make-live - wlasne LiveCD
ufocek
Post autor: ufocek »
Znalazlem na forum kaka napisal jak mozna zrobic wlasny livecd, no i akurat musze cos takiego zrobic wiec postanowilem wyprobowac ten pakiet.
Do pewnego momentu wszystko idzie ladnie pieknie az do tego momentu
Parallel mksquashfs: Using 2 processors
Creating little endian 3.0 filesystem on /home/ufo/livecd/debian-live/binary/casper/filesystem.squashfs, block size 65536.
0 MB .......... .......... .......... .......... .......... ..........
60 MB .......... .......... .......... .......... .......... ..........
120 MB .......... .......... .......... .......... .......... ..........
180 MB .......... .......... .......... .......... .......... ..........
240 MB .......... .......... .......... .......... .......... ..........
300 MB .......... .........
Little endian filesystem, data block size 65536, compressed data, compressed metadata, compressed fragments
Filesystem size 328202.04 Kbytes (320.51 Mbytes)
37.17% of uncompressed filesystem size (882956.18 Kbytes)
Inode table size 528627 bytes (516.24 Kbytes)
32.57% of uncompressed inode table size (1622967 bytes)
Directory table size 475008 bytes (463.88 Kbytes)
47.77% of uncompressed directory table size (994368 bytes)
Number of duplicate files found 3458
Number of inodes 51573
Number of files 39782
Number of fragments 5329
Number of symbolic links 1820
Number of device nodes 5352
Number of fifo nodes 1
Number of socket nodes 0
Number of directories 4618
Number of uids 5
root (0)
man (6)
klog (102)
news (9)
syslog (101)
Number of gids 22
video (44)
disk (6)
audio (29)
cdrom (24)
tty (5)
floppy (25)
dialout (20)
kmem (15)
lp (7)
tape (26)
shadow (42)
dhcp (101)
plugdev (46)
games (60)
mail (8)
utmp (43)
staff (50)
src (40)
root (0)
nvram (105)
adm (4)
klog (103)
Get:1 http://ftp.de.debian.org etch Release.gpg [378B]
Get:2 http://security.debian.org etch/updates Release.gpg [189B]
Get:3 http://security.debian.org etch/updates Release [22.5kB]
Get:4 http://ftp.de.debian.org etch Release [58.2kB]
Get:5 http://security.debian.org etch/updates/main Packages [59.4kB]
Get:6 http://ftp.de.debian.org etch/main Packages [4295kB]
Fetched 4435kB in 11s (375kB/s)
Reading package lists...
Building dependency tree...
Reading extended state information...
Initializing package states...
Writing extended state information...
Reading task descriptions...
Building tag database...
The following NEW packages will be installed:
syslinux
The following packages are RECOMMENDED but will NOT be installed:
mtools
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 325kB of archives. After unpacking 684kB will be used.
Get:1 http://ftp.de.debian.org etch/main syslinux 1:3.31-4 [325kB]
Fetched 325kB in 0s (356kB/s)
Selecting previously deselected package syslinux.
(Reading database ... 41748 files and directories currently installed.)
Unpacking syslinux (from .../syslinux_1%3a3.31-4_i386.deb) ...
Setting up syslinux (3.31-4) ...
The following packages will be REMOVED:
syslinux{p}
0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 684kB will be freed.
(Reading database ... 41799 files and directories currently installed.)
Removing syslinux ...
cp: cel `/home/ufo/livecd/debian-live/binary/isolinux/initrd.gz' nie jest katalogiem
Komus sie udalo zbudowac przy pomocy tego narzedzia wlasny live-cd?
pozdrawiam
Albert
[ Dodano: 2007-06-11, 08:44 ]
Po przenalizowaniu instalacji wydaje sie ze jest jakis dziwny blad w skryptach i dlatego tutaj konczy sie dzialanie.
Druga sprawa do tych ktorzy robili takie wlasne liveCD, jak uzyskac w nim takie rzeczy jak:
- wlasny hostname ( wbilem sie na chroot , ustawilem hostname oraz dodalem to w casper.conf)
ale dalej mam domyslny hostname live
- staly adres ip ( zeby nie pobieral poprzez dhcpd) ustawilem to ale niedziala to
pozdrawiam
Albert
[ Dodano: 2007-06-11, 22:15 ]
Ktos mi powie jak na takim livecd zbudowanym mozna ustawic statycznie adres ip zeby po odpaleniu CD niepobieral adresu z dhcpd ale mial juz przypisany statycznie?
Najdziwniejsze jest to ze po wydaniu polecenia ifconfig niepokazuje mi zadnych interfejsow...
pozdrawiam
Albert
