Bateria w ASUS UL80 - krótka praca
Posiadam Asusa ul80 na windowsie trzyma spokojnie 10h jak nie wiecej a na debianie amd64 przy max naladowanej baterii ok 5h. Zaobserwowalem ciekawa rzecz gdy odlaczam laptop z ladowarki przez chwile pokazuje na debianie 10h i spada po chwili do 5h i tak zostaje. Ma ktos moze pomysl dlaczego 50% roznica w uzyciu baterii? i jak to zniwelowac?
Co zwraca
cpufreq-info
cpufrequtils 006: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 10.0 us.
hardware limits: 800 MHz - 1.30 GHz
available frequency steps: 1.30 GHz, 800 MHz
available cpufreq governors: userspace, conservative, powersave, ondemand, performance
current policy: frequency should be within 800 MHz and 1.30 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 800 MHz.
cpufreq stats: 1.30 GHz:23,21%, 800 MHz:76,79% (12117)
analyzing CPU 1:
CPUs which run at the same hardware frequency: 1
CPUs which need to have their frequency coordinated by software: 1
within this range.
cpufreq stats: 1.30 GHz:38,36%, 800 MHz:61,64% (13561)
Pokaż W Windowsie za wyłączenie nieużywanej karty odpowiada program Asusa, w debianie jest pewnie ona ciągle włączona i stąd ten wysoki pobór mocy.
dmesg
calosc nie miesci sie w terminalu ale z tego co widac:
[ 0.242429] pci 0000:00:1f.2: PME# disabled
[ 0.242532] pci 0000:01:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff]
[ 0.242558] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xe0000000-0xefffffff]
[ 0.242590] pci 0000:01:00.0: reg 1c 64bit mmio pref: [0xfa000000-0xfbffffff]
[ 0.242610] pci 0000:01:00.0: reg 24 io port: [0xdc00-0xdc7f]
[ 0.242631] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfe980000-0xfe9fffff]
[ 0.242791] pci 0000:01:00.1: reg 10 32bit mmio: [0xfe97c000-0xfe97ffff]
[ 0.243046] pci 0000:00:01.0: bridge io port: [0xd000-0xdfff]
[ 0.243050] pci 0000:00:01.0: bridge 32bit mmio: [0xfd000000-0xfe9fffff]
[ 0.243055] pci 0000:00:01.0: bridge 64bit mmio pref: [0xe0000000-0xfbffffff]
[ 0.243257] pci 0000:03:00.0: reg 10 64bit mmio: [0xfeafe000-0xfeafffff]
[ 0.243416] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.243444] pci 0000:03:00.0: PME# disabled
[ 0.243566] pci 0000:00:1c.1: bridge 32bit mmio: [0xfea00000-0xfeafffff]
[ 0.243647] pci 0000:04:00.0: reg 10 64bit mmio: [0xfebc0000-0xfebfffff]
[ 0.243659] pci 0000:04:00.0: reg 18 io port: [0xec00-0xec7f]
[ 0.243744] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.243751] pci 0000:04:00.0: PME# disabled
[ 0.243849] pci 0000:00:1c.5: bridge io port: [0xe000-0xefff]
[ 0.243855] pci 0000:00:1c.5: bridge 32bit mmio: [0xfeb00000-0xfebfffff]
[ 0.243927] pci 0000:00:1e.0: transparent bridge
[ 0.243975] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.244279] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.244392] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[ 0.244509] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[ 0.244605] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.280838] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12)
[ 0.281050] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 10 12)
[ 0.281260] ACPI: PCI Interrupt Link [LNKC] (IRQs *6)
[ 0.281466] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 7 10 12)
[ 0.281673] ACPI: PCI Interrupt Link [LNKE] (IRQs 6) *0, disabled.
