lighty-enable-mod mysql-vhostDodane:
O to lighttpd.conf
# Debian lighttpd configuration file
############ Options you really have to take care of ####################
## modules to load
# mod_access, mod_accesslog and mod_alias are loaded by default
# all other module should only be loaded if neccesary
# - saves some time
# - saves memory
server.modules = (
"mod_access",
"mod_alias",
"mod_accesslog",
"mod_compress",
"mod_mysql_vhost",
# "mod_rewrite",
# "mod_redirect",
# "mod_evhost",
# "mod_usertrack",
# "mod_rrdtool",
# "mod_webdav",
# "mod_expire",
# "mod_flv_streaming",
# "mod_evasive"
mysql-vhost.db = "vhost_db"
mysql-vhost.user = "lighttpd"
mysql-vhost.pass = "lighttpd_dragon"
mysql-vhost.sock = "/var/run/mysqld/mysqld.sock"
mysql-vhost.sql = "SELECT vhost_document_root as docroot FROM vhost WHERE '?' like vhost_domain_name and vhost_active=1 and vhost_date_deleted=0 limit 1;"
mysql-vhost.hostname = "localhost"
mysql-vhost.port = 3306
## a static document-root, for virtual-hosting take look at the
## server.virtual-* options
server.document-root = "/var/www/"
## where to upload files to, purged daily.
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
## where to send error-messages to
server.errorlog = "/var/log/lighttpd/error.log"
## files to check for if .../ is requested
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm",
"index.lighttpd.html" )
## Use the "Content-Type" extended attribute to obtain mime type if possible
# mimetype.use-xattr = "enable"
#### accesslog module
accesslog.filename = "/var/log/lighttpd/access.log"
## deny access the file-extensions
# ~ is for backupfiles from vi, emacs, joe, ...
# .inc is often used for code includes which should in general not be part
# of the document-root
url.access-deny = ( "~", ".inc" )
# which extensions should not be handle via static-file transfer
# .php, .pl, .fcgi are most often handled by mod_fastcgi or mod_cgi
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
######### Options that are good to be but not neccesary to be changed #######
## Use ipv6 only if available.
include_shell "/usr/share/lighttpd/use-ipv6.pl"
## bind to port (default: 80)
# server.port = 81
## bind to localhost only (default: all interfaces)
## server.bind = "localhost"
## error-handler for status 404
#server.error-handler-404 = "/error-handler.html"
#server.error-handler-404 = "/error-handler.php"
## to help the rc.scripts
server.pid-file = "/var/run/lighttpd.pid"
## Format: <errorfile-prefix><status>.html
## -> ..../status-404.html for 'File not found'
#server.errorfile-prefix = "/var/www/"
## virtual directory listings
dir-listing.encoding = "utf-8"
server.dir-listing = "enable"
## send unhandled HTTP-header headers to error-log
#debug.dump-unknown-headers = "enable"
### only root can use these options
# chroot() to directory (default: no chroot() )
#server.chroot = "/"
## change uid to <uid> (default: don't care)
server.username = "www-data"
server.groupname = "www-data"
#### compress module
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ("text/plain", "text/html", "application/x-javascript", "text/css")
#### url handling modules (rewrite, redirect, access)
# url.rewrite = ( "^/$" => "/server-status" )
# url.redirect = ( "^/wishlist/(.+)" => "http://www.123.org/$1" )
# define a pattern for the host url finding
# %% => % sign
# %0 => domain name + tld
# %1 => tld
# %2 => domain name without tld
# %3 => subdomain 1 name
# %4 => subdomain 2 name
# evhost.path-pattern = "/home/storage/dev/www/%3/htdocs/"
#### expire module
# expire.url = ( "/buggy/" => "access 2 hours", "/asdhas/" => "access plus 1 seconds 2 minutes")
#### rrdtool
# rrdtool.binary = "/usr/bin/rrdtool"
# rrdtool.db-name = "/var/www/lighttpd.rrd"
#### variable usage:
## variable name without "." is auto prefixed by "var." and becomes "var.bar"
#bar = 1
#var.mystring = "foo"
## integer add
#bar += 1
## string concat, with integer cast as string, result: "www.foo1.com"
#server.name = "www." + mystring + var.bar + ".com"
## array merge
#index-file.names = (foo + ".php") + index-file.names
#index-file.names += (foo + ".php")
#### external configuration files
## mimetype mapping
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
## load enabled configuration files,
## read /etc/lighttpd/conf-available/README first
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
#### handle Debian Policy Manual, Section 11.5. urls
## by default allow them only from localhost
## (This must come last due to #445459)
## Note: =~ "127.0.0.1" works with ipv6 enabled, whereas == "127.0.0.1" doesn't
$HTTP["remoteip"] =~ "127.0.0.1" {
alias.url += (
"/doc/" => "/usr/share/doc/",
"/images/" => "/usr/share/images/"
$HTTP["url"] =~ "^/doc/|^/images/" {
dir-listing.activate = "enable"
}A o to zrzut ekranu z bazy danych
vhost_id vhost_active vhost_domain_name vhost_document_root vhost_data_added vhost_date_deleted
1 1 test.pl /home/lighttpd/test/ 2010-12-09 14:20:13 0000-00-00 00:00:00
