[+] Konfiguracja ejabberd
cooleq
Post autor: cooleq »
Próbuję uruchomić firmowy serwer do obsługi lokalnej. Niby miało być prosto ale jakoś nie działa.
Tu moja konfiguracja
%%%     Debian ejabberd configuration file
%%%     This config must be in UTF-8 encoding
%%% The parameters used in this configuration file are explained in more detail
%%% in the ejabberd Installation and Operation Guide.
%%% Please consult the Guide in case of doubts, it is available at
%%% /usr/share/doc/ejabberd/guide.html
%%%   OVERRIDE OPTIONS STORED IN DATABASE
%% Override global options (shared by all ejabberd nodes in a cluster).
%%override_global.
%% Override local options (specific for this particular ejabberd node).
%%override_local.
%% Remove the Access Control Lists before new ones are added.
%%override_acls.
%% Options which are set by Debconf and managed by ucf
%% Admin user
{acl, admin, {user, "admin", "localhost"}}.
%% Hostname
{hosts, ["ansee.pl"]}.
%%% This configuration file contains Erlang terms.
%%% In case you want to understand the syntax, here are the concepts:
%%%  - The character to comment a line is %
%%%  - Each term ends in a dot, for example:
%%%      override_global.
%%%  - A tuple has a fixed definition, its elements are
%%%    enclosed in {}, and separated with commas:
%%%      {loglevel, 4}.
%%%  - A list can have as many elements as you want,
%%%    and is enclosed in [], for example:
%%%      [http_poll, web_admin, tls]
%%%  - A keyword of ejabberd is a word in lowercase.
%%%    The strings are enclosed in "" and can have spaces, dots...
%%%      {language, "en"}.
%%%      {ldap_rootdn, "dc=example,dc=com"}.
%%%  - This term includes a tuple, a keyword, a list and two strings:
%%%      {hosts, ["jabber.example.net", "im.example.com"]}.
%%%   DEBUGGING
%% loglevel: Verbosity of log files generated by ejabberd.
%% 0: No ejabberd log at all (not recommended)
%% 1: Critical
%% 2: Error
%% 3: Warning
%% 4: Info
%% 5: Debug
{loglevel, 4}.
%% watchdog_admins: If an ejabberd process consumes too much memory,
%% send live notifications to those Jabber accounts.
%%{watchdog_admins, ["bob@example.com"]}.
%%%   SERVED HOSTNAMES
%% hosts: Domains served by ejabberd.
%% You can define one or several, for example:
%% {hosts, ["example.net", "example.com", "example.org"]}.
%% (This option is defined by debconf earlier)
%% {hosts, ["localhost"]}.
%% route_subdomains: Delegate subdomains to other Jabber server.
%% For example, if this ejabberd serves example.org and you want
%% to allow communication with a Jabber server called im.example.org.
%%{route_subdomains, s2s}.
%%%   LISTENING PORTS
%% listen: Which ports will ejabberd listen, which service handles it
%% and what options to start it with.
{listen,
  {5222, ejabberd_c2s, [
            {access, c2s},
            {shaper, c2s_shaper},
            {max_stanza_size, 65536},
            starttls, {certfile, "/etc/ejabberd/ejabberd.pem"}
  %% To enable the old SSL connection method (deprecated) in port 5223:
  %%{5223, ejabberd_c2s, [
  %%            {access, c2s},
  %%            {shaper, c2s_shaper},
  %%            {max_stanza_size, 65536},
  %%            tls, {certfile, "/etc/ejabberd/ejabberd.pem"}
  {5269, ejabberd_s2s_in, [
               {shaper, s2s_shaper},
               {max_stanza_size, 131072}
  %% External MUC jabber-muc (but internal mod_muc is better :) )
  %%{5554, ejabberd_service, [
  %%                {ip, {127, 0, 0, 1}},
  %%                {access, all},
  %%                {shaper_rule, fast},
  %%                {host, "muc.localhost", [{password, "secret"}]}
  %% Jabber ICQ Transport
  %%{5555, ejabberd_service, [
  %%                {access, all},
  %%                {hosts, ["icq.localhost", "sms.localhost"],
  %%                       [{password, "secret"}]}
  %% AIM Transport
  %%{5556, ejabberd_service, [
  %%                {access, all},
  %%                {host, "aim.localhost", [{password, "secret"}]}
  %% MSN Transport
  %%{5557, ejabberd_service, [
  %%                {access, all},
  %%                {host, "msn.localhost", [{password, "secret"}]}
  %% Yahoo! Transport
  %%{5558, ejabberd_service, [
  %%                {access, all},
  %%                {host, "yahoo.localhost", [{password, "secret"}]}
  %% External JUD (internal is more powerful,
  %% but doesn't allow to register users from other servers)
  %%{5559, ejabberd_service, [
  %%                {access, all},
  %%                {host, "jud.localhost", [{password, "secret"}]}
  {5280, ejabberd_http, [
             http_poll,
             web_admin
%% s2s_use_starttls: Enable STARTTLS + Dialback for S2S connections.
