Odinstalowanie Virtualadmina
murgal
Post autor: murgal »
Zainstalowałem virtualadmina z: http://www.webmin.com/vinstall.html
Teraz chcę go odinstalować, jak mogę to zrobić?
murgal
Virtualadmin
Gdy w virtualadminie chcę stworzyć nowy serwer wirtualny, wyświetla mi:
Failed to create virtual server :
Mailman cannot be enabled unless the administration list mailman has been created.
This can be done in the [url=https://192.168.1.5:10000/virtualmin-mailman/index.cgi]Mailman plugin module[/URL].
Otwieram mailman, próbuję utworzyć nową listę:
Failed to create mailing list :
 List creation command failed :
Create a new, unpopulated mailing list.
Usage: /var/lib/mailman/bin/newlist
[options]
[listname
[listadmin-addr [admin-password]]]
Options:      -l language     --language=language
Make the list's preferred language `language', which must be a two
letter language code.      -u urlhost     --urlhost=urlhost
Gives the list's web interface host name.
 -e emailhost     --emailhost=emailhost         Gives the list's email domain name.
 -q/--quiet         Normally the administrator is notified by email (after a prompt) that
 their list has been created.  This option suppresses the prompt and
notification.      -h/--help
Print this help text and exit.  You can specify as many of the arguments as you want on the command line: you will be prompted for the missing ones.  Every Mailman list has two parameters which define the default host name for outgoing email, and the default URL for all web interfaces.  When you configured Mailman, certain defaults were calculated, but if you are running multiple virtual Mailman sites, then the defaults may not be appropriate for the list you are creating.
You also specify the domain to create your new list in by typing the command like so:
newlist --urlhost=www.mydom.ain mylist  where `[url]www.mydom.ain[/url]' should be the base hostname for the URL to this virtual hosts's lists.
E.g. with this setting people will view the general list overviews at [url]http://www.mydom.ain/mailman/listinfo[/url].  Also, [url]www.mydom.ain[/url] should be a key in the VIRTUAL_HOSTS mapping in mm_cfg.py/Defaults.py if the email hostname to be automatically determined.  If you want the email hostname to be different from the one looked up by the VIRTUAL_HOSTS or if urlhost is not registered in VIRTUAL_HOSTS, you can specify `emailhost' like so:
newlist --urlhost=www.mydom.ain --emailhost=mydom.ain mylist  where `mydom.ain' is the mail domain name. If you don't specify emailhost but urlhost is not in the virtual host list, then mm_cfg.DEFAULT_EMAIL_HOST will be used for the email interface.  For backward compatibility, you can also specify the domain to create your new list in by spelling the listname like so:
[email]mylist@www.mydom.ain[/email]
where [url]www.mydom.ain[/url] is used for `urlhost' but it will also be used for `emailhost' if it is not found in the virtual host table. Note that '--urlhost' and '--emailhost' have precedence to this notation.  If you spell the list name as just `mylist', then the email hostname will be taken from DEFAULT_EMAIL_HOST and the url will be taken from DEFAULT_URL (as defined in your Defaults.py file or overridden by settings in mm_cfg.py).
Note that listnames are forced to lowercase.
The list admin address need to be a fully-qualified address, like [email]owner@example.com[/email], not just owner.
The list password cannot be empty
O co chodzi?
murgal, problem to dopiero zaczniesz mieć jak się nie uspokoisz z tym bezmyślnym zakładaniem podobnych tematów.
To w końcu co chcesz zrobić, odinstalować czy dalej konfigurować? W taki sposób to nie uzyskasz pomocy. Zdecyduj się na coś bo robisz bałagan i w swoim systemie i na forum.
Przejrzyj dział dla początkujących i ,,Debian Reference''. Większość odpowiedzi tam znajdziesz.
http://debian.linux.pl/threads/5676-Prz ... -napiszesz!
http://www.debian.org/doc/manuals/reference/
murgal
Chce go skonfigurować, szukałem odpowiedzi na ten problem, ale niestety nie znalazłem. Dlatego też pytam.
