To konfiguracje mojej sieci.
/etc/network/interfaces
auto lo br0
iface lo inet loopback
auto eth0
iface eth0 inet static
address 83.19.28.220
netmask 255.255.255.248
gateway 83.19.28.217
network 83.19.28.0
broadcast 83.19.28.255
iface eth1 inet manual
iface eth2 inet manual
iface br0 inet static
bridge_ports eth1 eth2
address 10.0.0.1
netmask 255.0.0.0
# Defaults for dhcp initscript
# sourced by /etc/init.d/dhcp
# installed at /etc/default/dhcp3-server by the maintainer scripts
# This is a POSIX shell fragment
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="br0"
ddns-update-style none;
option domain-name-servers 194.204.159.1, 194.204.152.34;
default-lease-time 600;
max-lease-time 7200;
subnet 10.0.0.0 netmask 255.0.0.0 {
option subnet-mask 255.0.0.0;
option routers 10.0.0.1;
option broadcast-address 10.0.0.255;
ignore unknown-clients;
#NR1
host NR1 {
hardware ethernet 00:1E:8C:78:49:C8;
fixed-address 10.0.0.3;
i tam lista hostow
# wlaczenie w jadrze przekierowania
echo 1 > /proc/sys/net/ipv4/ip_forward
# czyszczenie starych regul
iptables -F
iptables -X
iptables -t nat -X
iptables -t nat -F
iptables -t mangle -F
iptables -t mangle -X
# ustawienie domyslnej polityki
iptables -P INPUT ACCEPT
iptables -P FORWARD DROP
#iptables -P FORWARD Accept
iptables -P OUTPUT ACCEPT
# utrzymanie polaczen nawiazanych
iptables -A INPUT -j ACCEPT -m state --state ESTABLISHED,RELATED
iptables -A FORWARD -j ACCEPT -m state --state ESTABLISHED,RELATED
iptables -A OUTPUT -j ACCEPT -m state --state ESTABLISHED,RELATED
iptables -t nat -I PREROUTING -p tcp --dport 3389 -j DNAT --to 10.0.0.3:3389 #Pulpit Zdalny
# udostepniaie internetu w sieci lokalnej
iptables -t nat -A POSTROUTING -s 10.0.0.0/8 -j MASQUERADE
iptables -I FORWARD -s 10.0.0.3 -m mac --mac-source 00:1E:8C:78:49:C8 -j ACCEPT
iptables -I FORWARD -s 10.0.0.4 -m mac --mac-source 70:5A:B6:2C:28:9B -j ACCEPT
iptables -I FORWARD -s 10.1.2.1 -m mac --mac-source 00:03:0D:84:30:6A -j ACCEPT #P102 Olga
iptables -I FORWARD -s 10.1.2.2 -m mac --mac-source 00:03:0D:82:82:41 -j ACCEPT #P102 Basia
iptables -I FORWARD -s 10.1.3.1 -m mac --mac-source 00:26:F2:60:2B:37 -j ACCEPT #P103 Ola i kolezanka
iptables -I FORWARD -s 10.1.4.1 -m mac --mac-source 00:1D:72:01:36:C6 -j ACCEPT #P104 Ada
iptables -I FORWARD -s 10.1.7.1 -m mac --mac-source 00:26:2D:7C:10:6D -j ACCEPT #P107 Zielonka
iptables -I FORWARD -s 10.1.8.1 -m mac --mac-source 00:0E:2E:8C:C7:5D -j ACCEPT #P108 Marta
iptables -I FORWARD -s 10.1.9.1 -m mac --mac-source 00:0B:6A:75:A7:91 -j ACCEPT #P109 Rafal
iptables -I FORWARD -s 10.1.9.2 -m mac --mac-source 00:26:18:5E :D A:55 -j ACCEPT #P109 Angela
iptables -I FORWARD -s 10.1.10.1 -m mac --mac-source 90:E6:BA:A0:EE:79 -j ACCEPT #P110 Jacel
iptables -I FORWARD -s 10.2.2.1 -m mac --mac-source 00:0A:E6:96:8C:65 -j ACCEPT #P202 Blizniaki
iptables -I FORWARD -s 10.2.5.1 -m mac --mac-source 40:61:86:19:64:BA -j ACCEPT #P205 Sandra
iptables -I FORWARD -s 10.2.5.2 -m mac --mac-source E0:CB:4E:34:5F:72 -j ACCEPT #P205 Marta
iptables -I FORWARD -s 10.2.6.1 -m mac --mac-source 00:0C:76:E5:46:15 -j ACCEPT #P206 Jezus
iptables -I FORWARD -s 10.2.7.1 -m mac --mac-source 40:61:86:3E:03:B6 -j ACCEPT #P207 Ogor
