Mam problem z sterownikami.
Polecenie:
glxinfo | grep directKod: Zaznacz cały
YesZainstalowałem, zmieniam wpis w xorg.conf z radeon na radeonhd i niestety X-y nie uruchamiają się.
Log:
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.37-trunk-amd64 x86_64 Debian
Current Operating System: Linux Wolak 2.6.32-5-amd64 #1 SMP Mon Mar 7 21:35:22 UTC 2011 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=657a0f43-6475-471f-bf20-6176e3446cbe ro quiet
Build Date: 18 February 2011 08:27:24PM
xorg-server 2:1.7.7-13 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Mon May 2 09:52:10 2011
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
(**) ModulePath set to "/usr/lib/xorg/modules"
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x7c8aa0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(--) using VT number 8
(--) PCI:*(0:1:0:0) 1002:68e0:1043:1bf2 ATI Technologies Inc Manhattan [Mobility Radeon HD Series] rev 0, Mem @ 0xc0000000/268435456, 0xd0020000/131072, I/O @ 0x0000d000/256, BIOS @ 0x????????/131072
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "radeonhd"
(II) Loading /usr/lib/xorg/modules/drivers/radeonhd_drv.so
(II) Module radeonhd: vendor="AMD GPG"
compiled for 1.7.7, module version = 1.3.0
ABI class: X.Org Video Driver, version 6.0
(II) RADEONHD: X driver for the following AMD GPG (ATI) graphics devices:
RV505 : Radeon X1550, X1550 64bit.
RV515 : Radeon X1300, X1550, X1600; FireGL V3300, V3350.
RV516 : Radeon X1300, X1550, X1550 64-bit, X1600; FireMV 2250.
R520 : Radeon X1800; FireGL V5300, V7200, V7300, V7350.
RV530 : Radeon X1300 XT, X1600, X1600 Pro, X1650; FireGL V3400, V5200.
RV535 : Radeon X1300, X1650.
RV550 : Radeon X2300 HD.
RV560 : Radeon X1650.
RV570 : Radeon X1950, X1950 GT; FireGL V7400.
R580 : Radeon X1900, X1950; AMD Stream Processor.
R600 : Radeon HD 2900 GT/Pro/XT; FireGL V7600/V8600/V8650.
RV610 : Radeon HD 2350, HD 2400 Pro/XT, HD 2400 Pro AGP; FireGL V4000.
RV620 : Radeon HD 3450, HD 3470.
RV630 : Radeon HD 2600 LE/Pro/XT, HD 2600 Pro/XT AGP; Gemini RV630;
FireGL V3600/V5600.
RV635 : Radeon HD 3650, HD 3670.
RV670 : Radeon HD 3690, 3850, HD 3870, FireGL V7700, FireStream 9170.
R680 : Radeon HD 3870 X2.
M52 : Mobility Radeon X1300.
M54 : Mobility Radeon X1400; M54-GL.
M56 : Mobility Radeon X1600; Mobility FireGL V5200.
M58 : Mobility Radeon X1800, X1800 XT; Mobility FireGL V7100, V7200.
M62 : Mobility Radeon X1350.
M64 : Mobility Radeon X1450, X2300.
M66 : Mobility Radeon X1700, X1700 XT; FireGL V5250.
M68 : Mobility Radeon X1900.
M71 : Mobility Radeon HD 2300.
M72 : Mobility Radeon HD 2400; Radeon E2400.
M74 : Mobility Radeon HD 2400 XT.
M76 : Mobility Radeon HD 2600;
(Gemini ATI) Mobility Radeon HD 2600 XT.
M82 : Mobility Radeon HD 3400.
M86 : Mobility Radeon HD 3650, HD 3670, Mobility FireGL V5700.
M88 : Mobility Radeon HD 3850, HD 3850 X2, HD 3870, HD3870 X2.
RS600 : Radeon Xpress 1200, Xpress 1250.
RS690 : Radeon X1200, X1250, X1270.
RS740 : RS740, RS740M.
RS780 : Radeon HD 3100/3200/3300 Series.
R700 : Radeon R700.
RV710 : Radeon HD4570, HD4350.
RV730 : Radeon HD4670, HD4650.
RV740 : Radeon HD4770. EXPERIMENTAL AND UNTESTED.
RV770 : Radeon HD 4800 Series; Everest, K2, Denali ATI FirePro.
RV790 : Radeon HD 4890.
M92 : Mobility Radeon HD4330, HD4530, HD4570. EXPERIMENTAL.
M93 : Mobility Radeon M93. EXPERIMENTAL AND UNTESTED.
M96 : Mobility Radeon HD4600.
M97 : Mobility Radeon HD4860. EXPERIMENTAL AND UNTESTED.
M98 : Mobility Radeon HD4850, HD4870.
(II) RADEONHD: version 1.3.0, built from non-git sources
(II) Primary Device is: PCI 01@00:00:0
(EE) No devices detected.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE) No devices detected.Kod: Zaznacz cały
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, CEDAR, CEDAR, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, CEDAR, ATI Radeon HD 5450,
Jądro 2.6.32-5-amd64
Karta
ATI Technologies Inc Manhattan [Mobility Radeon HD 5000 Series] Radeon 5470HD
