instalacja
martynka19
instalacja środowiska graficznego
Post autor: martynka19 »
Wgrałam xorga ale polecenie:
dpkg-reconfigure xserver-xorg
Nie działa. A oto co dostaję po wpisaniu startxfce4:
~# startxfce4
/usr/bin/startxfce4: Starting X server
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.32.28-dsa-ia32 i686 Debian
Current Operating System: Linux 2.6.32.2-xxxx-std-ipv4-32 #1 SMP Tue Dec 29 14:40:32 UTC 2009 i686
Kernel command line: root=/dev/ram0 initrd=iscsi/initrd-iscsi.img libusual.bias=ub usb_libusual.bias=ub console=tty0 BOOT_IMAGE=rps/bzImage-2.6-xxxx-std-ipv4-32
Build Date: 12 January 2011  03:44:48AM
xorg-server 2:1.7.7-11 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb  9 14:14:49 2011
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
FATAL: Could not load /lib/modules/2.6.32.2-xxxx-std-ipv4-32/modules.dep: No such file or directory
(EE) [drm] failed to open device
(EE) open /dev/fb0: No such file or directory
SELinux: Disabled on system, not enabling in X server
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Internal error:   Could not resolve keysym XF86TouchpadToggle
> Internal error:   Could not resolve keysym XF86Suspend
> Internal error:   Could not resolve keysym XF86AudioForward
> Internal error:   Could not resolve keysym XF86Battery
> Internal error:   Could not resolve keysym XF86Bluetooth
> Internal error:   Could not resolve keysym XF86WLAN
> Internal error:   Could not resolve keysym XF86Hibernate
Errors from xkbcomp are not fatal to the X server
<stdin>:1:3: error: invalid preprocessing directive #Those
<stdin>:2:3: error: invalid preprocessing directive #or
<stdin>:3:3: error: invalid preprocessing directive #Xft
<stdin>:4:3: error: invalid preprocessing directive #Xft
xrdb:  "Xft.hinting" on line 9 overrides entry on line 6
xrdb:  "Xft.hintstyle" on line 11 overrides entry on line 7
Agent pid 5989
xfdesktop[6011]: starting up
(polkit-gnome-authentication-agent-1:6017): GLib-GObject-WARNING **: cannot register existing type `_PolkitError'
(polkit-gnome-authentication-agent-1:6017): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `GtkOptionMenu::indicator-size' of type `GtkRequisition' from rc file value "0" of type `glong'
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `GtkOptionMenu::indicator-spacing' of type `GtkBorder' from rc file value "0" of type `glong'
Proszę o pomoc, według poradników powinnam skonfigurować serwer xorga, ale polecenie do konfiguracji nie działa.
bolo
Post autor: bolo »
Czy chcesz zainstalować Debiana XFCE 4, czy doinstalować do istniejącego systemu to środowisko graficzne?
Tutaj ogólnie o instalacji Debiana: http://pl.wikibooks.org/wiki/Debian_-_u ... instalacja
Jeśli tylko same XFCE chcesz doinstalować:
aptitude update && aptitude install xfce4
lub poczytaj: http://pl.wikibooks.org/wiki/Debian_-_u ... znego#XFCE
