oto log:
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-4-486 #1 Mon Mar 26 16:39:10 UTC 2007 i686
Build Date: 04 April 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 10 21:35:18 2007
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "Radeon Mobility x1600"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Synaptics Touchpad"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(**) Option "AIGLX" "on"
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,5950 card 17ff,058f rev 10 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 1002,5a34 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:05:0: chip 1002,5a37 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:06:0: chip 1002,5a38 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1002,5a39 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:12:0: chip 1002,4379 card 17ff,058f rev 80 class 01,01,8f hdr 00
(II) PCI: 00:13:0: chip 1002,4374 card 1002,4374 rev 80 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4375 card 1002,4375 rev 80 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4373 card 1002,4373 rev 80 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4372 card 17ff,058f rev 83 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,4376 card 17ff,058f rev 80 class 01,01,82 hdr 00
(II) PCI: 00:14:2: chip 1002,437b card 17ff,058f rev 01 class 04,03,00 hdr 00
(II) PCI: 00:14:3: chip 1002,4377 card 17ff,058f rev 80 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4371 card 0000,0000 rev 80 class 06,04,01 hdr 81
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 1002,71c5 card 17ff,058f rev 00 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 10ec,8168 card 17ff,058f rev 01 class 02,00,00 hdr 00
(II) PCI: 05:00:0: chip 168c,001c card 1a32,0100 rev 01 class 02,00,00 hdr 00
(II) PCI: 0b:01:0: chip 1180,0832 card 17ff,058f rev 00 class 0c,00,10 hdr 80
(II) PCI: 0b:01:1: chip 1180,0822 card 17ff,058f rev 19 class 08,05,00 hdr 80
(II) PCI: 0b:01:2: chip 1180,0843 card 17ff,058f rev 01 class 08,80,00 hdr 80
(II) PCI: 0b:01:3: chip 1180,0592 card 17ff,058f rev 0a class 08,80,00 hdr 80
(II) PCI: 0b:01:4: chip 1180,0852 card 17ff,058f rev 05 class 08,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,11), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xc0100000 - 0xc01fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MX[B]
(II) Bus 2: bridge is at (0:5:0), (0,2,4), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xc0200000 - 0xc02fffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x30000000 - 0x300fffff (0x100000) MX[B]
(II) Bus 5: bridge is at (0:6:0), (0,5,7), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 5 non-prefetchable memory range:
[0] -1 0 0xc0300000 - 0xc03fffff (0x100000) MX[B]
(II) Bus 8: bridge is at (0:7:0), (0,8,10), BCTRL: 0x0004 (VGA_EN is cleared)
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 11: bridge is at (0:20:4), (0,11,13), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 11 non-prefetchable memory range:
[0] -1 0 0xc0400000 - 0xc04fffff (0x100000) MX[B]
(--) PCI:*(1:0:0) ATI Technologies Inc unknown chipset (0x71c5) rev 0, Mem @ 0xc8000000/27, 0xc0100000/16, I/O @ 0x9000/8
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xc0401400 - 0xc04014ff (0x100) MX[B]
[1] -1 0 0xc0401000 - 0xc04010ff (0x100) MX[B]
[2] -1 0 0xc0400c00 - 0xc0400cff (0x100) MX[B]
[3] -1 0 0xc0400800 - 0xc04008ff (0x100) MX[B]
[4] -1 0 0xc0400000 - 0xc04007ff (0x800) MX[B]
[5] -1 0 0xc0300000 - 0xc030ffff (0x10000) MX[B]
[6] -1 0 0xc0200000 - 0xc0200fff (0x1000) MX[B]
[7] -1 0 0xc0000000 - 0xc0003fff (0x4000) MX[B]
[8] -1 0 0xfed00000 - 0xfed003ff (0x400) MX[B]
[9] -1 0 0xc0007000 - 0xc0007fff (0x1000) MX[B]
[10] -1 0 0xc0006000 - 0xc0006fff (0x1000) MX[B]
[11] -1 0 0xc0005000 - 0xc0005fff (0x1000) MX[B]
[12] -1 0 0xc0004000 - 0xc00041ff (0x200) MX[B]
[13] -1 0 0xc0100000 - 0xc010ffff (0x10000) MX[B](B)
[14] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MX[B](B)
[15] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[16] -1 0 0x00008460 - 0x0000846f (0x10) IX[B]
[17] -1 0 0x000003f4 - 0x000003f4 (0x1) IX[B]
[18] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[19] -1 0 0x00008450 - 0x0000845f (0x10) IX[B]
[20] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[21] -1 0 0x00008410 - 0x00008413 (0x4) IX[B]
[22] -1 0 0x00008420 - 0x00008427 (0x8) IX[B]
[23] -1 0 0x00008430 - 0x00008433 (0x4) IX[B]
[24] -1 0 0x00008440 - 0x00008447 (0x8) IX[B]
[25] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xc0401400 - 0xc04014ff (0x100) MX[B]
[5] -1 0 0xc0401000 - 0xc04010ff (0x100) MX[B]
[6] -1 0 0xc0400c00 - 0xc0400cff (0x100) MX[B]
[7] -1 0 0xc0400800 - 0xc04008ff (0x100) MX[B]
[8] -1 0 0xc0400000 - 0xc04007ff (0x800) MX[B]
[9] -1 0 0xc0300000 - 0xc030ffff (0x10000) MX[B]
[10] -1 0 0xc0200000 - 0xc0200fff (0x1000) MX[B]
[11] -1 0 0xc0000000 - 0xc0003fff (0x4000) MX[B]
