Mam skonfigurowany plik ssh_config według tej strony: http://rafal.drezek.info/2008/12/12/zda ... z-openssh/
Mój plik wygląda teraz tak:
# RD”, a dodatkowo zmienione linie zaznaczone są pogrubieniem.
#    $OpenBSD: sshd_config,v 1.72 2005/07/25 11:59:40 markus Exp $
# This is the sshd server system-wide configuration file.  See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented.  Uncommented options change a
# default value.
Port 22
Protocol 2
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 768
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
PermitRootLogin no
StrictModes yes
MaxAuthTries 6
RSAAuthentication no
PubkeyAuthentication yes
AuthorizedKeysFile    .ssh/authorized_keys
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Change to yes if you don’t trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
IgnoreUserKnownHosts yes
# Don’t read the user’s ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
PasswordAuthentication no
PermitEmptyPasswords no
# Change to no to disable s/key passwords
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Set this to ‘yes’ to enable support for the deprecated ‘gssapi’ authentication
# mechanism to OpenSSH 3.8p1. The newer ‘gssapi-with-mic’ mechanism is included
# in this release. The use of ‘gssapi’ is deprecated due to the presence of
# potential man-in-the-middle attacks, which ‘gssapi-with-mic’ is not susceptible to.
#GSSAPIEnableMITMAttack no
# Set this to ‘yes’ to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication mechanism.
# Depending on your PAM configuration, this may bypass the setting of
# PasswordAuthentication, PermitEmptyPasswords, and
# “PermitRootLogin without-password”. If you just want the PAM account and
# session checks to run without PAM authentication, then enable this but set
# ChallengeResponseAuthentication=no
UsePAM yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
X11DisplayOffset 10 # RD
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
# no default banner path
#Banner /some/path
# override default of no subsystems
Subsystem    sftp    /usr/lib64/ssh/sftp-server
# This enables accepting locale enviroment variables LC_* LANG, see sshd_config(5).
AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES
AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT
AcceptEnv LC_IDENTIFICATION LC_ALLPrzy próbie restartowania ssh poleceniem:
debian:/home/debian# /etc/init.d/ssh restart
/etc/ssh/ssh_config: line 40: Bad configuration option: PermitRootLogin
/etc/ssh/ssh_config: line 41: Bad configuration option: StrictModes
/etc/ssh/ssh_config: line 42: Bad configuration option: MaxAuthTries
/etc/ssh/ssh_config: line 46: Bad configuration option: AuthorizedKeysFile
/etc/ssh/ssh_config: line 54: Bad configuration option: IgnoreUserKnownHosts
/etc/ssh/ssh_config: line 60: Bad configuration option: PermitEmptyPasswords
/etc/ssh/ssh_config: line 89: Bad configuration option: UsePAM
/etc/ssh/ssh_config: line 93: Bad configuration option: X11Forwarding
/etc/ssh/ssh_config: line 94: Bad configuration option: X11DisplayOffset
/etc/ssh/ssh_config: line 113: Bad configuration option: Subsystem
/etc/ssh/ssh_config: line 116: Bad configuration option: AcceptEnv
/etc/ssh/ssh_config: line 117: Bad configuration option: AcceptEnv
/etc/ssh/ssh_config: line 118: Bad configuration option: AcceptEnv
/etc/ssh/ssh_config: terminating, 13 bad configuration options