%% Allowed values are: true or false.
%% You must specify a certificate file.
{s2s_use_starttls, true}.
%% s2s_certfile: Specify a certificate file.
{s2s_certfile, "/etc/ejabberd/ejabberd.pem"}.
%% domain_certfile: Specify a different certificate for each served hostname.
%%{domain_certfile, "example.org", "/path/to/example_org.pem"}.
%%{domain_certfile, "example.com", "/path/to/example_com.pem"}.
%% S2S whitelist or blacklist
%% Default s2s policy for undefined hosts.
%%{s2s_default_policy, allow}.
%% Allow or deny communication with specific servers.
%%{{s2s_host, "goodhost.org"}, allow}.
%%{{s2s_host, "badhost.org"}, deny}.
%%%   AUTHENTICATION
%% auth_method: Method used to authenticate the users.
%% The default method is the internal.
%% If you want to use a different method,
%% comment this line and enable the correct ones.
{auth_method, internal}.
%% Authentication using external script
%% Make sure the script is executable by ejabberd.
%%{auth_method, external}.
%%{extauth_program, "/path/to/authentication/script"}.
%% Authentication using ODBC
%% Remember to setup a database in the next section.
%%{auth_method, odbc}.
%% Authentication using PAM
%%{auth_method, pam}.
%%{pam_service, "pamservicename"}.
%% Authentication using LDAP
%%{auth_method, ldap}.
%% List of LDAP servers:
%%{ldap_servers, ["localhost"]}.
%% Encryption of connection to LDAP servers (LDAPS):
%%{ldap_encrypt, tls}.
%% Port connect to LDAP server:
%%{ldap_port, 636}.
%% LDAP manager:
%%{ldap_rootdn, "dc=example,dc=com"}.
%% Password to LDAP manager:
%%{ldap_password, "******"}.
%% Search base of LDAP directory:
%%{ldap_base, "dc=example,dc=com"}.
%% LDAP attribute that holds user ID:
%%{ldap_uids, [{"mail", "%u@mail.example.org"}]}.
%% LDAP filter:
%%{ldap_filter, "(objectClass=shadowAccount)"}.
%% Anonymous login support:
%%   auth_method: anonymous
%%   anonymous_protocol: sasl_anon | login_anon | both
%%   allow_multiple_connections: true | false
%%{host_config, "public.example.org", [{auth_method, anonymous},
%%                                     {allow_multiple_connections, false},
%%                                     {anonymous_protocol, sasl_anon}]}.
%% To use both anonymous and internal authentication:
%%{host_config, "public.example.org", [{auth_method, [internal, anonymous]}]}.
%%%   DATABASE SETUP
%% ejabberd uses by default the internal Mnesia database,
%% so you can avoid this section.
%% This section provides configuration examples in case
%% you want to use other database backends.
%% Please consult the ejabberd Guide for details about database creation.
%% MySQL server:
%%{odbc_server, {mysql, "server", "database", "username", "password"}}.
%% If you want to specify the port:
%%{odbc_server, {mysql, "server", 1234, "database", "username", "password"}}.
%% PostgreSQL server:
%%{odbc_server, {pgsql, "server", "database", "username", "password"}}.
%%{odbc_server, {pgsql, "server", 1234, "database", "username", "password"}}.
%% If you use PostgreSQL, have a large database, and need a
%% faster but inexact replacement for "select count(*) from users"
%%{pgsql_users_number_estimate, true}.
%% ODBC compatible or MSSQL server:
%%{odbc_server, "DSN=ejabberd;UID=ejabberd;PWD=ejabberd"}.
