Z niewyjaśnionych przyczyn, bo ja nic nie mieszałem, strony przestały mi się wyświetlać
W logu serwera apache jest coś z .htaccess, lecz jak już mówiłem nic nie zmieniałem, ale ten sam błąd na stronie jest wszędzie.
[B]500 Internal Server Error[/B]
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/2.2.16 (Debian) Server at domena.pl Port 80
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php5/apache2/conf.d/gd.ini on line 1 in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20090626+lfs/gd.so' - /usr/lib/php5/20090626+lfs/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: Module 'mcrypt' already loaded in Unknown on line 0
PHP Warning: Module 'ssh2' already loaded in Unknown on line 0
[Sun Dec 19 06:25:29 2010] [notice] Apache/2.2.16 (Debian) PHP/5.3.3-6 with Suhosin-Patch mod_ssl/2.2.16 OpenSSL/0.9.8o configured -- resuming normal operations
[Sun Dec 19 07:31:20 2010] [alert] [client 66.249.66.xx] /var/www/sklep/.htaccess: Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration
[Sun Dec 19 08:13:53 2010] [alert] [client 95.108.245.xxx] /var/www/sklep/.htaccess: Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration
[Sun Dec 19 08:17:39 2010] [alert] [client 80.55.225.xx] /var/www/sklep/.htaccess: Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration
Debian 6.0 oczywiście Lenny
Max
