Instalacja sterowników do karty graficznej ATI, naruszenie ochrony pami
RaFFi
Instalacja sterowników do karty graficznej ATI, naruszenie ochrony pamięci
Post autor: RaFFi »
Zacznę od tego:
# glxinfo
name of display: :0.0
Naruszenie ochrony pamięci
# glxgears
# fglrxinfo
Ciężko mi wytłumaczyć to tak po prostu, bo próbowałem wszystkimi metodami zainstalować jakieś sterowniki, niestety nie udało się.
Wynik:
# lspci
00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge
00:01.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (Internal gfx)
00:04.0 PCI bridge: ATI Technologies Inc Device 7914
00:06.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Port 2)
00:07.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Port 3)
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:05.0 VGA compatible controller: ATI Technologies Inc RS690M [Radeon X1200 Series]
02:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 01)
Chciałbym sobie obejrzeć film, niestety nie mogę bo na pełnym ekranie nie działa. Wiem, że dziwnie wszystko to rozpisałem, ogólnie chodzi o to, że chciałbym aby moja karta graficzna działała jak należy i żeby nie było problemów z odtwarzaniem filmów.
http://debian.linux.pl/threads/19-Driver-ATI-fglrx
Wyskakuje informacja, że niby mam zainstalowane:
# module-assistant a-i fglrx
Updated infos about 1 packages
Getting source for kernel version: 2.6.32-5-amd64
Kernel headers available in /lib/modules/2.6.32-5-amd64/build
apt-get install build-essential
Budowanie drzewa zależności
build-essential jest już w najnowszej wersji.
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 14 nieaktualizowanych.
Done!
unpack
Extracting the package tarball, /usr/src/fglrx.tar.bz2, please wait...
Target package file
/usr/src/fglrx-kernel-2.6.32-5-amd64_10-9-3+2.6.32-30_amd64.deb already exists,
not rebuilding!
(however, you could use the -f switch to ignore it)
dpkg -Ei /usr/src/fglrx-kernel-2.6.32-5-amd64_10-9-3+2.6.32-30_amd64.deb
Wersja 1:10-9-3+2.6.32-30 pakietu fglrx-kernel-2.6.32-5-amd64 jest już zainstalowana.
Jednak po restarcie systemu i wpisaniu:
fglrxinfo
wyświetla się to co podałem powyżej.
P
rzy instalacji otwartych sterowników otrzymuję błąd, że nie obsługują mojej dystrybucji.
steb0
Post autor: steb0 »
RaFFi pisze:Witam.
Zacznę od tego:
Może zacznij od pochwalenia się jaki to system i jak (jakie) instalowałeś sterowniki, link do postu który podałeś jest trochę stary. przyzwoity opis masz na wiki debiana:
http://wiki.debian.org/AtiHowTo oraz http://wiki.debian.org/ATIProprietary
Nie jestem pewny, ale twoją kartę obsługuje chyba xserver-xorg-video-radeon dorzuciłbym jeszcze firmware-linux po dodaniu repozytorium non-free do sources.list
RaFFi
Post autor: RaFFi »
Mój system to Debian Wheezy.
Otwarty sterownik jaki chciałem zainstalować to ati-driver-installer-9-3-x86.x86_64.run.
Xserver-xorg-video-radeon i firmware-linux mam zainstalowane. Próbowałem zainstalować z pomocą tego poradnika sterownik zamknięty, lecz przy:
aticonfig --initial
wyskakuje błąd:
# aticonfig --initial
aticonfig: No supported adapters detected
a przy ręcznej edycji xorg.conf:
Section "Device"
        Identifier "ATI"
        Driver "fglrx"
EndSection
Section "Screen"
        Identifier "Default Screen"
        DefaultDepth 24
EndSection
Gdm3 w ogóle nie uruchamia się. Na wiki Debiana jest napisane:
For Debian Squeeze and later releases, you will need to install proprietary firmware if you have one of the following Radeon-based cards:
Radeon RS690
Moja karta graficzna właśnie jest RS690.
W System > Preferencje pojawiło się ATI Catalyst Control Center, jednak po włączeniu wyskakuje błąd że nie mam sterownika:
http://clip2net.com/clip/m14666/1297961 ... 3-15kb.png
//edit
Problem rozwiązany, dość dziwna metoda ale cały Debian mi się sypał więc zreinstalowałem system, tylko tym razem zainstalowałem netinstall z samym systemem bazowym i sam dociągnąłem xorgi itp. Teraz ładnie wszystko działa ;)
