[+] KDM nie w
Pablik
[+] KDM nie włącza się
Post autor: Pablik »
Nie wiem jak włączyć KDM (Menadżer logowani). Aktualnie loguje się przez terminal i uruchamiam środowisko graficzne poleceniem:
startx
Zauważyłem, że w /etc/init.d/kdm jest skrypt uruchamiający KDM (chyba), oto on:
#!/bin/sh -e
# upstart-job
# Symlink target for initscripts that have been converted to Upstart.
set -e
INITSCRIPT="$(basename "$0")"
JOB="${INITSCRIPT%.sh}"
if [ "$JOB" = "upstart-job" ]; then
    if [ -z "$1" ]; then
        echo "Usage: upstart-job JOB COMMAND" 1>&2
    exit 1
    fi
    JOB="$1"
    INITSCRIPT="$1"
    shift
else
        echo "Usage: $0 COMMAND" 1>&2
    exit 1
    fi
fi
COMMAND="$1"
shift
if [ -z "$DPKG_MAINTSCRIPT_PACKAGE" ]; then
    ECHO=echo
else
    ECHO=:
fi
$ECHO "Rather than invoking init scripts through /etc/init.d, use the service(8)"
$ECHO "utility, e.g. service $INITSCRIPT $COMMAND"
case $COMMAND in
status)
    $ECHO
    $ECHO "Since the script you are attempting to invoke has been converted to an"
    $ECHO "Upstart job, you may also use the $COMMAND(8) utility, e.g. $COMMAND $JOB"
    $COMMAND "$JOB"
start|stop|restart)
    $ECHO
    PID=$(status "$JOB" 2>/dev/null | awk '/[0-9]$/ { print $NF }')
    if [ -z "$PID" ] && [ "$COMMAND" = "stop" ]; then
        exit 0
    elif [ -n "$PID" ] && [ "$COMMAND" = "start" ]; then
        exit 0
    elif [ -z "$PID" ] && [ "$COMMAND" = "restart" ]; then
        start "$JOB"
        exit 0
    fi
    $COMMAND "$JOB"
reload|force-reload)
    $ECHO
    reload "$JOB"
    $ECHO
    $ECHO "The script you are attempting to invoke has been converted to an Upstart" 1>&2
    $ECHO "job, but $COMMAND is not supported for Upstart jobs." 1>&2
    exit 1
esac
Gdy go dodam do autostartu poprzez:
update-rc.d kdm defaults
to podczas startu systemu wyświetla się taki komunikat:
utility, e.g. service kdm start
Upstart job, you may also use the start(8) utility, e.g. start kdm
start: Rejected send message, 1 matched rules; type="method_call", sender=":1.39" (uid=1001 pid=8101 comm="start) interface="com.ubuntu.Upstart0_6.Job" member="Start" error name="(unset)" requested_reply=0 destination="com.ubuntu.Upstart" (uid=0 pid=1 comm="/sbin/init"))
Wie ktoś o co chodzi i jak można włączyć ten menadżer logowania?
Przeinstaluj kdm.
Pablik
Usuwałem i instalowałem na nowo i nic to nie dało:
aptitude remove kdm
aptitude install kdm
Van
Post autor: Van »
http://dug.net.pl/tekst/150/czyszczenie ... gnu_linux/
Część "Usuwanie starych plików konfiguracyjnych".
Pablik
aptitude purge kdm
Nic nie pomogło to samo.
Jakoś ogarnąłem ten problem:
Nie wiem czemu ale brakowało mi tej paczki "kdm-gdmcompat"
Następnie znalazłem działający skrypt rozruchu kdm, umieściłem go do /etc/init.d/kdm i dodałem prawa wykonania:
