B
shyte
Błąd podczas instalacji sterowników nvidia
Post autor: shyte »
Gdy chcę zainstalować sterowniki z tego to nie mogę, wyświetla błąd, a niżej logi.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Aug 15 19:08:48 2010
installer version: 1.0.7
option status:
 license pre-accepted    : false
 update                  : false
 force update            : false
 expert                  : false
 uninstall               : false
 driver info             : false
 precompiled interfaces  : true
 no ncurses color        : false
 query latest version    : false
 OpenGL header files     : true
 no questions            : false
 silent                  : false
 no recursion            : false
 no backup               : false
 kernel module only      : false
 sanity                  : false
 add this kernel         : false
 no runlevel check       : false
 no network              : false
 no ABI note             : false
 no RPMs                 : false
 no kernel module        : false
 force SELinux           : default
 no X server check       : false
 no cc version check     : false
 force tls               : (not specified)
 X install prefix        : (not specified)
 X library install path  : (not specified)
 X module install path   : (not specified)
 OpenGL install prefix   : (not specified)
 OpenGL install libdir   : (not specified)
 utility install prefix  : (not specified)
 utility install libdir  : (not specified)
 doc install prefix      : (not specified)
 kernel name             : (not specified)
 kernel include path     : (not specified)
 kernel source path      : (not specified)
 kernel output path      : (not specified)
 kernel install path     : (not specified)
 proc mount point        : /proc
 ui                      : (not specified)
 tmpdir                  : /tmp
 ftp mirror              : ftp://download.nvidia.com
 RPM file list           : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 96.43.18.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> The CC version check failed:
  The compiler used to compile the kernel (gcc 4.3) does not exactly match the
  current compiler (gcc 4.4).  The Linux 2.6 kernel module loader rejects kern
  el modules built with a version of gcc that does not exactly match that of t
  he compiler used to build the running kernel.
  If you know what you are doing and want to ignore the gcc version check, sel
  ect "No" to continue installation.  Otherwise, select "Yes" to abort install
  ation, set the CC environment variable to the name of the compiler used to c
  ompile your kernel, and restart installation.  Abort now? (Answer: No)
-> Kernel source path: '/lib/modules/2.6.32-5-686-bigmem/source'
-> Kernel output path: '/lib/modules/2.6.32-5-686-bigmem/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Cleaning kernel module build directory.
  executing: 'cd ./usr/src/nv; make clean'...
-> Building kernel module:
  executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.32-5-686-bi
  gmem/source SYSOUT=/lib/modules/2.6.32-5-686-bigmem/build'...
  NVIDIA: calling KBUILD...
  make CC=cc KBUILD_OUTPUT=/lib/modules/2.6.32-5-686-bigmem/build KBUILD_VERBO
  SE=1 -C /lib/modules/2.6.32-5-686-bigmem/source SUBDIRS=/tmp/selfgz4908/NVID
  IA-Linux-x86-96.43.18-pkg1/usr/src/nv modules
  make -C /lib/modules/2.6.32-5-686-bigmem/build \
      KBUILD_SRC=/usr/src/linux-headers-2.6.32-5-common \
      KBUILD_EXTMOD="/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv" -
  f /usr/src/linux-headers-2.6.32-5-common/Makefile \
      modules
  test -e include/linux/autoconf.h -a -e include/config/auto.conf || (        \
      echo;                                \
      echo "  ERROR: Kernel configuration is invalid.";        \
      echo "         include/linux/autoconf.h or include/config/auto.conf are mis
  sing.";    \
      echo "         Run 'make oldconfig && make prepare' on kernel src to fix it
      echo;                                \
      /bin/false)
  mkdir -p /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.tmp_vers
  ions ; rm -f /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.tmp_
  versions/*
  make -f /usr/src/linux-headers-2.6.32-5-common/scripts/Makefile.build obj=/t
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.nv.o
  .d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -Iinclude -
  Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/src/linux-
  headers-2.6.32-5-common/arch/x86/include -include include/linux/autoconf.h
  -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__KERNEL__ -Wa
  ll -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-comm
  on -Werror-implicit-function-declaration -Wno-format-security -fno-delete-nu
  ll-pointer-checks -Os -m32 -msoft-float -mregparm=3 -freg-struct-return -mpr
