Mam następujący problem. Po instalacji Compiza komendą:
apt-get install compiz compizconfig-settings-manager compiz-fusion-plugins-main compiz-gnome compiz-gtkOto wyniki poleceń:
lspci -nKod: Zaznacz cały
00:00.0 0600: 8086:2770 (rev 02)
00:01.0 0604: 8086:2771 (rev 02)
00:02.0 0300: 8086:2772 (rev 02)
00:02.1 0380: 8086:2776 (rev 02)
00:1c.0 0604: 8086:27d0 (rev 01)
00:1c.1 0604: 8086:27d2 (rev 01)
00:1d.0 0c03: 8086:27c8 (rev 01)
00:1d.1 0c03: 8086:27c9 (rev 01)
00:1d.2 0c03: 8086:27ca (rev 01)
00:1d.3 0c03: 8086:27cb (rev 01)
00:1d.7 0c03: 8086:27cc (rev 01)
00:1e.0 0604: 8086:244e (rev e1)
00:1e.2 0401: 8086:27de (rev 01)
00:1f.0 0601: 8086:27b8 (rev 01)
00:1f.1 0101: 8086:27df (rev 01)
00:1f.2 0101: 8086:27c0 (rev 01)
00:1f.3 0c05: 8086:27da (rev 01)
02:00.0 0200: 14e4:1677 (rev 01)
uname -rKod: Zaznacz cały
[2.6.32-5-amd64Kod: Zaznacz cały
/var/log/Xorg.0.logKod: Zaznacz cały
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.32-5-amd64 x86_64 Debian
Current Operating System: Linux debian 2.6.32-5-amd64 #1 SMP Wed Jan 12 03:40:32 UTC 2011 x86_64
Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-5-amd64 root=UUID=5799db38-719c-434e-a1db-8bbfd5838aee ro quiet
Build Date: 12 January 2011 02:59:50AM
xorg-server 2:1.7.7-11 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check [URL]http://wiki.x.org[/URL]
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 24 21:54:49 2011
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
Entry deleted from font path.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins,
built-ins
(**) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x7c8a00
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 8
(--) PCI:*(0:0:2:0) 8086:2772:1028:01ad Intel Corporation 82945G/GZ Integrated Graphics Controller rev 2, Mem @ 0xfeb00000/524288, 0xe0000000/268435456, 0xfeac0000/262144, I/O @ 0x0000e898/8
(--) PCI: (0:0:2:1) 8086:2776:1028:01ad Intel Corporation 82945G/GZ Integrated Graphics Controller rev 2, Mem @ 0xfeb80000/524288
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DRI2
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
compiled for 1.7.7, module version = 1.0.0
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.13.0
ABI class: X.Org Video Driver, version 6.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
(II) Primary Device is: PCI 00@00:02:0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(==) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(**) intel(0): Option "DRI" "true"
(II) intel(0): Integrated Graphics Chipset: Intel(R) 945G
(--) intel(0): Chipset: "945G"
(**) intel(0): Tiling enabled
(**) intel(0): SwapBuffers wait enabled
(==) intel(0): video overlay key set to 0x101fe
(II) intel(0): Output VGA1 using monitor section Monitor0
(II) intel(0): EDID for output VGA1
(II) intel(0): Manufacturer: DEL Model: 7006 Serial#: 0
(II) intel(0): Year: 2003 Week: 6
(II) intel(0): EDID Version: 1.3
(II) intel(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) intel(0): Sync: Separate
(II) intel(0): Max Image Size [cm]: horiz.: 30 vert.: 23
(II) intel(0): Gamma: 2.20
(II) intel(0): DPMS capabilities: Off; RGB/Color Display
(II) intel(0): First detailed timing is preferred mode
(II) intel(0): redX: 0.626 redY: 0.347 greenX: 0.308 greenY: 0.588
(II) intel(0): blueX: 0.146 blueY: 0.119 whiteX: 0.313 whiteY: 0.329
(II) intel(0): Supported established timings:
(II) intel(0): 720x400@70Hz
(II) intel(0): 640x480@60Hz
(II) intel(0): 640x480@75Hz
(II) intel(0): 800x600@60Hz
(II) intel(0): 800x600@75Hz
(II) intel(0): 1024x768@60Hz
(II) intel(0): 1024x768@75Hz
(II) intel(0): Manufacturer's mask: 0
(II) intel(0): Supported detailed timing:
(II) intel(0): clock: 65.0 MHz Image Size: 304 x 228 mm
(II) intel(0): h_active: 1024 h_sync: 1048 h_sync_end 1184 h_blank_end 1344 h_border: 0
(II) intel(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 806 v_border: 0
(II) intel(0): Serial No: 4R869329L53T
(II) intel(0): Monitor name: Dell E151FPp
(II) intel(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 61 kHz, PixClock max 85 MHz
(II) intel(0): EDID (in hex):
(II) intel(0): 00ffffffffffff0010ac067000000000
(II) intel(0): 060d0103681e17782a7ea5a0584e9625
(II) intel(0): 1e5054a54a0001010101010101010101
(II) intel(0): 01010101010164190040410026301888
(II) intel(0): 360030e410000018000000ff00345238
(II) intel(0): 36393332394c3533540a000000fc0044
(II) intel(0): 656c6c20453135314650700a000000fd
(II) intel(0): 00384c1e3d08000a2020202020200020
(II) intel(0): EDID vendor "DEL", prod id 28678
(II) intel(0): Using EDID range info for horizontal sync
(II) intel(0): Using EDID range info for vertical refresh
(II) intel(0): Printing DDC gathered Modelines:
(II) intel(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) intel(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) intel(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) intel(0): Printing probed modes for output VGA1
