Zainstalowałem system z jądrem w wersji 2.6.26-2-amd64
cat /etc/debian_version
5.0.7
you need to load the kernel first
# DO NOT EDIT THIS FILE
# It is automatically generated by /usr/sbin/update-grub using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
set default=0
set timeout=5
set root=(hd0,1)
search --fs-uuid --set 6e0e3113-eb37-4624-935f-2c995e245ffe
if font /usr/share/grub/ascii.pff ; then
set gfxmode=640x480
insmod gfxterm
insmod vbe
terminal gfxterm
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_hurd ###
### END /etc/grub.d/10_hurd ###
### BEGIN /etc/grub.d/10_linux ###
menuentry "Debian GNU/Linux, linux 2.6.26-2-xen-amd64" {
set root=(hd0,1)
linux /boot/vmlinuz-2.6.26-2-xen-amd64 root=UUID=6e0e3113-eb37-4624-93 5f-2c995e245ffe ro
initrd /boot/initrd.img-2.6.26-2-xen-amd64
menuentry "Debian GNU/Linux, linux 2.6.26-2-xen-amd64 (single-user mode)" {
set root=(hd0,1)
linux /boot/vmlinuz-2.6.26-2-xen-amd64 root=UUID=6e0e3113-eb37-4624-93 5f-2c995e245ffe ro single
menuentry "Debian GNU/Linux, linux 2.6.26-2-amd64" {
set root=(hd0,1)
linux /boot/vmlinuz-2.6.26-2-amd64 root=UUID=6e0e3113-eb37-4624-935f-2 c995e245ffe ro
initrd /boot/initrd.img-2.6.26-2-amd64
menuentry "Debian GNU/Linux, linux 2.6.26-2-amd64 (single-user mode)" {
set root=(hd0,1)
linux /boot/vmlinuz-2.6.26-2-amd64 root=UUID=6e0e3113-eb37-4624-935f-2 c995e245ffe ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file is an example on how to add custom entries
### END /etc/grub.d/40_custom ###
Filesystem Size Used Avail Use% Mounted on
/dev/cciss/c0d0p1 9.3G 899M 8.0G 10% /
tmpfs 1004M 0 1004M 0% /lib/init/rw
udev 10M 692K 9.4M 7% /dev
tmpfs 1004M 0 1004M 0% /dev/shm
config-2.6.26-2-amd64 System.map-2.6.26-2-amd64
config-2.6.26-2-xen-amd64 System.map-2.6.26-2-xen-amd64
grub vmlinuz-2.6.26-2-amd64
initrd.img-2.6.26-2-amd64 vmlinuz-2.6.26-2-xen-amd64
initrd.img-2.6.26-2-xen-amd64 xen-3.2-1-amd64.gz
