X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.32-5-686 i686 Debian
Current Operating System: Linux debian 2.6.32-5-686 #1 SMP Sat Sep 18 02:14:45 UTC 2010 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=2a25e576-150e-4eaa-8cbf-b8ea133bfc9c ro quiet
Build Date: 20 September 2010 03:40:46PM
xorg-server 2:1.7.7-7 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 14 11:02:13 2010
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
(Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
(==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
(II) The server relies on udev to provide the list of input devices.
(II) Loader magic: 0x81ea020
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:2a12:103c:30d8 Intel Corporation Mobile GME965/GLE960 Integrated Graphics Controller rev 12, Mem @ 0xe4400000/1048576, 0xd0000000/268435456, I/O @ 0x00004000/8
(--) PCI: (0:0:2:1) 8086:2a13:103c:30d8 Intel Corporation Mobile GME965/GLE960 Integrated Graphics Controller rev 12, Mem @ 0xe4500000/1048576
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched intel as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.9.1
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.3.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.4.2
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, Clarkdale, Arrandale
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(II) Primary Device is: PCI 00@00:02:0
(WW) Falling back to old probe method for vesa
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 0.0.2
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
(==) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 965GME/GLE
(--) intel(0): Chipset: "965GME/GLE"
(II) intel(0): Output VGA1 has no monitor section
(II) intel(0): Output LVDS1 has no monitor section
(II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
(II) intel(0): Output TV1 has no monitor section
(II) intel(0): EDID for output VGA1
(II) intel(0): EDID for output LVDS1
(II) intel(0): Manufacturer: SEC Model: 4c45 Serial#: 0
(II) intel(0): Year: 2007 Week: 0
(II) intel(0): EDID Version: 1.3
(II) intel(0): Digital Display Input
(II) intel(0): Max Image Size [cm]: horiz.: 33 vert.: 21
(II) intel(0): Gamma: 2.20
(II) intel(0): No DPMS capabilities specified
(II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) intel(0): First detailed timing is preferred mode
(II) intel(0): redX: 0.580 redY: 0.340 greenX: 0.310 greenY: 0.550
(II) intel(0): blueX: 0.155 blueY: 0.155 whiteX: 0.313 whiteY: 0.329
(II) intel(0): Manufacturer's mask: 0
(II) intel(0): Supported detailed timing:
(II) intel(0): clock: 69.3 MHz Image Size: 331 x 207 mm
(II) intel(0): h_active: 1280 h_sync: 1296 h_sync_end 1344 h_blank_end 1416 h_border: 0
(II) intel(0): v_active: 800 v_sync: 801 v_sync_end 804 v_blanking: 816 v_border: 0
(II) intel(0): Unknown vendor-specific block f
(II) intel(0): SAMSUNG
(II) intel(0): LTN154X3-L01
(II) intel(0): EDID (in hex):
(II) intel(0): 00ffffffffffff004ca3454c00000000
(II) intel(0): 00110103802115780a87f594574f8c27
(II) intel(0): 27505400000001010101010101010101
(II) intel(0): 010101010101121b0088502010301030
(II) intel(0): 13004bcf100000190000000f00000000
(II) intel(0): 00000000002387026404000000fe0053
(II) intel(0): 414d53554e470a2020202020000000fe
(II) intel(0): 004c544e31353458332d4c30310a001c
(II) intel(0): Not using default mode "320x175" (doublescan mode not supported)
(II) intel(0): Not using default mode "320x200" (doublescan mode not supported)
(II) intel(0): Not using default mode "360x200" (doublescan mode not supported)
(II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
(II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
(II) intel(0): Not using default mode "1024x768" (interlace mode not supported)
(II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
(II) intel(0): Not using default mode "1152x864" (exceeds panel dimensions)
(II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
(II) intel(0): Not using default mode "1280x960" (exceeds panel dimensions)
(II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
(II) intel(0): Not using default mode "1280x1024" (exceeds panel dimensions)
(II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
(II) intel(0): Not using default mode "1600x1200" (exceeds panel dimensions)
(II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
(II) intel(0): Not using default mode "1792x1344" (exceeds panel dimensions)
(II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
(II) intel(0): Not using default mode "1856x1392" (exceeds panel dimensions)
(II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
(II) intel(0): Not using default mode "1920x1440" (exceeds panel dimensions)
(II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
(II) intel(0): Not using default mode "416x312" (doublescan mode not supported)
(II) intel(0): Not using default mode "1360x768" (monitor doesn't support reduced blanking)
(II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
(II) intel(0): Not using default mode "1360x768" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1400x1050" (exceeds panel dimensions)
(II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
(II) intel(0): Not using default mode "1440x900" (exceeds panel dimensions)
