Czy da sie ustawic na sambie cos takiego
Dysk_F
|---- Katalog_A
|---- Katalog_B
i teraz w otoczeniu widoczny jest Dysk_F i dopiero jak ktos tam wejdzie widzi dwa katalogi A i B
Klient chcialby aby dysk A byl dostepny dla wszystkich natomiast katalog B dostepny jedynie dla osob ktore sa w grupie samba.
smb.conf
[global]
workgroup = FIRMA
netbios name = SAMBA-DEB
server string = LINUX SERVER
interfaces = eth1
security = SHARE
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:*
password level = 8
username level = 8
log level = 3
syslog = 0
log file = /var/log/samba/samba.%m
max log size = 1000
name resolve order = wins bcast hosts lmhosts
time server = Yes
deadtime = 15
keepalive = 15
max open files = 20000
socket options = TCP_NODELAY SO_SNDBUF=16384 SO_RCVBUF=16384 IPTOS_LOWDELAY
add user script = /usr/sbin/useradd -m %u
delete user script = /usr/sbin/userdel -r %u
add group script = /usr/sbin/groupadd %g
delete group script = /usr/sbin/groupdel %g
add user to group script = /usr/sbin/usermod -G %g %u
add machine script = /usr/sbin/useradd -s /bin/false -d /dev/null %u
os level = 64
wins support = Yes
[DYSK_F]
comment = DYSK_F
path = /opt/samba
force group = samba
read only = No
create mask = 0644
guest ok = Yesużywaj tagów code oraz quote
mlyczek