chmod +x kdm
#!/bin/sh
### BEGIN INIT INFO
# Provides:          x-display-manager kdm
# Required-Start:    $local_fs $remote_fs hal
# Required-Stop:    $local_fs $remote_fs hal
# Should-Start:      console-screen
# Should-Stop:      console-screen
# Default-Start:    2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: X display manager for KDE
# Description:      KDM manages a collection of X servers, which may be on the local host or remote machines.
### END INIT INFO
# /etc/init.d/kdm: start or stop the X display manager
# Script originally stolen from the xdm package
# description: K Display Manager
set -e
# Import the LSB init functions
. /lib/lsb/init-functions
# To start kdm even if it is not the default display manager, change
# HEED_DEFAULT_DISPLAY_MANAGER to "false."
HEED_DEFAULT_DISPLAY_MANAGER=true
DEFAULT_DISPLAY_MANAGER_FILE=/etc/X11/default-display-manager
PATH=/bin:/usr/bin:/sbin:/usr/sbin
DAEMON=/usr/bin/kdm
PIDFILE=/var/run/kdm.pid
UPGRADEFILE=/var/run/kdm.upgrade
# parameters to support kdm customization
KDMRC=/etc/kde4/kdm/kdmrc
BACKGROUNDRC=/etc/kde4/kdm/backgroundrc
#if configuration is changed by kdmtheme or other tools, don't do magick
if grep -q "Theme=@@@ToBeReplacedByDesktopBase@@@" ${KDMRC} && grep -q "Wallpaper=default_blue.jpg" ${BACKGROUNDRC}
then
KDMOVERRIDEDIR=/etc/default/kdm.d
KDMCFGDIR=/var/run/kdm
KDMCFG=$KDMCFGDIR/kdmrc
BACKGROUNDCFG=$KDMCFGDIR/backgroundrc
test -x $DAEMON || exit 0
# uncomment, if you want auto-logon to be runlevel-dependant
#test "$runlevel" || { runlevel=`runlevel`; runlevel=${runlevel#* }; }
#test "$runlevel" = 4 && ARG=-autolog || ARG=-noautolog
# uncomment, if you want tons of debug info in your syslog
#ARG="$ARG -debug 255"
# we use an alternative kdm master configuration file
ARG="$ARG -config $KDMCFG"
# we source overrides. run-parts sorts the list in a predictable order
if [ -d "$KDMOVERRIDEDIR" ]; then
    for part in $(run-parts --list "$KDMOVERRIDEDIR" 2>/dev/null || true); do
        . "$part"
    done
fi
# we generate kdm configuration files
genkdmconf --in $KDMCFGDIR 1> /dev/null
# we update kdm configuration files (only overridden values)
[ -n "$USEBACKGROUND" ] && sed -i "s|^#\?UseBackground=.*|UseBackground=$USEBACKGROUND|" $KDMCFG
[ -n "$BACKGROUNDCFG" ] && sed -i "s|^#\?BackgroundCfg=.*|BackgroundCfg=$BACKGROUNDCFG|" $KDMCFG
[ -n "$USETHEME" ] && sed -i "s|^#\?UseTheme=.*|UseTheme=$USETHEME|" $KDMCFG
[ -n "$THEME" ] && sed -i "s|^#\?Theme=.*|Theme=$THEME|" $KDMCFG
[ -n "$WALLPAPER" ] && sed -i "s|^#\?Wallpaper=.*|Wallpaper=`readlink -f $WALLPAPER`|" $BACKGROUNDCFG
fi
# autologin overrides are useful for live debian environment
if [ -n "$AUTOLOGINUSER" ]; then
   sed -i "s|^#\?AutoLoginEnable=.*|AutoLoginEnable=true|" $KDMCFG
   sed -i "s|^#\?AutoLoginUser=.*|AutoLoginUser=$AUTOLOGINUSER|" $KDMCFG
fi
[ -n "$AUTOLOGINDELAY" ] && sed -i "s|^#\?AutoLoginDelay=.*|AutoLoginDelay=$AUTOLOGINDELAY|" $KDMCFG
[ -n "$AUTOLOGINAGAIN" ] && sed -i "s|^#\?AutoLoginAgain=.*|AutoLoginAgain=$AUTOLOGINAGAIN|" $KDMCFG
[ -n "$AUTOLOGINLOCKED" ] && sed -i "s|^#\?AutoLoginLocked=.*|AutoLoginLocked=$AUTOLOGINLOCKED|" $KDMCFG
# If we upgraded the daemon, we can't use the --exec argument to
# start-stop-daemon since the inode will have changed.  The risk here is that
# in a situation where the daemon died, its pidfile was not cleaned up, and
# some other process is now running under that pid, start-stop-daemon will send
# signals to an innocent process.  However, this seems like a corner case.
# C'est la vie!
if [ -e $UPGRADEFILE ]; then
  SSD_ARGS="--pidfile $PIDFILE --startas $DAEMON"
else
  SSD_ARGS="--pidfile $PIDFILE --exec $DAEMON"
fi
stillrunning () {
  if expr "$(cat /proc/$DAEMONPID/cmdline 2> /dev/null)" : "$DAEMON" > /dev/null 2>&1; then
    true
  else
    # if the daemon does not remove its own pidfile, we will
    rm -f $PIDFILE $UPGRADEFILE
    false
  fi;
case "$1" in
  start)
    if [ -e $DEFAULT_DISPLAY_MANAGER_FILE ] &&
      [ "$HEED_DEFAULT_DISPLAY_MANAGER" = "true" ] &&
      [ "$(cat $DEFAULT_DISPLAY_MANAGER_FILE)" != "$DAEMON" ]; then
      echo "Not starting K Display Manager (kdm); it is not the default display manager."
    else
      echo -n "Starting K Display Manager: kdm"
      start-stop-daemon --start --quiet $SSD_ARGS -- $ARG || echo -n " already running"
      echo "."
    fi
  restart)
    /etc/init.d/kdm stop
    if [ -f $PIDFILE ]; then
      if stillrunning; then
        exit 1
      fi
    fi
    /etc/init.d/kdm start
  reload)
    echo -n "Reloading K Display Manager configuration..."
    if start-stop-daemon --stop --signal 1 --quiet $SSD_ARGS; then
      echo "done."
    else
      echo "kdm not running."
    fi
  force-reload)
    /etc/init.d/kdm reload
  stop)
    echo -n "Stopping K Display Manager: kdm"
    if [ ! -f $PIDFILE ]; then
      echo " not running ($PIDFILE not found)."
      exit 0
    else
      DAEMONPID=$(cat $PIDFILE | tr -d '[:blank:]')
      KILLCOUNT=1
      if [ ! -e $UPGRADEFILE ]; then
        if start-stop-daemon --stop --quiet $SSD_ARGS; then
          # give kdm's signal handler a second to catch its breath
          sleep 1
        else
          echo -n " not running"
        fi
      fi
      while [ $KILLCOUNT -le 5 ]; do
          kill $DAEMONPID
        else
          break
        fi
        sleep 1
        KILLCOUNT=$(( $KILLCOUNT + 1 ))
      done
        echo -n " not responding to TERM signal (pid $DAEMONPID)"
      else
        rm -f $UPGRADEFILE
      fi
    fi
    echo "."
  status)
    status_of_proc -p "$PIDFILE" "$DAEMON" kdm && exit 0 || exit $?
    echo "Usage: /etc/init.d/kdm {start|stop|restart|reload|force-reload|status}"
    exit 1
esac
exit 0
