[+] Krita - nie otwiera żadnych plików
majoballs
Post autor: majoballs »
Witam serdecznie.
Proszę o poradę. Przy próbie otworzenia jakichkolwiek plików graficznych Krita wyłącza się.
majoballs@Aristo:~$ krita
krita(30917)/kdecore (KLibrary) findLibraryInternal: plugins should not have a 'lib' prefix: "libkritapart.so"
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/libkritapart.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/defaulttools.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/kopabackgroundtool.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/paragraphtool.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/textshape.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/artistictextshape.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/pathshapes.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/kolcmsengine.so" does not offer a qt_plugin_instance function.
krita(30917)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/kofficedockers.so" does not offer a qt_plugin_instance function.
(Soprano::Redland::BackendPlugin) creating model of type "hashes" with options "hash-type='memory',contexts='yes'"
krita(30917)/kdeui (KAction) KActionCollection::setComponentData: this does not work on a KActionCollection containing actions!
krita(30917)/kotext TextShapeFactory::newDocumentResourceManager: No KUndoStack found in the document resource manager, creating a new one
krita(30917)/kdecore (KLibrary) findLibraryInternal: plugins should not have a 'lib' prefix: "libxsltexport.so"
krita(30917)/koffice (filter manager) KoFilterManager::filterAvailable: The library  ""  does not offer a check_ ""  function.
krita(30917)/kdecore (KLibrary) findLibraryInternal: plugins should not have a 'lib' prefix: "libkritapngimport.so"
X Error: BadAtom (invalid Atom parameter) 5
  Major opcode: 20 (X_GetProperty)
  Resource id:  0x0
Enchant dict for "pl" 0x3369d40
Enchant dict for "en_US" 0x338f6d0
Enchant dict for "pl" 0x3b9e380
"popup frame" true
KCrash: Application 'krita' crashing...
sock_file=/home/majoballs/.kde/socket-Aristo/kdeinit4__0
[1]+  Stopped                 krita
majoballs@Aristo:~$
Nie wiem co było nie tak, ale po usunięciu katalogu .kde i przelogowaniu wszystko działa jak należy. Metoda trochę brutalna ale pomogło :D
