B
starach
Błąd przy uruchamianiu gedit z terminala
Post autor: starach »
Co prawda nie powoduje to dziwne zachowanie problemów z funkcjonowaniem aplikacji tylko bardzo dużo śmieci wypluwa do konsoli. Chciałbym wiedzieć dlaczego.
root@debian:log> gedit
(gedit:11593): EggSMClient-WARNING **: Failed to connect to the session manager: None of the authentication protocols specified are supported
GConf Error: Failed to contact configuration server; the most common cause is a missing or misconfigured D-Bus session bus daemon. See http://projects.gnome.org/gconf/ for information. (Details -  1: Failed to get connection to session: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
root@debian:log> GConf Error: Failed to contact configuration server; the most common cause is a missing or misconfigured D-Bus session bus daemon. See http://projects.gnome.org/gconf/ for information. (Details -  1: Failed to get connection to session: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
root@debian:log>
