lspci
00:07.0 Audio device: nVidia Corporation MCP67 High Definition Audio (rev a1)
lspci
dpkg -l | grep pulse
ii gstreamer0.10-pulseaudio 0.10.24-1 GStreamer plugin for PulseAudio
ii libpulse-browse0 0.9.21-3 PulseAudio client libraries (zeroconf support)
ii libpulse-mainloop-glib0 0.9.21-3 PulseAudio client libraries (glib support)
ii libpulse0 0.9.21-3 PulseAudio client libraries
ii pulseaudio 0.9.21-3 PulseAudio sound server
ii pulseaudio-esound-compat 0.9.21-3 PulseAudio ESD compatibility layer
ii pulseaudio-module-gconf 0.9.21-3 GConf module for PulseAudio sound server
ii pulseaudio-module-x11 0.9.21-3 X11 module for PulseAudio sound server
ii pulseaudio-module-zeroconf 0.9.21-3 Zeroconf module for PulseAudio sound server
ii pulseaudio-utils 0.9.21-3 Command line tools for the PulseAudio sound server
ii vlc-plugin-pulse 1.1.3-1 PulseAudio plugin for VLC
Enable software sound mixing (ESD)
E: alsa-sink.c: Error opening PCM device front:0: Urządzenie lub zasoby zajęte
System -> Preferencje (Preferences) -> Dźwięk (Sound)
Tego.fnmirk pisze:Kod: Zaznacz cały
tego tutaj nie ma.fnmirk pisze:.Kod: Zaznacz cały