%% Number of connections to open to the database for each virtual host
%%{odbc_pool_size, 10}.
%% Interval to make a dummy SQL request to keep alive the connections
%% to the database. Specify in seconds: for example 28800 means 8 hours
%%{odbc_keepalive_interval, undefined}.
%%%   TRAFFIC SHAPERS
%% The "normal" shaper limits traffic speed to 1.000 B/s
{shaper, normal, {maxrate, 1000}}.
%% The "fast" shaper limits traffic speed to 50.000 B/s
{shaper, fast, {maxrate, 50000}}.
%%%   ACCESS CONTROL LISTS
%% The 'admin' ACL grants administrative privileges to Jabber accounts.
%% You can put as many accounts as you want.
%%{acl, admin, {user, "aleksey", "localhost"}}.
%%{acl, admin, {user, "ermine", "example.org"}}.
%% Blocked users
%%{acl, blocked, {user, "baduser", "example.org"}}.
%%{acl, blocked, {user, "test"}}.
%% Local users: don't modify this line.
{acl, local, {user_regexp, ""}}.
%% More examples of ACLs
%%{acl, jabberorg, {server, "jabber.org"}}.
%%{acl, aleksey, {user, "aleksey", "jabber.ru"}}.
%%{acl, test, {user_regexp, "^test"}}.
%%{acl, test, {user_glob, "test*"}}.
%%%   ACCESS RULES
%% Define the maximum number of time a single user is allowed to connect:
{access, max_user_sessions, [{10, all}]}.
%% This rule allows access only for local users:
{access, local, [{allow, local}]}.
%% Only non-blocked users can use c2s connections:
{access, c2s, [{deny, blocked},
           {allow, all}]}.
%% For all users except admins used "normal" shaper
{access, c2s_shaper, [{none, admin},
              {normal, all}]}.
%% For all S2S connections used "fast" shaper
{access, s2s_shaper, [{fast, all}]}.
%% Only admins can send announcement messages:
{access, announce, [{allow, admin}]}.
%% Only admins can use configuration interface:
{access, configure, [{allow, admin}]}.
%% Admins of this server are also admins of MUC service:
{access, muc_admin, [{allow, admin}]}.
%% All users are allowed to use MUC service:
{access, muc, [{allow, all}]}.
%% No username can be registered via in-band registration:
%% To enable in-band registration, replace 'deny' with 'allow'
% (note that if you remove mod_register from modules list then users will not
% be able to change their password as well as register).
% This setting is default because it's more safe.
{access, register, [{allow, all}]}.
%% Everybody can create pubsub nodes
{access, pubsub_createnode, [{allow, all}]}.
%%%   DEFAULT LANGUAGE
%% language: Default language used for server messages.
{language, "en"}.
%%%   MODULES
%% Modules enabled in all ejabberd virtual hosts.
{modules,
  {mod_adhoc,    []},
  {mod_announce, [{access, announce}]}, % requires mod_adhoc
  {mod_caps,     []},
  {mod_configure,[]}, % requires mod_adhoc
  {mod_ctlextra, []},
  {mod_disco,    []},
  %%{mod_echo,   [{host, "echo.localhost"}]},
  {mod_irc,      []},
  {mod_last,     []},
  {mod_muc,      [
          %%{host, "conference.@HOST@"},
          {access, muc},
          {access_create, muc},
          {access_persistent, muc},
          {access_admin, muc_admin},
          {max_users, 500}
  %%{mod_muc_log,[]},
  {mod_offline,  []},
  {mod_privacy,  []},
  {mod_private,  []},
  {mod_proxy65,  [
          {access, local},
  {mod_pubsub,   [ % requires mod_caps
          {access_createnode, pubsub_createnode},
          {plugins, ["default", "pep"]}
  {mod_register, [
          %% After successful registration, the user receives
          %% a message with this subject and body.
          {welcome_message, {"Welcome!",
                     "Welcome to a Jabber service powered by Debian. "
                     "For information about Jabber visit "
                     "http://www.jabber.org"}},
          %% Replace it with 'none' if you don't want to send such message:
          %%{welcome_message, none},
          %% When a user registers, send a notification to
          %% these Jabber accounts.
