Architektura: i386
Pamięć:
# lshw -class memory
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 1101 (08/18/2010)
capacity: 8128KiB
capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 128KiB
capabilities: internal write-through instruction
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 512KiB
capabilities: internal write-through unified
*-cache:2
description: L3 cache
physical id: 7
slot: L3-Cache
capacity: 4MiB
capabilities: internal write-back unified
*-memory
description: System Memory
physical id: 36
slot: System board or motherboard
*-bank:0
description: DIMM DDR Synchronous 1333 MHz (0.8 ns)
product: PartNum0
vendor: Manufacturer0
physical id: 0
serial: SerNum0
slot: DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMM [empty]
product: PartNum1
vendor: Manufacturer1
physical id: 1
serial: SerNum1
slot: DIMM1
*-bank:2
product: PartNum2
vendor: Manufacturer2
physical id: 2
serial: SerNum2
slot: DIMM2
width: 64 bits
*-bank:3
product: PartNum3
vendor: Manufacturer3
physical id: 3
serial: SerNum3
slot: DIMM3
Pierwsza moja myśl, to, że producenci kart pamięci zaczęli oszukiwać tak jak na dyskach (1000B = 1KB itd.), jądro jest typu bigmem, więc powinien widzieć całą RAM...
Co o tym myślicie?
