[+] ClamAV-daemon, naruszenie ochrony pami
ksysinek
[+] ClamAV-daemon, naruszenie ochrony pamięci
Post autor: ksysinek »
Od pewnego czasu zauważyłem, że ClamAV zaczął ostro zapełniać logi. Oto ich fragment:
Feb 24 19:45:32 poczta amavis[19027]: (19027-06-2) (!!)ClamAV-clamd av-scanner FAILED: run_av error: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: Po\263\261czenie odrzucone) at (eval 86) line 309.
Feb 24 19:45:32 poczta amavis[19027]: (19027-06-2) (!!)WARN: all primary virus scanners failed, considering backups
Feb 24 19:45:42 poczta amavis[19027]: (19027-06-2) (!)killing process [19211] running ClamAV-clamscan (reason: on reading: timed out)
Feb 24 19:45:42 poczta amavis[19027]: (19027-06-2) (!)run_av (ClamAV-clamscan): collect_results - reading aborted: timed out at /usr/sbin/amavisd-new line 3108.
Feb 24 19:45:42 poczta amavis[19027]: (19027-06-2) (!!)ClamAV-clamscan av-scanner FAILED: run_av error: run_av: Exceeded allowed time at (eval 86) line 516.
Feb 24 19:45:42 poczta amavis[19027]: (19027-06-2) (!!)TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: run_av error: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: Po\263\261czenie odrzucone) at (eval 86) line 309.; ClamAV-clamscan av-scanner FAILED: run_av error: run_av: Exceeded allowed time at (eval 86) line 516.
Feb 24 19:45:42 poczta amavis[19027]: (19027-06-2) (!)PRESERVING EVIDENCE in /var/lib/amavis/tmp/amavis-20110224T194525-19027
Zauważyłem, że są też problemy z uruchomieniem clamav-daemon:
/etc/init.d/clamav-daemon restart
Stopping ClamAV daemon: clamd.
Starting ClamAV daemon: clamd LibClamAV Warning: ***********************************************************
LibClamAV Warning: ***  This version of the ClamAV engine is outdated.     ***
LibClamAV Warning: *** DON'T PANIC! Read [URL]http://www.clamav.net/support/faq[/URL] ***
/lib/lsb/init-functions: line 30: 20671 Naruszenie ochrony pamięci  /sbin/start-stop-daemon --start --nicelevel $nice --quiet --exec $exec --oknodo --pidfile "$pidfile" -- "$@"
 failed!
Uaktualniłem ClamAV do wersji 0.97 jednak to nie pomogło. Wciąż przy próbie uruchomienia występuje informacja o naruszeniu ochrony pamięci. Co mogę z tym zrobić? Nie ukrywam, że zależy mi na bezpieczeństwie moich e-maili i wyłączenie skanowania nie wchodzi w rachubę.
Dzisiaj poradziłem sobie z problemem. Rozwiązaniem była odinstalowanie z pomocą apt-get z opcją purge, usunięcie wszystkich katalogów z clamav, uaktualnienie repozytoriów i ponowna instalacja.
