Próbuje zrobić powiadomienie gg o nowej wiadomości e-mail.
Moje ustawienia postfiksa.
Main.cf
command_directory = /usr/sbin
mail_owner = postfix
mydomain = domena(wycieta)
myhostname = moj host(wyciety)
myorigin = /etc/mailname
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain,
mynetworks = 127.0.0.0/8
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relayhost =
#smtpd_sasl_auth_enable = yes
#smtpd_sasl_security_options = noanonymous
#smtpd_recipient_restrictions =
# permit_sasl_authenticated,
# permit_mynetworks,
# reject_unauth_destination
#AUTH SMTP
smtpd_sasl_type = dovecot
smtpd_sasl2_auth_enable = yes
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions = permit_mynetworks,
reject_unauth_destination,
reject_unknown_recipient_domain,
reject_non_fqdn_recipient
smtpd_client_restrictions = permit_sasl_authenticated,
reject_unknown_client,
reject_rbl_client dul.dnsbl.sorbs.net,
# reject_rbl_client list.dsbl.org,
reject_rbl_client sbl.spamhaus.org,
reject_rbl_client cbl.abuseat.org
smtpd_sender_restrictions = permit_sasl_authenticated,
reject_unknown_sender_domain,
reject_non_fqdn_sender,
reject_unknown_address
#TLS
smtpd_tls_auth_only = no
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
mailbox_command = procmail -a "$EXTENSION"Kod: Zaznacz cały
SHELL=/bin/bash
VERBOSE=off
LOGFILE=/var/log/procmail/procmail.log
MAILDIR=$HOME/Maildir
DEFAULT=$HOME/Maildir/Kod: Zaznacz cały
NEW_SUBJECT='formail -xSubject'
MAIL_FROM='formail -xFrom:'
mail_reply='formail -xReturn-Path'
do_kogo=`formail -xTo:'
:0 c
| /home/[b]użytkownik[/b]/powiadom "$MAIL_FROM" "$NEW_SUBJECT" "-" "$do_kogo"Kod: Zaznacz cały
#!/usr/bin/perl
$kto=@ARGV[0];
$temat=@ARGV[1];
open(sms,"|ekg msg gg ' $kto --> $temat ' >/dev/null");
close(sms);
Czy ktoś wie dlaczego tak się dzieje i jak to naprawić?
Z góry dziękuje (docelowo chciałbym aby wszystko czyli od kogo temat i treść była przekazywana do php jeśli można to prosiłbym o pomoc również z tym).
Dziękuje.