  eferred-stack-boundary=2 -march=i686 -mtune=generic -Wa,-mtune=generic32 -ff
  reestanding -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME
  =1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx
  -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fomit-frame-pointer -g -Wdecl
  aration-after-statement -Wno-pointer
  -sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack   -I/tmp/sel
  fgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -Wall -Wimplicit -Wreturn-
  type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-
  multichar -Werror -MD -Wsign-compare -Wno-cast-qual -Wno-error -D_LOOSE_KERN
  EL_NAMES -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"96.43.18\" -UDEB
  UG -U_DEBUG -DNDEBUG  -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUIL
  D_STR(nv)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -c -o /tmp/selfgz4908/NVI
  DIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.tmp_nv.o /tmp/selfgz4908/NVIDIA-Linu
  x-x86-96.43.18-pkg1/usr/src/nv/nv.c
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/b
  itops.h:17,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/k
  ernel.h:15,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/s
  ched.h:54,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/u
  tsname.h:35,
                   from /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src
  /nv/nv-linux.h:25,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/bitops.h: In fun
  ction :
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/bitops.h:64: war
  ning: pointer of type  used in arithmetic
  ction :
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/bitops.h:102: wa
  rning: pointer of type  used in arithmetic
  ction :
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/bitops.h:178: wa
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/l
  ist.h:6,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/p
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/t
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/prefetch.h: In function
  /usr/src/linux-headers-2.6.32-5-common/include/linux/prefetch.h:57: warning:
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/p
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/list.h: In function :
  /usr/src/linux-headers-2.6.32-5-common/include/linux/list.h:106: warning: po
  /usr/src/linux-headers-2.6.32-5-common/include/linux/list.h:107: warning: po
  /usr/src/linux-headers-2.6.32-5-common/include/linux/list.h:579: warning: po
  /usr/src/linux-headers-2.6.32-5-common/include/linux/list.h:580: warning: po
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/s
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/rculist.h: In function
  /usr/src/linux-headers-2.6.32-5-common/include/linux/rculist.h:97: warning:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/rculist.h:143: warning:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/rculist.h:286: warning:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/rculist.h:306: warning:
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/u
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/sched.h: In function :
  /usr/src/linux-headers-2.6.32-5-common/include/linux/sched.h:2279: warning:
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/i
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/io.h: In functio
  n :
  /usr/src/linux-headers-2.6.32-5-common/arch/x86/include/asm/io.h:70: warning
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/d
  ma-mapping.h:7,
                   from /usr/src/linux-headers-2.6.32-5-common/include/asm-gen
  eric/pci-dma-compat.h:7,
                   from /usr/src/linux-headers-2.6.32-5-common/arch/x86/includ
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/scatterlist.h: In funct
  ion :
  /usr/src/linux-headers-2.6.32-5-common/include/linux/scatterlist.h:199: warn
  In file included from /usr/src/linux-headers-2.6.32-5-common/arch/x86/includ
  e/asm/dma-mapping.h:42,
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/asm-generic/dma-mapping-commo
  n.h: In function :
  n.h:77: warning: pointer of type  used in arithmetic
  In file included from /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src
  /nv/nv-linux.h:119,
  /nv/nv.c:13:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/highmem.h: In function
  /usr/src/linux-headers-2.6.32-5-common/include/linux/highmem.h:149: warning:
  /usr/src/linux-headers-2.6.32-5-common/include/linux/highmem.h:152: warning:
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.nv-v
  m.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -Iinclud
  e -Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/src/lin
  ux-headers-2.6.32-5-common/arch/x86/include -include include/linux/autoconf.
