xorg.conf - http://pastebin.com/x5FfAnsL
(podejrzany z logów X-ów - to jest domyślny konfig) i na nim działa z oszałamiającymi ustawieniami - 640x480.
Polecenie:
X -scanpci
Probing for PCI devices (Bus :D evice:Function)
(0:3:0) unknown card (0x108e/0x1647) using a Broadcom Corporation NetXtreme BCM5703 Gigabit Ethernet
lspci
0000:00:03.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5703 Gigabit Ethernet
0001:00:02.0 PCI bridge: Intel Corporation 21154 PCI-to-PCI Bridge
0001:00:04.0 SCSI storage controller: LSI Logic / Symbios Logic 53c1010 66MHz Ultra3 SCSI Adapter (rev 01)
0001:00:04.1 SCSI storage controller: LSI Logic / Symbios Logic 53c1010 66MHz Ultra3 SCSI Adapter (rev 01)
0001:01:00.0 Ethernet controller: Sun Microsystems Computer Corp. Cassini 10/100/1000 (rev 20)
0002:00:04.0 PCI bridge: Texas Instruments PCI2250 PCI-to-PCI Bridge (rev 02)
0002:00:06.0 Non-VGA unclassified device: ALi Corporation M7101 Power Management Controller [PMU]
0002:00:07.0 ISA bridge: ALi Corporation M1533/M1535/M1543 PCI to ISA Bridge [Aladdin IV/V/V+]
0002:00:08.0 Multimedia audio controller: ALi Corporation M5451 PCI AC-Link Controller Audio Device (rev 02)
0002:00:0a.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
0002:00:0b.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
0002:00:0d.0 IDE interface: ALi Corporation M5229 IDE (rev c4)
0002:01:08.0 USB Controller: NEC Corporation USB (rev 43)
0002:01:08.1 USB Controller: NEC Corporation USB (rev 43)
0002:01:08.2 USB Controller: NEC Corporation USB 2.0 (rev 04)
0002:01:0b.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
0003:00:02.0 VGA compatible controller: ATI Technologies Inc Radeon RV100 QY [Radeon 7000/VE]
strace
X -scanpci
open("/proc/bus/pci/01/0e.0", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/proc/bus/pci/0000:01", 0xffebf110) = -1 ENOENT (No such file or directory)
open("/proc/bus/pci/01/0f.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/proc/bus/pci/01/10.0", O_RDONLY) = -1 ENOENT (No such file or directory)
X -scanpci
lspci
pci:bus:dev:func
Efekt:
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny2)
Current Operating System: Linux hermes 2.6.26-2-sparc64 #1 Fri Sep 17 00:51:46 UTC 2010 sparc64
Build Date: 11 June 2009 10:44:40AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 11 02:23:34 2010
Backtrace:
Fatal server error:
Caught signal 11. Server aborting
Aborted
I nadal nie potrafi, straciłem już wszelkie siły do gada (zastąpiłem go porządnym intelem i 1920x1020 poszło z palucha). Jedyne co udało mi się wygrzebać to działający konfig. Działa ale i tak nie potrafiłem wydusić więcej niż 1024x768.
Dla porządku podaję działający konfig:
Section "Device"
Identifier "VESA"
Driver "fbdev"
Option "UseFBDdev" "true"
Option "fbdev" "/dev/fb0"
BusID "00:02.0"
VendorName "Unknown"
BoardName "Unknown"
EndSection
#Section "Monitor"
# Identifier "Configured Monitor"
#EndSection
Section "Monitor"
Identifier "Monitor0"
HorizSync 31.5 - 64.3
VertRefresh 40.0 - 150.0
EndSection
Section "Screen"
Identifier "Screen0"
Device "VESA"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 8
Modes "1024x768" "832x624" "800x600" "640x480"
EndSubSection
Viewport 0 0
Depth 16
#"800x600" "640x400"
EndSubSection
Viewport 0 0
Depth 24
Modes "1280x1024" "1024x768"
# "832x624" "800x600"
EndSubSection
EndSection
#Section "Screen"
# Identifier "Screen0"
# Device "VESA"
# Monitor "Monitor0"
http://forums.gentoo.org/viewtopic-p-62 ... 81b74dd64f