[12] -1 0 0xfed00000 - 0xfed003ff (0x400) MX[B]
[13] -1 0 0xc0007000 - 0xc0007fff (0x1000) MX[B]
[14] -1 0 0xc0006000 - 0xc0006fff (0x1000) MX[B]
[15] -1 0 0xc0005000 - 0xc0005fff (0x1000) MX[B]
[16] -1 0 0xc0004000 - 0xc00041ff (0x200) MX[B]
[17] -1 0 0xc0100000 - 0xc010ffff (0x10000) MX[B](B)
[18] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MX[B](B)
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[22] -1 0 0x00008460 - 0x0000846f (0x10) IX[B]
[23] -1 0 0x000003f4 - 0x000003f4 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[25] -1 0 0x00008450 - 0x0000845f (0x10) IX[B]
[26] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[27] -1 0 0x00008410 - 0x00008413 (0x4) IX[B]
[28] -1 0 0x00008420 - 0x00008427 (0x8) IX[B]
[29] -1 0 0x00008430 - 0x00008433 (0x4) IX[B]
[30] -1 0 0x00008440 - 0x00008447 (0x8) IX[B]
[31] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(**) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "ati"
(II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
(II) Module ati: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 6.6.3
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
compiled for 7.1.1, module version = 1.1.1
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) ATI: ATI driver (version 6.6.3) for chipsets: ati, ativga
(II) R128: Driver for ATI Rage 128 chipsets:
ATI Rage 128 Mobility M3 LE (PCI), ATI Rage 128 Mobility M3 LF (AGP),
ATI Rage 128 Mobility M4 MF (AGP), ATI Rage 128 Mobility M4 ML (AGP),
ATI Rage 128 Pro GL PA (AGP?), ATI Rage 128 Pro GL PB (AGP?),
ATI Rage 128 Pro GL PC (AGP?), ATI Rage 128 Pro GL PD (PCI),
ATI Rage 128 Pro GL PE (AGP?), ATI Rage 128 Pro GL PF (AGP),
ATI Rage 128 Pro VR PG (AGP?), ATI Rage 128 Pro VR PH (AGP?),
ATI Rage 128 Pro VR PI (AGP?), ATI Rage 128 Pro VR PJ (AGP?),
ATI Rage 128 Pro VR PK (AGP?), ATI Rage 128 Pro VR PL (AGP?),
ATI Rage 128 Pro VR PM (AGP?), ATI Rage 128 Pro VR PN (AGP?),
ATI Rage 128 Pro VR PO (AGP?), ATI Rage 128 Pro VR PP (PCI),
ATI Rage 128 Pro VR PQ (AGP?), ATI Rage 128 Pro VR PR (PCI),
ATI Rage 128 Pro VR PS (AGP?), ATI Rage 128 Pro VR PT (AGP?),
ATI Rage 128 Pro VR PU (AGP?), ATI Rage 128 Pro VR PV (AGP?),
ATI Rage 128 Pro VR PW (AGP?), ATI Rage 128 Pro VR PX (AGP?),
ATI Rage 128 GL RE (PCI), ATI Rage 128 GL RF (AGP),
ATI Rage 128 RG (AGP), ATI Rage 128 VR RK (PCI),
ATI Rage 128 VR RL (AGP), ATI Rage 128 4X SE (AGP?),
ATI Rage 128 4X SF (AGP?), ATI Rage 128 4X SG (AGP?),
ATI Rage 128 4X SH (AGP?), ATI Rage 128 4X SK (AGP?),
ATI Rage 128 4X SL (AGP?), ATI Rage 128 4X SM (AGP),
ATI Rage 128 4X SN (AGP?), ATI Rage 128 Pro ULTRA TF (AGP),
ATI Rage 128 Pro ULTRA TL (AGP), ATI Rage 128 Pro ULTRA TR (AGP),
ATI Rage 128 Pro ULTRA TS (AGP?), ATI Rage 128 Pro ULTRA TT (AGP?),
ATI Rage 128 Pro ULTRA TU (AGP?)
(II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI Radeon VE/7000 QY (AGP/PCI), ATI Radeon VE/7000 QZ (AGP/PCI),
ATI ES1000 515E (PCI), ATI ES1000 5969 (PCI),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI Radeon IGP320 (A3) 4136, ATI Radeon IGP320M (U1) 4336,
ATI Radeon IGP330/340/350 (A4) 4137,
ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon 7000 IGP (A4+) 4237, ATI Radeon Mobility 7000 IGP 4437,
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 8500 AIW BB (AGP),
ATI Radeon 8500 AIW BC (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP),
ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835, ATI Radeon 9100 PRO IGP 7834,
ATI Radeon Mobility 9200 IGP 7835, ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP), ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP),
ATI FireGL RV360 AV (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon 9650,
ATI Radeon 9800SE AH (AGP), ATI Radeon 9800 AI (AGP),
ATI Radeon 9800 AJ (AGP), ATI FireGL X2 AK (AGP),
ATI Radeon 9800PRO NH (AGP), ATI Radeon 9800 NI (AGP),
ATI FireGL X2 NK (AGP), ATI Radeon 9800XT NJ (AGP),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE),
ATI Radeon Mobility X600 (M24) 3150 (PCIE),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE),
ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE), ATI FireGL V5000 (RV410) (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 XT (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 SE (RV410) (PCIE),
ATI Radeon X800 (R420) JH (AGP), ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800XT (R420) JP (AGP), ATI Radeon X800 SE (R420) (AGP),
ATI Radeon AIW X800 VE (R420) JT (AGP),
ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE), ATI FireGL V7100 (R423) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Radeon X800 (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 XTP (R430) (PCIE),
ATI Radeon X850 5D4C (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP)
(II) Primary Device is: PCI 01:00:0
(II) ATI: Candidate "Device" section "Radeon Mobility x1600".
(EE) No devices detected.
Fatal server error:
no screens found