  h   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__KERNEL__
  -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-c
  ommon -Werror-implicit-function-decla
  ration -Wno-format-security -fno-delete-null-pointer-checks -Os -m32 -msoft-
  float -mregparm=3 -freg-struct-return -mpreferred-stack-boundary=2 -march=i6
  86 -mtune=generic -Wa,-mtune=generic32 -ffreestanding -fstack-protector -DCO
  NFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-as
  ynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larg
  er-than=1024 -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-poin
  ter-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack   -I/tmp/
  selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -Wall -Wimplicit -Wretu
  rn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -W
  no-multichar -Werror -MD -Wsign-compare -Wno-cast-qual -Wno-error -D_LOOSE_K
  ERNEL_NAMES -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"96.43.18\" -U
  DEBUG -U_DEBUG -DNDEBUG  -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KB
  UILD_STR(nv_vm)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -c -o /tmp/selfgz49
  r/src/nv/.tmp_nv-vm.o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src
  /nv/nv-vm.c
  itops.h:17,
  ernel.h:15,
  ched.h:54,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-vm.c:14:
  ction :
  ction :
  ction :
  ist.h:6,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-vm.c:14:
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-vm.c:14:
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-vm.c:14:
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-vm.c:14:
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  /nv/nv-vm.c:14:
  n :
  ma-mapping.h:7,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv-vm.c:14:
  ion :
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv-vm.c:14:
  n.h: In function :
  /nv/nv-linux.h:119,
  /nv/nv-vm.c:14:
  /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-vm.c: In functi
  on :
  /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-vm.c:143: warni
  ng: assignment makes integer from pointer without a cast
  /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-vm.c:228: warni
  ng: label  defined but not used
  /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-vm.c:138: warni
  ng: unused variable
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.os-a
  gp.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -Iinclu
  de -Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/src/li
  nux-headers-2.6.32-5-common/arch/x86/include -include include/linux/autoconf
  .h   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__KERNEL_
  _ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno
  -common -Werror-implicit-function-declaration -Wno-format-security -fno-dele
  32 -msoft-float -mregparm=3 -freg-struct-return -mpreferred-stack-boundary=2
  -march=i686 -mtune=generic -Wa,-mtune=generic32 -ffreestanding -fstack-prote
  ctor -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compar
  e -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wf
  rame-larger-than=1024 -fomit-frame-pointer -g -Wdeclaration-after-statement
  -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack
   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -Wall -Wimplici
  t -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-
  arith -Wno-multichar -Werror -MD -Wsign-compare -Wno-cast-qual -Wno-error -D
  _LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"96.43
  .18\" -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BAS
  ENAME=KBUILD_STR(os_agp)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -c -o /tmp
  /selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.tmp_os-agp.o /tmp/sel
  pkg1/usr/src/nv/os-agp.c
  itops.h:17,
  ernel.h:15,
  ched.h:54,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-agp.c:24:
  ction :
  ction :
  ction :
  ist.h:6,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-agp.c:24:
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-agp.c:24:
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-agp.c:24:
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-agp.c:24:
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  /nv/os-agp.c:24:
  n :
  ma-mapping.h:7,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/os-agp.c:24:
  ion :
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/os-agp.c:24:
  n.h: In function :
  /nv/nv-linux.h:119,
  /nv/os-agp.c:24:
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.os-i
  nterface.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -
  Iinclude -Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/
  src/linux-headers-2.6.32-5-common/arch/x86/include -include include/linux/au
  toconf.h   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__K
  ERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasin
  g -fno-common -Werror-implicit-function-declaration -Wno-format-security -fn
  o-delete-null-pointer-checks -Os -m32 -msoft-float -mregparm=3 -freg-struct-
  return -mpreferred-stack-boundary=2 -march=i686 -mtune=generic -Wa,-mtune=ge
  neric32 -ffreestanding -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_S
  IGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-s
  se -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fomit-frame-point
  er -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -
  fno-dwarf2-cfi-asm -fconserve-stack   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.
