Apr 22 13:40:37 Ksenia postfix/smtp[5113]: 9221A7402C: to=<freakpower@excite.co.jp>, relay=mx.excite.co.jp[180.235.96.64]:25, delay=102636, delays=102633/0.71/1.8/0, ds
n=4.4.2, status=deferred (lost connection with mx.excite.co.jp[180.235.96.64] while receiving the initial server greeting)
Apr 22 13:40:37 Ksenia postfix/smtp[5114]: 5484C74006: host idcmail-mx1so.cg.shawcable.net[24.71.223.11] refused to talk to me: 554-idcmail.shaw.ca 554 Your connection
from 83.19.68.26 has been rejected due to poor reputation.
Apr 22 13:40:38 Ksenia postfix/smtp[5114]: 5484C74006: to=<andy8cbr@shaw.ca>, relay=idcmail-mx2no.cg.shawcable.net[64.59.134.8]:25, delay=102757, delays=102754/0.74/2.3
/0, dsn=4.0.0, status=deferred (host idcmail-mx2no.cg.shawcable.net[64.59.134.8] refused to talk to me: 554-idcmail.shaw.ca 554 Your connection from 83.19.68.26 has bee
n rejected due to poor reputation.)
Apr 22 13:40:38 Ksenia postfix/smtp[5101]: B462074026: to=<freakyc_74@juno.com>, relay=mx.dca.untd.com[64.136.44.37]:25, delay=102638, delays=102634/0.86/2.7/0, dsn=4.0
.0, status=deferred (host mx.dca.untd.com[64.136.44.37] refused to talk to me: 550 IP 83.19.68.26 in zen.spamhaus.org : Access Denied, please see www.spamhaus.org )
Apr 22 13:40:38 Ksenia postfix/smtp[5104]: 65F6174005: to=<andyakalife@juno.com>, relay=mx.vgs.untd.com[64.136.52.37]:25, delay=102794, delays=102790/0.4/3.2/0, dsn=4.0
.0, status=deferred (host mx.vgs.untd.com[64.136.52.37] refused to talk to me: 550 IP 83.19.68.26 in zen.spamhaus.org : Access Denied, please see www.spamhaus.org )
Apr 22 13:40:40 Ksenia postfix/smtp[5109]: 21E7D7400E: to=<andy_jpt@ac.auone-net.jp>, relay=mx.ac.auone-net.jp[210.141.108.179]:25, delay=102791, delays=102786/0.6/1.6/
3.3, dsn=4.0.0, status=deferred (host mx.ac.auone-net.jp[210.141.108.179] said: 450 <du26.internetdsl.tpnet.pl[83.19.68.26]>: Client host rejected: sigh (in reply to RC
PT TO command))
Apr 22 13:40:56 Ksenia postfix/smtp[5097]: connect to mail.kobaltmusic.be[194.73.110.26]:25: Connection timed out
Apr 22 13:40:56 Ksenia postfix/smtp[5100]: connect to mail.kobaltmusic.be[194.73.110.26]:25: Connection timed out
Apr 22 13:40:56 Ksenia postfix/smtp[5097]: 390957403B: to=<hegifcnpel@kobaltmusic.be>, relay=none, delay=102487, delays=102466/0.27/21/0, dsn=4.4.1, status=deferred (co
nnect to mail.kobaltmusic.be[194.73.110.26]:25: Connection timed out)
Apr 22 13:40:56 Ksenia postfix/smtp[5100]: 34BE974021: to=<jgiwdtmblw@kobaltmusic.be>, relay=none, delay=102001, delays=101980/0.32/21/0, dsn=4.4.1, status=deferred (co
Apr 22 13:40:56 Ksenia postfix/smtp[5089]: connect to mx1.gmmail.com[10.42.23.11]:25: Connection timed out
Apr 22 13:40:56 Ksenia postfix/smtp[5089]: 5955874042: to=<erickmotagonzalez@gmmail.com>, relay=none, delay=102369, delays=102348/0.77/21/0, dsn=4.4.1, status=deferred
(connect to mx1.gmmail.com[10.42.23.11]:25: Connection timed out)
Apr 22 13:43:55 Ksenia postfix/scache[5117]: statistics: start interval Apr 22 13:40:35
Apr 22 13:43:55 Ksenia postfix/scache[5117]: statistics: domain lookup hits=0 miss=3 success=0%
Apr 22 13:43:55 Ksenia postfix/scache[5117]: statistics: address lookup hits=0 miss=4 success=0%
Apr 22 13:50:34 Ksenia postfix/qmgr[5029]: 2D9C37400F: from=<uvcek@carlsbergboy.be>, size=1883, nrcpt=1 (queue active)
Apr 22 13:50:36 Ksenia postfix/smtp[5125]: 2D9C37400F: to=<dim@bboa.com>, relay=smtp.getontheweb.com[66.36.236.47]:25, delay=103265, delays=103263/0.06/1.5/0.29, dsn=2.
0.0, status=sent (250 ok 1303456302 qp 50917)
Apr 22 13:50:36 Ksenia postfix/qmgr[5029]: 2D9C37400F: removed
main.cf
command_directory = /usr/sbin
mail_owner = postfix
mydomain = gocz.info
myhostname = ksenia.gocz.info
myorigin = $mydomain
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain
mynetworks = 192.168.2.0/24, 127.0.0.0/8
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relay_domains = $mydestination
smtpd_helo_required = yes
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
reject_unauth_destination,
reject_unknown_recipient_domain,
reject_non_fqdn_recipient
smtpd_client_restrictions =
#reject_unknown_client,
reject_rbl_client dul.dnsbl.sorbs.net,
reject_rbl_client list.dsbl.org,
reject_rbl_client sbl.spamhaus.org,
reject_rbl_client cbl.abuseat.org
smtpd_sender_restrictions =
reject_unknown_sender_domain,
reject_non_fqdn_sender,
reject_unknown_address
#AUTH SMTP
smtpd_sasl_type = dovecot
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
