Zainstalowałem Javę z repozytorium Debiana i niby wszystko dobrze, tylko aplikacja nie łączy się z internetem kiedy np. chcę wejść na czat. Dostaję komunikat o treści:
Java Plug-in 1.6.0_20
Using JRE version 1.6.0_20-b02 Java HotSpot(TM) Client VM
User home directory = /home/slawek
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class INTChat.class not found.
java.lang.ClassNotFoundException: INTChat.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Applet2ClassLoader.java:219)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Plugin2ClassLoader.java:532)
at sun.plugin2.applet.Plugin2Manager.createApplet(Plugin2Manager.java:2940)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Plugin2Manager.java:1444)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.net.ConnectException: Network is unreachable
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at sun.net.NetworkClient.doConnect(NetworkClient.java:161)
at sun.net.[url]www.http.HttpClient.openServer(HttpClient.java:394[/url])
at sun.net.[url]www.http.HttpClient.openServer(HttpClient.java:529[/url])
at sun.net.www.http.HttpClient.<init>(HttpClient.java:233)
at sun.net.[url]www.http.HttpClient.New(HttpClient.java:306[/url])
at sun.net.[url]www.http.HttpClient.New(HttpClient.java:323[/url])
at sun.net.[url]www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:860[/url])
at sun.net.[url]www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:801[/url])
at sun.net.[url]www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:726[/url])
at sun.net.[url]www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1049[/url])
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:373)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Applet2ClassLoader.java:535)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Applet2ClassLoader.java:51)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Applet2ClassLoader.java:192)
at java.security.AccessController.doPrivileged(Native Method)
at sun.plugin2.applet.Applet2ClassLoader.findClass(Applet2ClassLoader.java:189)
... 6 more
Exception: java.lang.ClassNotFoundException: INTChat.class