  43.18-pkg1/us
  r/src/nv -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts
  -Wparentheses -Wpointer-arith -Wno-multichar -Werror -MD -Wsign-compare -Wno
  -cast-qual -Wno-error -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNVRM -DN
  V_VERSION_STRING=\"96.43.18\" -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE -D"KBUILD_
  STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_interface)"  -D"KBUILD_MODNAME=K
  BUILD_STR(nvidia)"  -c -o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr
  /src/nv/.tmp_os-interface.o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/u
  sr/src/nv/os-interface.c
  itops.h:17,
  ernel.h:15,
  ched.h:54,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-interface.c:26:
  ction :
  ction :
  ction :
  ist.h:6,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  tsname.h:35,
  /nv/nv-linux.h:25,
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  n :
  ma-mapping.h:7,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  ion :
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  n.h: In function :
  /nv/nv-linux.h:119,
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.os-r
  egistry.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -I
  include -Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/s
  rc/linux-headers-2.6.32-5-common/arch/x86/include -include include/linux/aut
  oconf.h   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__KE
  RNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing
  ion-declaration -Wno-format-security -fno-delete-null-pointer-checks -Os -m3
  ENAME=KBUILD_STR(os_registry)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -c -o
  6.43.18-pkg1/usr/src/nv/.tmp_os-registry.o /tmp/selfgz4908/NVIDIA-Linux-x86-
  96.43.18-pkg1/usr/src/nv/os-registry.c
  itops.h:17,
  ernel.h:15,
  ched.h:54,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/os-registry.c:14:
  ction :
  ction :
  ction :
  ist.h:6,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  tsname.h:35,
  /nv/nv-linux.h:25,
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  n :
  ma-mapping.h:7,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  ion :
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  n.h: In function :
  /nv/nv-linux.h:119,
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.nv-i
  2c.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -Iinclu
  te-null-pointer-checks -Os -m32 -msoft-float -mregparm=3 -freg-struct-return
  -mpreferred-stack-boundary=2 -march=i686 -mtune=generic -Wa,-mtune=generic32
  -ffreestanding -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FR
  AME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-
  mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fomit-frame-pointer -g -W
  ENAME=KBUILD_STR(nv_i2c)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -c -o /tmp
  /selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.tmp_nv-i2c.o /tmp/sel
  fgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-i2c.c
  itops.h:17,
  ernel.h:15,
  ched.h:54,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-i2c.c:8:
  ction :
  ction :
  ction :
  ist.h:6,
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-i2c.c:8:
  reempt.h:11,
  pinlock.h:50,
  eqlock.h:29,
  ime.h:8,
  imex.h:56,
  ched.h:56,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-i2c.c:8:
  ched.h:82,
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-i2c.c:8:
  tsname.h:35,
  /nv/nv-linux.h:25,
  /nv/nv-i2c.c:8:
  o.h:22,
  ci.h:54,
  /nv/nv-linux.h:88,
  /nv/nv-i2c.c:8:
  n :
  ma-mapping.h:7,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv-i2c.c:8:
  ion :
  ma-mapping.h:103,
  e/asm/pci.h:128,
  ci.h:1131,
  /nv/nv-linux.h:88,
  /nv/nv-i2c.c:8:
  n.h: In function :
  /nv/nv-linux.h:119,
  /nv/nv-i2c.c:8:
    ld -m elf_i386   -r -o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/
  src/nv/nvidia.o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv
  -kernel.o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv.o /tm
  p/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-vm.o /tmp/selfgz49
  08/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/os-agp.o /tmp/selfgz4908/NVIDIA
  -Linux-x86-96.43.18-pkg1/usr/src/nv/os-interface.o /tmp/selfgz4
  908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/os-registry.o /tmp/selfgz4908/
  NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nv-i2c.o
  (cat /dev/null;   echo kernel//tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1
  /usr/src/nv/nvidia.ko ;) > /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr
  /src/nv/modules.order
  make -f /usr/src/linux-headers-2.6.32-5-common/scripts/Makefile.modpost
    scripts/mod/modpost -m  -i /usr/src/linux-headers-2.6.32-5-686-bigmem/Modu
  le.symvers -I /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/Modu
  le.symvers  -o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/Mod
  ule.symvers -S -w -c -s
    cc -Wp,-MD,/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/.nvid
  ia.mod.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.4.5/include -Ii
