michal@:~$ sudo apt-get install pidgin
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
pidgin : Depends: libpurple0 (>= 2.7.0) but it is not going to be installed
Depends: perlapi-5.10.1
E: Broken packages
