Proszę o pomoc przy konfiguracji ustawień pliku xorg.conf.
Niedawno zauważyłem, że nie mam renderingu bezpośredniego i wpadłem na kiepski pomysł, który polegał na ponownej instalacji sterowników nVidii. Jeśli ma to znaczenie, używam Gnome na repo Sida. Po tej instalacji serwer X nie uruchamia się, ze względu na nieprawidłową konfigurację.
Oto Xorg.0.log:
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux csknet-84-234-44-83 2.6.18-4-686 #1 SMP Wed May 9 23:03:12 UTC 2007 i686
Build Date: 16 May 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Mon May 21 09:02:54 2007
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "SyncMaster"
(**) | |-->Device "nVidia Corporation NV43 [GeForce 6600]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(WW) Including the default font path
/usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/
fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75d
pi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
/usr/share/fonts/X11/75dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Loader magic: 0x81e5f60
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: 00:00:0: chip 8086,2580 card 1458,2580 rev 04 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2581 card 0000,0000 rev 04 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,2658 card 1458,2658 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2659 card 1458,2659 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,265a card 1458,265a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,265b card 1458,265a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,265c card 1458,5006 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev d3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2640 card 0000,0000 rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2651 card 1458,2651 rev 03 class 01,01,80 hdr 00
(II) PCI: 00:1f:3: chip 8086,266a card 1458,266a rev 03 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0141 card 1458,3124 rev a2 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 1102,0007 card 1102,100a rev 00 class 04,01,00 hdr 00
(II) PCI: 02:01:0: chip 109e,036e card 1461,0003 rev 11 class 04,00,00 hdr 80
(II) PCI: 02:01:1: chip 109e,0878 card 1461,0003 rev 11 class 04,80,00 hdr 80
(II) PCI: 02:05:0: chip 10ec,8169 card 1458,e000 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000e (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0x48000000 - 0x480fffff (0x100000) MX
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xe0000000 - 0xe1ffffff (0x2000000) MX
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xe2000000 - 0xe20fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV43 [GeForce 6600] rev 162, Mem @ 0xd8000000/26, 0xd0000000/27,
0xdc000000/24
(--) PCI: (2:1:0) Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xe2000000/12
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xe1000000 - 0xe10000ff (0x100) MX[B]
[1] -1 0 0xe2001000 - 0xe2001fff (0x1000) MX[B]
[2] -1 0 0xe2100000 - 0xe21003ff (0x400) MX[B]
[3] -1 0 0xe2000000 - 0xe2000fff (0x1000) MX[B](B)
[4] -1 0 0xdc000000 - 0xdcffffff (0x1000000) MX[B](B)
[5] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[6] -1 0 0xd8000000 - 0xdbffffff (0x4000000) MX[B](B)
[7] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[8] -1 0 0x0000a000 - 0x0000a01f (0x20) IX[B]
[9] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[10] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[11] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[12] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[13] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[14] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xe1000000 - 0xe10000ff (0x100) MX[B]
[5] -1 0 0xe2001000 - 0xe2001fff (0x1000) MX[B]
[6] -1 0 0xe2100000 - 0xe21003ff (0x400) MX[B]
[7] -1 0 0xe2000000 - 0xe2000fff (0x1000) MX[B](B)
[8] -1 0 0xdc000000 - 0xdcffffff (0x1000000) MX[B](B)
[9] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[10] -1 0 0xd8000000 - 0xdbffffff (0x4000000) MX[B](B)
[11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[12] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[13] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[14] -1 0 0x0000a000 - 0x0000a01f (0x20) IX[B]
[15] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[16] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[17] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[18] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[19] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[20] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
(II) LoadModule: "i2c"(II) Module already built-in
(II) LoadModule: "ddc"(II) Module already built-in
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.3.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(WW) Warning, couldn't open module glx
(II) UnloadModule: "glx"
(EE) Failed to load module "glx" (module does not exist, 0)
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules//fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nvidia"
(WW) Warning, couldn't open module nvidia
(II) UnloadModule: "nvidia"
(EE) Failed to load module "nvidia" (module does not exist, 0)
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 7.1.1, module version = 1.1.0
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 7.1.1, module version = 1.1.1
(EE) No drivers available.
Fatal server error:
no screens found
Oto mój xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Mon Feb 26 23:38:46 PST 2007
# package.
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen" 0 0
EndSection
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
EndSection
Section "Device"
Identifier "nVidia Corporation NV43 [GeForce 6600]"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1600x1200" "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Wydaje się, że nie ładują się moduły nvidia i glx. Zaznaczam, że nie używałem compiza ani beryla. Co z tym zrobić?Z góry dzięki za zainteresowanie.
Problem z X-ami
(EE) No drivers available.Popraw cały post, użyj tagów code i quote
A co do samego problemu to było na forum
Dodaj do xorg.conf do sekcji "Files":
[/color]
#Path on which the NVIDIA drivers install themselves.
ModulePath "/usr/X11R6/lib/modules"
# Debian default module path.
ModulePath "/usr/lib/xorg/modules"
