCI bridge: nVidia Corporation MCP78S [GeForce 8200] PCI Bridge (rev a1)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor HyperTransport Configuration (rev 40)
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Link Control
02:00.0 VGA compatible controller: nVidia Corporation C77 [GeForce 9100M G] (rev a2)
06:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
07:00.0 FireWire (IEEE 1394): JMicron Technology Corp. IEEE 1394 Host Controller
07:00.1 System peripheral: JMicron Technology Corp. SD/MMC Host Controller
07:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller
07:00.3 System peripheral: JMicron Technology Corp. MS Host Controller
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
Czy ktoś może spotkał się z takim czymś, lub wie jak rozwiązać ten problem? Szukałem z pomocą Google, ale nic konkretnego nie znalazłem?
