doszedłem do ostatniego etapu i napotkałęm problem a iż że jestem zielony w tematyce linuksa nie wiem co dalej z tym zrobić , oczywiście wszystko robię po kolei z http://debian.linux.pl/threads/20322-LA ... nfiguracja
root@debian:/tmp/iRedMail-0.6.1# bash iRedMail.sh
< INFO > Checking necessary command/package: dialog/dialog ...
< INFO > Check configuration file: /tmp/iRedMail-0.6.1/./config... Found.
< Question > Use it for mail server setting? [y|N]y
< INFO > Use configuration file: /tmp/iRedMail-0.6.1/./config for mail server setting.
< INFO > Import installation process status from file: /tmp/iRedMail-0.6.1/./.iRedMail.installation.status.
< INFO > Installing package(s): postfix postfix-pcre awstats mysql-server-5.0 mysql-client-5.0 postfix-ldap slapd ldap-utils libnet-ldap-perl postfix-policyd dovecot-imapd dovecot-pop3d amavisd-new libcrypt-openssl-rsa-perl libmail-dkim-perl clamav-freshclam clamav-daemon spamassassin altermime libmail-spf-perl python-ldap libapache2-mod-wsgi python-mysqldb python-ldap python-jinja2 python-netifaces python-webpy python-ldap bzip2 acl patch cron tofrodos
Reading package lists... Done
Building dependency tree
Note, selecting 'mysql-server-5.1' instead of 'mysql-server-5.0'
Package mysql-client-5.0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
mysql-client-5.1
N: Ignoring file 'opera.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Package 'mysql-client-5.0' has no installation candidate
< ERROR > Installation failed, please check the terminal output.