iptables -I FORWARD -s 10.2.7.2 -m mac --mac-source 00:03:0D:82:72:C4 -j ACCEPT #P207 Henry
iptables -I FORWARD -s 10.2.8.1 -m mac --mac-source D4:85:64:EB:4E:C5 -j ACCEPT #P208 Maciek
iptables -I FORWARD -s 10.2.10.1 -m mac --mac-source 00:0C:76:6A:A5:68 -j ACCEPT #P210 Ania l2
iptables -I FORWARD -s 10.3.2.1 -m mac --mac-source 00:26:9E:10:47:F3 -j ACCEPT #P302 Kamil
iptables -I FORWARD -s 10.3.5.1 -m mac --mac-source 00:16:36:48:C6:89 -j ACCEPT #P305 Ula
iptables -I FORWARD -s 10.3.5.2 -m mac --mac-source 00:24:1D :D 4:85:18 -j ACCEPT #P305 Martyna
iptables -I FORWARD -s 10.3.6.1 -m mac --mac-source 00:03:0D:86:59:39 -j ACCEPT #P306 Artur
iptables -I FORWARD -s 10.3.6.2 -m mac --mac-source 00:C0:A8 :D 9:F7 :D B -j ACCEPT #P306 Tomek
iptables -I FORWARD -s 10.3.7.1 -m mac --mac-source 00:23:54:54:49:A2 -j ACCEPT #P307 Wojtek
iptables -I FORWARD -s 10.3.9.1 -m mac --mac-source 00:1E:33:C7:4F:51 -j ACCEPT #P306 Alina
iptables -I FORWARD -s 10.3.16.1 -m mac --mac-source 00:1B:38:0F:F6:9A -j ACCEPT #P316 Agnieszka
tc qdisc del root dev br0
tc qdisc add dev br0 root handle 1:0 htb
tc class add dev br0 parent 1:0 classid 1:1 htb rate 10mbit ceil 10mbit
tc class add dev br0 parent 1:1 classid 1:2 htb rate 2mbit ceil 5mbit prio 1 #admin
tc class add dev br0 parent 1:1 classid 1:3 htb rate 80kbit ceil 512kbit prio 3 #P102 Olga
tc class add dev br0 parent 1:1 classid 1:4 htb rate 80kbit ceil 512kbit prio 3 #P102 Basia
tc class add dev br0 parent 1:1 classid 1:5 htb rate 80kbit ceil 512kbit prio 3 #P103 Ola i kolezanka
tc class add dev br0 parent 1:1 classid 1:6 htb rate 80kbit ceil 512kbit prio 3 #P104 Ada
tc class add dev br0 parent 1:1 classid 1:7 htb rate 80kbit ceil 512kbit prio 3 #P107 Zielonka
tc class add dev br0 parent 1:1 classid 1:8 htb rate 80kbit ceil 512kbit prio 3 #P108 Marta
tc class add dev br0 parent 1:1 classid 1:9 htb rate 80kbit ceil 512kbit prio 3 #P109 Rafal
tc class add dev br0 parent 1:1 classid 1:10 htb rate 80kbit ceil 512kbit prio 3 #P109 Angela
tc class add dev br0 parent 1:1 classid 1:11 htb rate 80kbit ceil 512kbit prio 3 #P110 Jacel
tc class add dev br0 parent 1:1 classid 1:12 htb rate 80kbit ceil 512kbit prio 3 #P202 Blizniaki
tc class add dev br0 parent 1:1 classid 1:13 htb rate 80kbit ceil 512kbit prio 3 #P205 Sandra
tc class add dev br0 parent 1:1 classid 1:14 htb rate 80kbit ceil 512kbit prio 3 #P205 Marta
tc class add dev br0 parent 1:1 classid 1:15 htb rate 80kbit ceil 512kbit prio 3 #P206 Jezus
tc class add dev br0 parent 1:1 classid 1:16 htb rate 80kbit ceil 512kbit prio 2 #P207 Ogor
tc class add dev br0 parent 1:1 classid 1:17 htb rate 80kbit ceil 512kbit prio 3 #P207 Henry
tc class add dev br0 parent 1:1 classid 1:18 htb rate 80kbit ceil 512kbit prio 3 #P208 Maciek
tc class add dev br0 parent 1:1 classid 1:19 htb rate 80kbit ceil 512kbit prio 3 #P210 Ania l2
tc class add dev br0 parent 1:1 classid 1:20 htb rate 80kbit ceil 512kbit prio 3 #P302 Kamil
tc class add dev br0 parent 1:1 classid 1:21 htb rate 80kbit ceil 512kbit prio 3 #P305 Ula
tc class add dev br0 parent 1:1 classid 1:22 htb rate 80kbit ceil 512kbit prio 3 #P305 Martyna