          %%{registration_watchers, ["admin1@example.org"]},
          {access, register}
  {mod_roster,   []},
  %%{mod_service_log,[]},
  %%{mod_shared_roster,[]},
  {mod_stats,    []},
  {mod_time,     []},
  {mod_vcard,    []},
  {mod_version,  []}
%%% $Id: ejabberd.cfg.example 1178 2008-02-08 18:28:36Z badlop $
%%% Local Variables:
%%% mode: erlang
%%% End:
%%% vim: set filetype=erlang tabstop=8:
Otworzyłem porty poleceniem
iptables -A INPUT -p tcp --dport 5222 -m state --state NEW -j ACCEPT
iptables -A INPUT -p tcp --dport 5269 -m state --state NEW -j ACCEPT
iptables -A OUTPUT -p tcp --dport 5222 -m state --state NEW -j ACCEPT
iptables -A OUTPUT -p tcp --dport 5269 -m state --state NEW -j ACCEPT
Fragment wyniku polecenia:
lsof -i
epmd      28348 ejabberd    3u  IPv4  989209       TCP *:4369 (LISTEN)
epmd      28348 ejabberd    5u  IPv4 1148750       TCP localhost:4369->localhost:35427 (ESTABLISHED)
Tylko nie wiem dlaczego tak, skoro powinno być 5222.
W każdym razie, przy próbie zarejestrowania użytkownika przez PSI dostaję kompunikat
"Niepoprawna nazwa serwera".
Nie konfigurowałem nic więcej niż jest http://daggerka.pl/2011/02/24/ejabberd- ... r-jabbera/
mendeczka
Post autor: mendeczka »
Przede wszystkim ustaw siebie jako administratora, odblokuj sobie ACL, następnie sprawdź, czy uda Ci się wejść przez WWW. Przetestuj nawet LINKS-em:
http://localhost:5280/admin
Przedstaw, co pokazuje:
ejabberdctl status
Klient też nasłuchuje na tych portach
Wydaje mi się, że jeśli już to powinieneś użyć --sport w powyższych regułach.
Raczej na łańcuchu INPUT (na wejściu a nie na wyjściu)!
cooleq
http://192.168.0.150:5280/admin
Rzeczywiście, strona próbuję się otworzyć ale nie mogę przejść autoryzacji. Założyłem konto poleceniem:
ejabberdctl register admin ansee.pl test
ale dalej nie mogę.
W konfigu mam ustawione
%% Admin user
I z linksa na serwerze też nie mogę się zalogować.
Yampress, nie do końca wiem o czym mówisz, przecież otworzyłem i wejście i wyjście. Czy generalnie chodzi o to żeby otworzyć tylko nasłuch? Tylko że przecież serwer też odpowiada to chyba też musi być otwarte ,,OUTPUT''?
Ps. Zapomniałem:
Heimdall:/home/tomasz# ejabberdctl status
Node ejabberd@Heimdall is started. Status: started
ejabberd is running
Ps. Chyba powoli zaczynam rozumieć jak działa XMPP. W każdym razie rejestracja już działa, mogę to robić i z poziomu systemu (ejabberctl) jak i z klienta. Niestety dalej nie mogę się zalogować do webadmina.
Dodanie linijki:
{access, configure, [{allow, admins}]}
też nie pomogło.
mendeczka
Ważne jest jak się logujesz. Spróbuj
admin@localhost
no i hasło. Bo rozumiem że okienko logowania pokazuje się :)
cooleq
Tak pojawia się, ale nie da się zalogować używając tego co napisałeś ani żadnej z kombinacji:
[email]admin@localhost@ansee.pl[/email]
[email]admin@ansee.pl[/email]@localhost
mendeczka
Poprawny login to np.:
admin@localhost
admin@twojadomena.pl
Nie możesz używać tego co napisałeś?
Jeżeli nie działa Ci to oznacza błąd w konfiguracji.
cooleq
No jak napisałem, żadna z tych kombinacji nie pozwala się zalogować. A te 3 członowe to gdzieś wyczytałem, że tak chyba powinno być, ale widać to lipa była.
mendeczka
To popraw (dodaj) w pliku konfiguracyjnym:
%% Hostname
{hosts, ["localhost" , "ansee.pl"]}.
Przeładuj jabbera i sprawdź.
Jeżeli poprawnie zarejestrowałeś użytkownika "admin" to powinno pójść na:
admin@localhost