  nclude -Iinclude2 -I/usr/src/linux-headers-2.6.32-5-common/include -I/usr/sr
  c/linux-headers-2.6.32-5-common/arch/x86/include -include include/linux/auto
  conf.h   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv -D__KER
  NEL__ -Wall -Wunde
  f -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werro
  r-implicit-function-declaration -Wno-format-security -fno-delete-null-pointe
  r-checks -Os -m32 -msoft-float -mregparm=3 -freg-struct-return -mpreferred-s
  tack-boundary=2 -march=i686 -mtune=generic -Wa,-mtune=generic32 -ffreestandi
  ng -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe
  -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse
  2 -mno-3dnow -Wframe-larger-than=1024 -fomit-frame-pointer -g -Wdeclaration-
  after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -
  fconserve-stack   -I/tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/n
  v -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparen
  theses -Wpointer-arith -Wno-multichar -Werror -MD -Wsign-compare -Wno-cast-q
  ual -Wno-error -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSI
  ON_STRING=\"96.43.18\" -UDEBUG -U_DEBUG -DNDEBUG  -D"KBUILD_STR(s)=#s" -D"KB
  UILD_BASENAME=KBUILD_STR(nvidia.mod)
  "  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)"  -DMODULE -c -o /tmp/selfgz4908/NVI
  DIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nvidia.mod.o /tmp/selfgz4908/NVIDIA-L
  inux-x86-96.43.18-pkg1/usr/src/nv/nvidia.mod.c
  itops.h:17,
  ernel.h:15,
  e/asm/percpu.h:45,
  e/asm/current.h:5,
  e/asm/processor.h:15,
  refetch.h:14,
  ist.h:6,
                   from /usr/src/linux-headers-2.6.32-5-common/include/linux/m
  odule.h:9,
  /nv/nvidia.mod.c:1:
  ction :
  ction :
  ction :
  ist.h:6,
  odule.h:9,
  /nv/nvidia.mod.c:1:
  In file included from /usr/src/linux-headers-2.6.32-5-common/include/linux/m
  odule.h:9,
  /nv/nvidia.mod.c:1:
    ld -r -m elf_i386 -T /usr/src/linux-headers-2.6.32-5-common/scripts/module
  -common.lds --build-id -o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr
  /src/nv/nvidia.ko /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/
  nvidia.o /tmp/selfgz4908/NVIDIA-Linux-x86-96.43.18-pkg1/usr/src/nv/nvidia.mo
  d.o
  NVIDIA: left KBUILD.
-> done.
-> Kernel module compilation complete.
ERROR: Unable to load the kernel module 'nvidia.ko'.  This happens most
      frequently when this kernel module was built against the wrong or
      improperly configured kernel sources, with a version of gcc that differs
      from the one used to build the target kernel, or if a driver such as
      rivafb/nvidiafb is present and prevents the NVIDIA kernel module from
      obtaining ownership of the NVIDIA graphics device(s).
      Please see the log entries 'Kernel module load error' and 'Kernel
      messages' at the end of the file '/var/log/nvidia-installer.log' for
      more information.
-> Kernel module load error: insmod: error inserting './usr/src/nv/nvidia.ko':
  -1 No such device
-> Kernel messages:
  [  266.729479] NVRM: No NVIDIA graphics adapter probed!
  [  294.262159] [drm] nouveau 0000:01:00.0: Allocating FIFO number 2
  [  294.267117] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc:
  initialised FIFO 2
  [  349.749140] [drm] nouveau 0000:01:00.0: nouveau_channel_free: freeing
  fifo 2
  [  366.773534] NVRM: The NVIDIA probe routine was not called for 1
  device(s).
  [  366.773537] NVRM: This can occur when a driver such as nouveau, rivafb,
  [  366.773538] NVRM: nvidiafb, or rivatv was loaded and obtained ownership
  of
  [  366.773539] NVRM: the NVIDIA device(s).
  [  366.773541] NVRM: Try unloading the conflicting kernel module (and/or
  [  366.773542] NVRM: reconfigure your kernel without the conflicting
  [  366.773543] NVRM: driver(s)), then try loading the NVIDIA kernel module
  [  366.773544] NVRM: again.
  [  366.773592] NVRM: No NVIDIA graphics adapter probed!
  [  374.236133] [drm] nouveau 0000:01:00.0: Allocating FIFO number 2
  [  374.241683] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc:
  initialised FIFO 2
  [  676.884723] [drm] nouveau 0000:01:00.0: nouveau_channel_free: freeing
  fifo 2
  [  696.064575] NVRM: The NVIDIA probe routine was not called for 1
  device(s).
  [  696.064578] NVRM: This can occur when a driver such as nouveau, rivafb,
  [  696.064579] NVRM: nvidiafb, or rivatv was loaded and obtained ownership
  of
  [  696.064580] NVRM: the NVIDIA device(s).
  [  696.064581] NVRM: Try unloading the conflicting kernel module (and/or
  [  696.064582] NVRM: reconfigure your kernel without the conflicting
  [  696.064583] NVRM: driver(s)), then try loading the NVIDIA kernel module
  [  696.064584] NVRM: again.
  [  696.064630] NVRM: No NVIDIA graphics adapter probed!
ERROR: Installation has failed.  Please see the file
      '/var/log/nvidia-installer.log' for details.  You may find suggestions
      on fixing installation problems in the README available on the Linux
      driver download page at www.nvidia.com.
button
Post autor: button »
