Przedstawiam mój plik konfiguracji compiza. I nie ma tam takiej opcji zaznaczonej w compize żeby powodowała problem. No i teraz w ogóle nie wiem gdzie szukać rozwiązania?
[firepaint]
s0_fire_color = #ff3305ff
[place]
s0_mode = 0
[rotate]
as_edge_flip_window = false
as_rotate_left_key = Disabled
as_rotate_right_key = Disabled
as_rotate_left_window_key = Disabled
as_rotate_right_window_key = Disabled
as_rotate_to_1_key = <Control>F1
as_rotate_to_2_key = <Control>F2
as_rotate_to_3_key = <Control>F3
as_rotate_to_4_key = <Control>F4
s0_zoom = 0,557700
[wall]
as_outline_color = #333333d9
as_background_gradient_base_color = #cccce6d9
as_background_gradient_highlight_color = #f3f3ffd9
as_background_gradient_shadow_color = #f3f3ffd9
as_thumb_gradient_base_color = #33333359
as_thumb_gradient_highlight_color = #3f3f3f3f
as_thumb_highlight_gradient_base_color = #fffffff3
as_thumb_highlight_gradient_shadow_color = #dfdfdfa6
as_arrow_base_color = #e6e6e6d9
as_arrow_shadow_color = #dcdcdcd9
as_left_key = Disabled
as_right_key = Disabled
as_up_key = Disabled
as_down_key = Disabled
as_left_window_key = Disabled
as_right_window_key = Disabled
as_up_window_key = Disabled
as_down_window_key = Disabled
s0_edgeflip_move = false
[atlantis]
s0_creature_color = #ffffffff;#60a0ffff;#ff7000ff;#ffff00ff;#ff0000ff;
s0_plant_color = #00d010ff;#00d010ff;#8090ff0c;
s0_ground_color = #855e00ff
s0_water_color = #08093008
[move]
as_initiate_key = Disabled
[expo]
as_expo_key = <Control>F8
as_ground_color1 = #b3b3b3cc
as_ground_color2 = #b3b3b300
[resizeinfo]
as_gradient_1 = #cccce6cc
as_gradient_2 = #f3f3f3cc
as_gradient_3 = #d9d9d9cc
[vpswitch]
as_switch_to_1_key = <Control>F1
as_switch_to_2_key = <Control>F2
as_switch_to_3_key = <Control>F3
as_switch_to_4_key = <Control>F4
[core]
as_active_plugins = core;ccp;move;resize;place;decoration;firepaint;regex;imgjpeg;session;kdecompat;ring;wobbly;cube;rotate;animation;switcher;expo;
as_click_to_focus = false
as_unmaximize_window_key = Disabled
as_minimize_window_key = Disabled
as_maximize_window_key = Disabled
as_window_menu_key = <Alt>F3
as_toggle_window_shaded_key = Disabled
s0_hsize = 4
[showmouse]
s0_color = #ffdf3fff
[animationaddon]
s0_beam_color = #7f7f7fff
[resize]
as_mode = 0
[thumbnail]
s0_thumb_color = #0000007f
[scale]
as_initiate_key = <Control>F9
as_initiate_all_key = <Control>F10
[commands]
as_command11 = xkill
as_run_command11_key = <Control><Alt>
[snap]
s0_snap_type = 0;1;
s0_edges_categories =
s0_attraction_distance = 30
[shift]
s0_ground_color1 = #b3b3b3cc
s0_ground_color2 = #b3b3b300
[cube]
s0_images = /home/peer/Obrazy/Tapety HD/Tamino___wallpapers_by_19_10.jpg;/usr/share/images/desktop-base/debian-blueish-wallpaper-640x480.png;
s0_adjust_image = true
s0_skydome = true
s0_skydome_image = /home/peer/Obrazy/Tapety HD/Moodflow Wallpapers Collection 16.jpg
s0_active_opacity = 45,250000
[cubeaddon]
s0_ground_color2 = #b3b3b300Kod: Zaznacz cały
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 256.53 (buildmeister@builder97.nvidia.com) Fri Aug 27 20:55:22 PDT 2010
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
#ModulePath "/usr/lib/xorg/modules"
ModulePath "/usr/lib64/xorg/modules/extensions/nvidia"
ModulePath "/usr/lib64/xorg/modules/drivers"
ModulePath "/usr/lib64/xorg/modules"
FontPath "built-ins"
EndSection
Section "Module"
Load "glx"
Load "extmod"
# Load "dri"
Load "dbe"
Load "dri2"
Load "record"
#Load "GLcore"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
Option "XAANoOffscreenPixmaps" "true"
Option "AllowGLXWithComposite" "true"
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "Rotate" # [<str>]
#Option "VideoKey" # <i>
#Option "FlatPanel" # [<bool>]
#Option "FPDither" # [<bool>]
#Option "CrtcNumber" # <i>
#Option "FPScale" # [<bool>]
#Option "FPTweak" # <i>
#Option "DualHead" # [<bool>]
Identifier "Card0"
Driver "nvidia"
VendorName "nVidia Corporation"
BoardName "G73 [GeForce 7600 GT]"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
Option "Coolbits" "1"
Option "AddARGBGLXVisuals" "true"
Option "TripleBuffer" "false"
### Available Driver options are:-
SubSection "Display"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "enable"
EndSection