(II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
(II) intel(0): Not using default mode "1600x1024" (exceeds panel dimensions)
(II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
(II) intel(0): Not using default mode "1680x1050" (monitor doesn't support reduced blanking)
(II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
(II) intel(0): Not using default mode "1680x1050" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1920x1080" (monitor doesn't support reduced blanking)
(II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
(II) intel(0): Not using default mode "1920x1200" (monitor doesn't support reduced blanking)
(II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
(II) intel(0): Not using default mode "2048x1536" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
(II) intel(0): Printing probed modes for output LVDS1
(II) intel(0): Modeline "1280x800"x60.0 69.30 1280 1296 1344 1416 800 801 804 816 -hsync -vsync (48.9 kHz)
(II) intel(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) intel(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) intel(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) intel(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
(II) intel(0): EDID for output TV1
(II) intel(0): Output VGA1 disconnected
(II) intel(0): Output LVDS1 connected
(II) intel(0): Output TV1 disconnected
(II) intel(0): Using exact sizes for initial modes
(II) intel(0): Output LVDS1 using initial mode 1280x800
(II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) UnloadModule: "vesa"
(II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(==) Depth 24 pixmap format is 32 bpp
(II) intel(0): [DRI2] Setup complete
(**) intel(0): Framebuffer compression disabled
(**) intel(0): Tiling enabled
(**) intel(0): SwapBuffers wait enabled
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): Attempting memory allocation with tiled buffers.
(II) intel(0): Tiled allocation successful.
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): No memory allocations
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(==) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder disabled
(II) intel(0): Set up textured video
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: DRI2 Enabled
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_make_current_read
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
(II) AIGLX: Loaded and initialized /usr/lib/dri/i965_dri.so
(II) GLX: Initialized DRI2 GL provider for screen 0
(II) intel(0): Setting screen physical size to 338 x 211
(II) config/udev: Adding input device Power Button (/dev/input/event3)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event3"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/udev: Adding input device Video Bus (/dev/input/event6)
(**) Video Bus: Applying InputClass "evdev keyboard catchall"
(**) Video Bus: always reports core events
(**) Video Bus: Device: "/dev/input/event6"
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
(II) config/udev: Adding input device Lid Switch (/dev/input/event2)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Sleep Button (/dev/input/event1)
(**) Sleep Button: Applying InputClass "evdev keyboard catchall"
(**) Sleep Button: always reports core events
(**) Sleep Button: Device: "/dev/input/event1"
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
(II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event7)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
(**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
(**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
(**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 1.2.2
(II) Synaptics touchpad driver version 1.2.2
(**) Option "Device" "/dev/input/event5"
(II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
(II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
(II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
(II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
(II) SynPS/2 Synaptics TouchPad: buttons: left right middle double triple
(--) SynPS/2 Synaptics TouchPad: touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
(**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
(**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 0
(**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
(**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
(II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
SynPS/2 Synaptics TouchPad no synaptics event device found
(**) Option "Device" "/dev/input/mouse0"
Query no Synaptics: 6003C8
(--) SynPS/2 Synaptics TouchPad: no supported touchpad found
(EE) SynPS/2 Synaptics TouchPad Unable to query/initialize Synaptics hardware.
(EE) PreInit failed for input device "SynPS/2 Synaptics TouchPad"
(II) UnloadModule: "synaptics"
(II) config/udev: Adding input device PC Speaker (/dev/input/event4)
(II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event8)
(**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
(**) ACPI Virtual Keyboard Device: always reports core events
(**) ACPI Virtual Keyboard Device: Device: "/dev/input/event8"
(II) ACPI Virtual Keyboard Device: Found keys
(II) ACPI Virtual Keyboard Device: Configuring as keyboard
(II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD)
