mam skonfigurowany sterownik ATI fglrx, wszystko cacy i ładnie, niestety - problem pojawia się przy próbie pogrania w Tibie. Co prawda ilość fpsów przekracza 110 jednakże po zalogowaniu cały interfejs się (za przeproszeniem) pieprzy. Tak to wygląda. Od razu mówie że chce korzystać z linuxowego natywnego klienta.
Oto co wywala wy konsoli:
$ ./Tibia
X Error of failed request: BadDrawable (invalid Pixmap or Window parameter)
Major opcode of failed request: 14 (X_GetGeometry)
Resource id in failed request: 0x0
Serial number of failed request: 7430
Current serial number in output stream: 7430
[center:112de47133]glxinfo[/center:112de47133]
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
GLX_ARB_multisample
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9200 Series DDR Generic
OpenGL version string: 1.3.1091 (X4.3.0-8.28.8)
OpenGL extensions:
GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
GL_S3_s3tc, GL_ARB_occlusion_query, GL_ARB_point_parameters,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_transpose_matrix, GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_ATI_element_array,
GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer,
GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once,
GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object,
GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3,
GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_stencil_wrap, GL_EXT_texgen_reflection, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square,
GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 Slow
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 Slow
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 Slow
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 Slow
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 Slow
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 Slow
0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 Slow
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 Slow
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x30 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
EndSection
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Monitor"
Identifier "Q770"
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 160.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV280 [Radeon 9200 PRO]"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV280 [Radeon 9200 PRO]"
Monitor "Q770"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
usunąłem niepotrzebne dwa znaczniki code na końcu postu
mlyczek
