vnc - brak czcionek
Van Pytel
vnc - brak czcionek
Post autor: Van Pytel »
Zainstalowałem sobie xfce4 potem vnc i chciałem go uruchomić to otrzymałem błąd:
 vncserver :1
VNCÂŽ Server Enterprise Edition E4.5.4 (r41964) - built Jun 14 2010 09:46:36
Copyright (C) 2002-2010 RealVNC Ltd.
VNC is a registered trademark of RealVNC Ltd. in the U.S. and in other countries.
See http://www.realvnc.com for information on VNC.
VNCÂŽ Server Enterprise Edition E4.5.4 (r41964) (Virtual-Mode) - built Jun 14 2010 09:56:23
Underlying X server release 60900000, The X.Org Foundation
Wed Sep 29 20:55:25 2010
 vncext:      VNC extension running!
 vncext:      created VNC Server for screen 0
 TcpListener: listening on IPv6, port 5901
 TcpListener: listening on IPv6, port 5801
error opening security policy file /usr/X11R6/lib/X11/xserver/SecurityPolicy
Could not init font path element /usr/X11R6/lib/X11/fonts/misc/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/TTF/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/Type1/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/75dpi/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/, removing from list!
Fatal server error:
could not open default font 'fixed'
Jak mogę ewentualnie zainstalować te czcionki, lub usunąć je aby nie ładowały się?
W katalogu /usr/X11R6/lib/X11/fonts/ mam takie:
100dpi  75dpi  misc  Type1  X11
i ich nie czyta :(
Przedstawiam też listę czcionek jakie mam:
 dpkg -l | grep font
ii  console-data                         2:1.10-5                             keymaps, fonts, charset maps, fallback tables for console-tools
ii  console-setup                        1.56                                 console font and keymap setup program
ii  console-terminus                     4.30-2                               Fixed-width fonts for fast reading on the Linux console
ii  console-tools                        1:0.2.3dbs-69                        Linux console and font utilities
ii  defoma                               0.11.11                              Debian Font Manager -- automatic font configuration framework
ii  fontconfig                           2.8.0-2.1                            generic font configuration library - support binaries
ii  fontconfig-config                    2.8.0-2.1                            generic font configuration library - configuration
ii  gsfonts                              1:8.11+urwcyr1.0.7~pre44-4.2         Fonts for the Ghostscript interpreter(s)
ii  gucharmap                            1:2.30.3-1                           Unicode character picker and font browser
ii  libconsole                           1:0.2.3dbs-69                        Shared libraries for Linux console and font manipulation
ii  libfontconfig1                       2.8.0-2.1                            generic font configuration library - runtime
ii  libfontenc1                          1:1.0.5-2                            X11 font encoding library
ii  libfreetype6                         2.4.2-1                              FreeType 2 font engine, shared library files
ii  libt1-5                              5.1.2-3                              Type 1 font rasterizer library - runtime
ii  libxfont1                            1:1.4.1-2                            X11 font rasterisation library
ii  libxft2                              2.1.14-2                             FreeType-based font drawing library for X
ii  ttf-dejavu-core                      2.31-1                               Vera font family derivate with additional characters
ii  ttf-dejavu-extra                     2.31-1                               Vera font family derivate with additional characters
ii  ttf-lyx                              1.6.7-1                              TrueType versions of some TeX fonts
ii  x11-xfs-utils                        7.4+1                                X font server utilities
rc  xfonts-100dpi                        1:1.0.1                              100 dpi fonts for X
rc  xfonts-75dpi                         1:1.0.1                              75 dpi fonts for X
ii  xfonts-base                          1:1.0.1                              standard fonts for X
ii  xfonts-encodings                     1:1.0.3-1                            Encodings for X.Org fonts
rc  xfonts-scalable                      1:1.0.1-1                            scalable fonts for X
ii  xfonts-utils                         1:7.5+2                              X Window System font utility programs
Nie chcę zmieniać na inne vnc, wolę realny vnc, dlatego pytam was o radę.
Dziękuję za odpowiedź.
Rozwiązane:
Musiałem zrobić reczną ścieżke:
/usr/X11R6/lib/X11/ <-- a potem dowiązać fonty z innego katalogu.
