kod conkyego na razie z poradnika Kaki':
background yes
#prawy dolny rog
gap_x 1050
gap_y 50
maximum_width 200
# X font when Xft is disabled, you can pick one with program xfontsel
#font -*-*-*-r-normal--14-*-*-*-c-*-iso8859-2
font -xos4-terminus-*-r-normal-*-12-100-*-*-c-*-iso10646-1
# Use Xft?
use_xft yes
#xftfont Bitstream Vera Sans Mono:size=8
xftfont Terminus:encoding=utf-8:size=9
xftalpha 0.9
update_interval 1.0
total_run_times 0
own_window no
#own_window_type desktop
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_transparent yes
# If own_window_transparent is set to no, you can set the background colour here
own_window_colour hotpink
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
draw_shades yes
draw_outline no
draw_borders no
stippled_borders 8
border_margin 4
border_width 1
default_color white
default_shade_color black
default_outline_color white
alignment top_left
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 2
override_utf8_locale no
use_spacer yes
TEXT
${color #ddaa00}${font Terminus:encoding=iso8859-2:size=15}${time %A}${color}
${font :encoding=iso8859-2:size=9}$alignc${color #ddaa00}${time %e %B %G}
${color slate grey}Kernel:
$alignc${color }$kernel
${color slate grey}UpTime:
$alignc${color }$uptime
${color slate grey}Load:
$alignc${color }$loadavg
${color }${color slate grey}CPU: $color%${color #ddaa00}$cpu$alignr$color$running_processes/ $processes
${color slate grey}${cpugraph 25,200 000000 ffffff}
${font :size=8}${color #ddaa00}${top name 1}$alignr${top cpu 1}
${color lightgrey}${top name 2}$alignr${top cpu 2}
${color lightgrey}${top name 3}$alignr${top cpu 3}
${color lightgrey}${top name 4}$alignr${top cpu 4}
${font :size=9}
${color slate grey}RAM: $color%$memperc ${alignr}$mem
${membar 5,200}
${color slate grey}SWAP: $color%$swapperc ${alignr}$swap
${swapbar 5,200}
${font :size=8}${color #ddaa00}${top_mem name 1}$alignr${top_mem mem 1}
${color lightgrey}${top_mem name 2}$alignr${top_mem mem 2}
${color lightgrey}${top_mem name 3}$alignr${top_mem mem 3}
${color lightgrey}${top_mem name 4}$alignr${top_mem mem 4}
${font :size=9}
${color slate grey}TWARDZIEL: $color$alignr$diskio
${color slate grey}${diskiograph 25,200 000000 ff0000}
${color slate grey} /:${alignr}${color }${fs_free /}
${fs_bar 5,200 /}
${color slate grey}INTERNET:
${color}DL:${color #ddaa00}${downspeed eth0}${color}UP:${color #ddaa00}${upspeed eth0}${color}${alignr}KiB/s
${offset 10}${color}Total: ${color white}${totaldown eth0}
${offset 10}${color}Total: ${color white}${totalup eth0}
${color slate grey}${downspeedgraph eth0 25,200 000000 00ff00}
${color slate grey}${upspeedgraph eth0 25,200 000000 0000ff}
${color #0077ff}@Connections@
$color Outbound: ${tcp_portmon 32768 61000 count}
$color Inbound: ${tcp_portmon 1 32767 count}
${color #0077ff}Outbound Connection ${alignr} Port$color
${tcp_portmon 32768 61000 rip 0} ${alignr} ${tcp_portmon 32768 61000 rservice 0}
${tcp_portmon 32768 61000 rip 1} ${alignr} ${tcp_portmon 32768 61000 rservice 1}
${tcp_portmon 32768 61000 rip 2} ${alignr} ${tcp_portmon 32768 61000 rservice 2}
${tcp_portmon 32768 61000 rip 3} ${alignr} ${tcp_portmon 32768 61000 rservice 3}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 4}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 5}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 6}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 7}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 8}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 9}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 10}
dpkg -l | grep feh
ii feh 1.8-1 imlib2 based image viewer
Prosiłbym o sprawdzenie i napisanie co robię źle. Dziękuję z góry za pomoc.
Jeśli zmienię w conkyrc double_buffer no to w tym momencie conky jest ładnie wyświetlany na pulpicie ale niestety mruga.
Przy punkcie edycji xorg.conf w poradniku Kaki' nie doszukałem się takiego pliku i sekcje modules z wpisem
Load "dbe"
