Unable to migrate to dependency-based boot system │
│ Tests have determined that problems in the boot system exist which prevent migration to dependency-based boot │
│ sequencing: │
│ insserv: warning: script 'K20firewall' missing LSB tags and overrides, insserv: warning: script 'firewall' missing LSB │
│ tags and overrides, insserv: warning: script 'UPGRADE.MONITOR' missing LSB tags and overrides, │
│ If the reported problem is a local modification, it needs to be fixed manually. If it's a bug in the package, it should │
│ be reported to the BTS and fixed in the package. See http://wiki.debian.org/LSBInitScripts/DependencyBasedBoot for more │
│ information about how to fix the problems preventing migration. │
│ To reattempt the migration process after the problems have been fixed, run "dpkg-reconfigure sysv-rc".
davidoss@debian-sid-2010:~$ cat /etc/init.d/firewall
#!/bin/sh
## DESKTOP FIREWALL by grzesiek ;)
start () {
iptables -F
iptables -X
iptables -F -t nat
iptables -X -t nat
iptables -P FORWARD DROP
iptables -P INPUT DROP
iptables -P OUTPUT DROP
# INPUT
iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A INPUT -i !eth0 -s 192.168.0.0/16 -p udp -m multiport --dport 137,138 -m state --state NEW -j ACCEPT
iptables -A INPUT -i !eth0 -s 192.168.0.0/16 -p tcp -m multiport --dport 139,445 -m state --state NEW -j ACCEPT
iptables -A INPUT -p tcp --dport 22 -m state --state NEW -j ACCEPT
iptables -A INPUT -i lo -m state --state NEW -j ACCEPT
iptables -A INPUT -p icmp -m state --state NEW -j ACCEPT
iptables -A INPUT -j REJECT --reject-with icmp-host-prohibited
# OUTPUT
iptables -A OUTPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A OUTPUT -p tcp --sport 1024:65535 -m state --state NEW -j ACCEPT
iptables -A OUTPUT -p udp --sport 1024:65535 -m state --state NEW -j ACCEPT
iptables -A OUTPUT -p icmp -m state --state NEW -j ACCEPT
iptables -A OUTPUT -j REJECT --reject-with icmp-host-prohibited
# FORWARD
iptables -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A FORWARD -s 192.168.0.0/255.255.0.0 -p tcp --sport 1024:65535 -m state --state NEW -j ACCEPT
iptables -A FORWARD -s 192.168.0.0/255.255.0.0 -p udp --sport 1024:65535 -m state --state NEW -j ACCEPT
iptables -A FORWARD -p icmp -m state --state NEW -j ACCEPT
iptables -A FORWARD -j REJECT --reject-with icmp-host-prohibited
# NAT system
iptables -t nat -A POSTROUTING -s 192.168.0.0/255.255.0.0 -d 0/0 -j MASQUERADE
echo "Configuration iptables on... (more information use option: show)"
exit 0
stop () {
iptables -F
iptables -X
iptables -F -t nat
iptables -X -t nat
iptables -P FORWARD ACCEPT
iptables -P INPUT ACCEPT
iptables -P OUTPUT ACCEPT
echo "Configuration iptables off (except NAT system for 192.168.0.0/16 !)... (more information use option: show)"
exit 0
show () {
echo "\n [ Table: filter ]\n"
iptables -L -nv --line-numbers -t filter
echo "\n [ Table: nat ]\n"
iptables -L -nv --line-numbers -t nat
echo "\n"
exit 0
#main:
case "$1" in
start)
start ;;
stop)
stop ;;
show)
show ;;
echo $" Składnia: $0 {stary, stop, show}"
echo "@@@ Firewall by grzesiek ;) @@@"
exit 1
esac
davidoss@debian-sid-2010:~$ cat /etc/init.d/UPGRADE.MONITOR
#!/bin/bash
logfile="/var/log/upgrades.log"
lista() {
apt-get dist-upgrade -s | grep 'Inst'
apt-get update 2>&1 >/dev/null
if [ -z "$(lista)" ]; then
echo "Brak" > $logfile
else
echo "$(lista | sed '/^Inst/!d;{s/Inst\ //;s/\ .*//}')" > $logfile
fi
