BŁĄD: Połączenie pominięte przez serwer IMAP
base_dir = /var/run/dovecot/
protocols = imap imaps pop3 pop3s
listen = *
disable_plaintext_auth = no
shutdown_clients = yes
#logi
log_path=/var/log/dovecot.log
info_log_path = /var/log/mail.log
log_timestamp = "%Y-%m-%d %H:%M:%S "
syslog_facility = mail
login_process_size = 64
login_greeting = Welcome. I'm ready ...
login_log_format_elements = user=<%u> method=%m rip=%r lip=%l %c
login_log_format = %$: %s
login_chroot = no
login_user = dovecot
login_process_per_connection = yes
login_processes_count = 3
login_max_processes_count = 128
mail_location = maildir:~/Maildir
#SSL
ssl_disable = no
ssl_cert_file = /etc/postfix/ssl/mail.pem
ssl_key_file = /etc/postfix/ssl/mail.pem
verbose_ssl = yes
mail_access_groups = postfix
protocol imap {
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
protocol lda {
postmaster_address = info@cukierniapawlowski.pl
auth_verbose = yes
auth_debug = yes
auth default {
mechanisms = plain login
passdb pam {
userdb passwd {
user = root
socket listen {
client {
path = /var/spool/postfix/private/auth
mode = 0660
user = postfix
group = postfix
dict {
plugin {
