#!/bin/bash
# This is a script to output bible verses from
# Diatheke for use in a conky script.
# This script depends on diatheke and rand.
# In Ubuntu and it's derivatives use:
# sudo apt-get install diatheke rand
# Visit http://www.crosswire.org/sword/diatheke/
# to learn more about Diatheke and the Sword Project.
# Usage:
# When called by itself this script will choose
# a verse at random from the list at $List. The
# list should be plain text with one verse or a
# group of verses per line. Examples of
# acceptable lines are as follows:
# Jn 3:16
# 1 Corinthians 12:8-10,12
# Revelation 22:20
# When called with an argument this script will
# attempt to use the argument as a verse and
# display the results.
# Feeding the script any other input will give
# unpredictable results.
# A suitable list of verses can be found at:
# http://www.gnpcb.org/esv/share/rss2.0/?show-verses=true
# The sample conkyrc can be invoked with
# conky -c verse.conkyrc
# Help with configuring conky can be found at:
# http://conky.sourceforge.net/documentation.html
# To learn about Jesus visit:
# http://www.christianity.com/Essentials/
# Module must be an installed Sword Module.
# Install new modules with bibletime.
Module=NETfree
# Location of plain text file with verses to choose from.
List=~/bin/bibleverse/verse.list
# Height and Width of output to keep the conky display sane.
OutputHeight=17
OutputWidth=48
# When set to true padding will be added to top of output.
# Otherwise the padding will be added to the bottom.
AlignBottom=true
# We use a temp file to speed up the script run time.
TempFile=/tmp/conky-verse
getVerse (){
case $1 in
"") ListLength=`wc -l $List | cut -d " " -f 1`
RandomNumber=`rand -M $ListLength -N 1`
VerseNumber=`expr $RandomNumber + 1`
Verse=`cat $List | head -n $VerseNumber | tail -n 1` ;;
*) Verse=$@ ;;
esac
printVerse (){
Verse=$1
Chapter=`diatheke -b $Module -k $Verse | head -n 1 | cut -d : -f 1`
# Print book chapter:verse(s)
echo '${color1}'$Verse'${color0}'
# Print the verse(s)
diatheke -b $Module -k $Verse | \
sed 's/'"$Chapter:"'//' | \
sed 's/('$Module')//' | \
sed 's/ ^[ \t]*//' | \
sed '/./!d' | \
sed 's/\t/ /g' | \
sed 's/^/ /' | \
fold -sw $OutputWidth | \
sed 's/^ /${color1} /' | \
sed 's/:/${color0}/'
padVerse (){
Lines=`cat $TempFile | wc -l | cut -d " " -f 1`
LinesAdd=`expr $OutputHeight - $Lines`
let i=0
while [ $i -lt $LinesAdd ]; do
echo
let i=$i+1
done
displayVerse (){
cat $TempFile
getVerse "$@"
printVerse "$Verse" > $TempFile
case $AlignBottom in
true|True) padVerse
displayVerse ;;
*) displayVerse
padVerse ;;
esac
exit 0Doinstalować drugiego nie mogę, więc poszukałem gdzie pojawia się ta funkcja.
RandomNumber=`rand -M $ListLength -N 1`Czy może mi ktoś podpowiedzieć, w jaki sposób zmusić powyższy skrypt do działania, ewentualnie jak podmienić fragment o losowej liczbie, żeby się generowała, a nie tylko udawała?
