Przetestowałem jedną płytę (nie do końca bo odczyt stanął przy samym końcu).
Track list (1-1):
1: 00:02:00 (sec: 000000) data
170: 75:19:51 (sec: 338826) data (leadout)
Disc status: data mode 1
Multisession: 0
Audio status: no status
Try to find out what sort of CD this is...
CD-ROM with iso9660 fs
iso9660: 661 MB size, label 'TAPETY 2 '
Creating software: 'STOMP RECORDNOW MAX - BUILD 4.5.000'
NB! For disks written with some burners cdck might
report about unreadable sectors at the end of the disk.
In such cases you can just ignore those warnings.
Reading sectors 1-338826
338788 ok
ii cdrecord 9:1.1.10-1 Dummy transition package for wodim
ii wodim 9:1.1.10-1 command line CD/DVD writing tool
wodim: Overview of accessible drives (1 found) :
0 dev='/dev/hda' rwrw-- : 'TSSTcorp' 'CDDVDW TS-L632H'
cat /etc/udev/rules.d/70-persistent-cd.rules
# This file was automatically generated by the /lib/udev/write_cd_rules
# program, run by the cd-aliases-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and set the $GENERATED variable.
# TSSTcorp_CDDVDW_TS-L632H (pci-0000:00:1f.1)
SUBSYSTEM=="block", ENV{ID_CDROM}=="?*", ENV{ID_PATH}=="pci-0000:00:1f.1", SYMLINK+="cdrom", ENV{GENERATED}="1"
SUBSYSTEM=="block", ENV{ID_CDROM}=="?*", ENV{ID_PATH}=="pci-0000:00:1f.1", SYMLINK+="cdrw", ENV{GENERATED}="1"
SUBSYSTEM=="block", ENV{ID_CDROM}=="?*", ENV{ID_PATH}=="pci-0000:00:1f.1", SYMLINK+="dvd", ENV{GENERATED}="1"
SUBSYSTEM=="block", ENV{ID_CDROM}=="?*", ENV{ID_PATH}=="pci-0000:00:1f.1", SYMLINK+="dvdrw", ENV{GENERATED}="1"
Jutro popołudniu zrobię jeszcze jakiś test płyty CD-R tym programem.