[ 0.281879] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *7 10 12)
[ 0.282087] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 *4 5 6 7 10 12)
[ 0.282294] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 12)
[ 0.282434] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.282457] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[ 0.282462] vgaarb: loaded
[ 0.282539] PCI: Using ACPI for IRQ routing
[ 0.282805] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.282811] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.288010] Switching to clocksource tsc
[ 0.289463] pnp: PnP ACPI init
[ 0.289472] ACPI: bus type pnp registered
[ 0.293282] pnp: PnP ACPI: found 15 devices
[ 0.293285] ACPI: ACPI bus type pnp unregistered
[ 0.293296] system 00:01: iomem range 0xfed10000-0xfed19fff has been reserved
[ 0.293307] system 00:08: ioport range 0x4d0-0x4d1 has been reserved
[ 0.293311] system 00:08: ioport range 0x4c0-0x4cf has been reserved
[ 0.293314] system 00:08: ioport range 0x4d2-0x4ff has been reserved
[ 0.293318] system 00:08: ioport range 0x800-0x87f has been reserved
[ 0.293322] system 00:08: ioport range 0x400-0x41f has been reserved
[ 0.293325] system 00:08: ioport range 0x500-0x57f has been reserved
[ 0.293329] system 00:08: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.293333] system 00:08: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 0.293337] system 00:08: iomem range 0xfed45000-0xfed89fff has been reserved
[ 0.293341] system 00:08: iomem range 0xfed90000-0xfed90fff has been reserved
[ 0.293345] system 00:08: iomem range 0xfed91000-0xfed91fff has been reserved
[ 0.293349] system 00:08: iomem range 0xfed92000-0xfed92fff has been reserved
[ 0.293353] system 00:08: iomem range 0xfed93000-0xfed93fff has been reserved
[ 0.293357] system 00:08: iomem range 0xffb00000-0xffbfffff has been reserved
[ 0.293361] system 00:08: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.293368] system 00:0a: iomem range 0xffa00000-0xffbfffff could not be reserved
[ 0.293372] system 00:0a: iomem range 0xffe00000-0xffffffff could not be reserved
[ 0.293379] system 00:0b: iomem range 0xffc00000-0xffdfffff has been reserved
[ 0.293386] system 00:0c: ioport range 0x250-0x253 has been reserved
[ 0.293389] system 00:0c: ioport range 0x256-0x25f has been reserved
[ 0.293393] system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.293397] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.293401] system 00:0c: iomem range 0xfec18000-0xfec1ffff has been reserved
[ 0.293405] system 00:0c: iomem range 0xfec38000-0xfec3ffff has been reserved
[ 0.293411] system 00:0d: iomem range 0xc0000000-0xcfffffff has been reserved
[ 0.293418] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[ 0.293422] system 00:0e: iomem range 0xc0000-0xcffff has been reserved
[ 0.293426] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
[ 0.293429] system 00:0e: iomem range 0x100000-0xbddfffff could not be reserved
[ 0.298200] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.298204] pci 0000:00:01.0: IO window: 0xd000-0xdfff
[ 0.298209] pci 0000:00:01.0: MEM window: 0xfd000000-0xfe9fffff
[ 0.298213] pci 0000:00:01.0: PREFETCH window: 0x000000e0000000-0x000000fbffffff
[ 0.298218] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[ 0.298221] pci 0000:00:1c.0: IO window: disabled
[ 0.298227] pci 0000:00:1c.0: MEM window: disabled
[ 0.298232] pci 0000:00:1c.0: PREFETCH window: disabled
[ 0.298241] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:03
[ 0.298243] pci 0000:00:1c.1: IO window: disabled
[ 0.298250] pci 0000:00:1c.1: MEM window: 0xfea00000-0xfeafffff
[ 0.298256] pci 0000:00:1c.1: PREFETCH window: disabled
[ 0.298264] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:04
[ 0.298268] pci 0000:00:1c.5: IO window: 0xe000-0xefff
[ 0.298276] pci 0000:00:1c.5: MEM window: 0xfeb00000-0xfebfffff
[ 0.298281] pci 0000:00:1c.5: PREFETCH window: disabled
[ 0.298289] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05
[ 0.298292] pci 0000:00:1e.0: IO window: disabled
[ 0.298298] pci 0000:00:1e.0: MEM window: disabled
[ 0.298304] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.298318] alloc irq_desc for 16 on node -1
[ 0.298320] alloc kstat_irqs on node -1
[ 0.298326] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.298331] pci 0000:00:01.0: setting latency timer to 64
[ 0.298342] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.298347] pci 0000:00:1c.0: setting latency timer to 64
[ 0.298358] alloc irq_desc for 17 on node -1