tc class add dev br0 parent 1:1 classid 1:23 htb rate 80kbit ceil 512kbit prio 3 #P306 Artur
tc class add dev br0 parent 1:1 classid 1:24 htb rate 80kbit ceil 512kbit prio 3 #P306 Tomek
tc class add dev br0 parent 1:1 classid 1:25 htb rate 80kbit ceil 512kbit prio 3 #P307 Wojtek
tc class add dev br0 parent 1:1 classid 1:26 htb rate 80kbit ceil 512kbit prio 3 #P306 Alina
tc class add dev br0 parent 1:1 classid 1:27 htb rate 80kbit ceil 512kbit prio 3 #P316 Agnieszka
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.0.0.3 flowid 1:2 #admin
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.2.1 flowid 1:3 #P102 Olga
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.2.2 flowid 1:4 #P102 Basia
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.3.1 flowid 1:5 #P103 Ola i kolezanka
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.4.1 flowid 1:6 #P104 Ada
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.7.1 flowid 1:7 #P107 Zielonka
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.8.1 flowid 1:8 #P108 Marta
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.9.1 flowid 1:9 #P109 Rafal
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.9.2 flowid 1:10 #P109 Angela
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.1.10.1 flowid 1:11 #P110 Jacel
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.2.1 flowid 1:12 #P202 Blizniaki
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.5.1 flowid 1:13 #P205 Sandra
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.5.2 flowid 1:14 #P205 Marta
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.6.1 flowid 1:15 #P206 Jezus
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.7.1 flowid 1:16 #P207 Ogor
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.7.2 flowid 1:17 #P207 Henry
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.8.1 flowid 1:18 #P208 Maciek
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.2.10.1 flowid 1:19 #P210 Ania l2
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.2.1 flowid 1:20 #P302 Kamil
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.5.1 flowid 1:21 #P305 Ula
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.5.2 flowid 1:22 #P305 Martyna
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.6.1 flowid 1:23 #P306 Artur
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.6.2 flowid 1:24 #P306 Tomek
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.7.1 flowid 1:25 #P307 Wojtek
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.9.1 flowid 1:26 #P306 Alina
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.3.16.1 flowid 1:27 #P316 Agnieszka
pasmo 4MB rodzielam następująco: dla mnie (#Admin) na 2MB i 25 hostom po 80KB.
Kupiłem sobie laptopa (10.0.0.4) i chcę aby jemu przydzilane zostało z mojej kolejki, czyli np.
(jak ściągam coś na stacjonarnym komputerze 1MB to na laptopie mi zostaje 1MB).
Zrobiłem w ten sposób niewiem czy dobrze ale jakoś działa.
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.0.0.3 flowid 1:2 #Stacjonara
tc filter add dev br0 protocol ip parent 1:0 u32 match ip dst 10.0.0.4 flowid 1:2 #Laptop
Jeśli to jest źle zrobione to co mam zmienić żeby było dobrze?