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
(II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) intel(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) intel(0): Output VGA1 connected
(II) intel(0): Using exact sizes for initial modes
(II) intel(0): Output VGA1 using initial mode 1024x768
(II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
(II) intel(0): Kernel page flipping support detected, enabling
(**) intel(0): Display dimensions: (300, 230) mm
(**) intel(0): DPI set to (86, 84)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "dri2"
(II) Reloading /usr/lib/xorg/modules/extensions/libdri2.so
(==) Depth 24 pixmap format is 32 bpp
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): [DRI2] Setup complete
(II) intel(0): Allocated new frame buffer 1024x768 stride 4096, tiled
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(II) put_image
(II) get_image
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(==) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder disabled
(II) intel(0): Set up textured video
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: DRI2 Enabled
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_make_current_read
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
(II) AIGLX: Loaded and initialized /usr/lib/dri/i915_dri.so
(II) GLX: Initialized DRI2 GL provider for screen 0
(II) intel(0): Setting screen physical size to 270 x 203
(II) config/udev: Adding input device Power Button (/dev/input/event4)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event4"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/udev: Adding input device Power Button (/dev/input/event3)
(**) Power Button: Device: "/dev/input/event3"
(II) config/udev: Adding input device DELL Dell QuietKey Keyboard (/dev/input/event1)
(**) DELL Dell QuietKey Keyboard: Applying InputClass "evdev keyboard catchall"
(**) DELL Dell QuietKey Keyboard: always reports core events
(**) DELL Dell QuietKey Keyboard: Device: "/dev/input/event1"
(II) DELL Dell QuietKey Keyboard: Found keys
(II) DELL Dell QuietKey Keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "DELL Dell QuietKey Keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device Dell Dell USB Optical Mouse (/dev/input/event2)
(**) Dell Dell USB Optical Mouse: Applying InputClass "evdev pointer catchall"
(**) Dell Dell USB Optical Mouse: always reports core events
(**) Dell Dell USB Optical Mouse: Device: "/dev/input/event2"
(II) Dell Dell USB Optical Mouse: Found 3 mouse buttons
(II) Dell Dell USB Optical Mouse: Found scroll wheel(s)
(II) Dell Dell USB Optical Mouse: Found relative axes
(II) Dell Dell USB Optical Mouse: Found x and y relative axes
(II) Dell Dell USB Optical Mouse: Configuring as mouse
(**) Dell Dell USB Optical Mouse: YAxisMapping: buttons 4 and 5
(**) Dell Dell USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Dell Dell USB Optical Mouse" (type: MOUSE)
(II) Dell Dell USB Optical Mouse: initialized for relative axes.
(II) config/udev: Adding input device Dell Dell USB Optical Mouse (/dev/input/mouse1)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device PC Speaker (/dev/input/event5)
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/event0)
(**) Macintosh mouse button emulation: Applying InputClass "evdev pointer catchall"
(**) Macintosh mouse button emulation: always reports core events
(**) Macintosh mouse button emulation: Device: "/dev/input/event0"
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found relative axes
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
(**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
(**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE)
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/mouse0)
(II) intel(0): Using hsync ranges from config file
(II) intel(0): Using vrefresh ranges from config file
(II) intel(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)Oraz mój plik /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "built-ins"
EndSection
Section "Module"
Load "dri2"
Load "glx"
Load "dbe"
Load "dri"
Load "extmod"
Load "record"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
Option "DRI" "true" # [<bool>]
#Option "ColorKey" # <i>
#Option "VideoKey" # <i>
#Option "FallbackDebug" "true" # [<bool>]
#Option "Tiling" "true" # [<bool>]
#Option "Shadow" "true" # [<bool>]
#Option "SwapbuffersWait" "true" # [<bool>]
#Option "XvMC" "true" # [<bool>]
#Option "XvPreferOverlay" "true" # [<bool>]
#Option "DebugFlushBatches" "true" # [<bool>]
#Option "DebugFlushCaches" "true" # [<bool>]
#Option "DebugWait" "true" # [<bool>]
Identifier "Card0"
Driver "intel"
VendorName "Intel Corporation"
BoardName "82945G/GZ Integrated Graphics Controller"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "enable"
# Option "RENDER" "disable"
EndSection