[ 0.298360] alloc kstat_irqs on node -1
[ 0.298370] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.298376] pci 0000:00:1c.1: setting latency timer to 64
[ 0.298387] pci 0000:00:1c.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.298393] pci 0000:00:1c.5: setting latency timer to 64
[ 0.298402] pci 0000:00:1e.0: setting latency timer to 64
[ 0.298407] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.298411] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.298414] pci_bus 0000:01: resource 0 io: [0xd000-0xdfff]
[ 0.298417] pci_bus 0000:01: resource 1 mem: [0xfd000000-0xfe9fffff]
[ 0.298420] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xfbffffff]
[ 0.298424] pci_bus 0000:03: resource 1 mem: [0xfea00000-0xfeafffff]
[ 0.298427] pci_bus 0000:04: resource 0 io: [0xe000-0xefff]
[ 0.298430] pci_bus 0000:04: resource 1 mem: [0xfeb00000-0xfebfffff]
[ 0.298433] pci_bus 0000:05: resource 3 io: [0x00-0xffff]
[ 0.298436] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.298468] NET: Registered protocol family 2
[ 0.298655] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.299994] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.304044] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.304558] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.304561] TCP reno registered
[ 0.304680] NET: Registered protocol family 1
[ 0.304711] pci 0000:00:02.0: Boot video device
[ 0.304992] Unpacking initramfs...
[ 0.530797] Freeing initrd memory: 7577k freed
[ 0.533810] Simple Boot Flag at 0x51 set to 0x1
[ 0.534202] audit: initializing netlink socket (disabled)
[ 0.534216] type=2000 audit(1274884560.531:1): initialized
[ 0.534615] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.536329] VFS: Disk quotas dquot_6.5.2
[ 0.536390] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.536485] msgmni has been set to 7866
[ 0.536697] alg: No test for stdrng (krng)
[ 0.536757] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.536761] io scheduler noop registered
[ 0.536763] io scheduler anticipatory registered
[ 0.536766] io scheduler deadline registered
[ 0.536806] io scheduler cfq registered (default)
[ 0.536935] alloc irq_desc for 24 on node -1
[ 0.536937] alloc kstat_irqs on node -1
[ 0.536949] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 0.536956] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.537083] alloc irq_desc for 25 on node -1
[ 0.537086] alloc kstat_irqs on node -1
[ 0.537096] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[ 0.537107] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.537259] alloc irq_desc for 26 on node -1
[ 0.537261] alloc kstat_irqs on node -1
[ 0.537271] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
[ 0.537282] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.537437] alloc irq_desc for 27 on node -1
[ 0.537439] alloc kstat_irqs on node -1
[ 0.537449] pcieport 0000:00:1c.5: irq 27 for MSI/MSI-X
[ 0.537461] pcieport 0000:00:1c.5: setting latency timer to 64
[ 0.539318] Linux agpgart interface v0.103
[ 0.539321] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.539795] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.539879] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.543546] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 0.545274] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.545281] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.545311] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.545338] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.545363] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.545482] mice: PS/2 mouse device common for all mice
[ 0.545538] rtc_cmos 00:03: RTC can wake from S4
[ 0.545582] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.545615] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.545631] cpuidle: using governor ladder
[ 0.545634] cpuidle: using governor menu
[ 0.545639] No iBFT detected.
[ 0.546004] TCP cubic registered
[ 0.546132] NET: Registered protocol family 10
[ 0.546651] lo: Disabled Privacy Extensions
[ 0.546975] Mobile IPv6
[ 0.546978] NET: Registered protocol family 17
[ 0.547066] PM: Resume from disk failed.
[ 0.547072] registered taskstats version 1
[ 0.547697] rtc_cmos 00:03: setting system clock to 2010-05-26 14:36:00 UTC (1274884560)
[ 0.547756] Freeing unused kernel memory: 580k freed
[ 0.547956] Write protecting the kernel read-only data: 4144k
[ 0.583164] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.764151] thermal LNXTHERM:01: registered as thermal_zone0
[ 0.764160] ACPI: Thermal Zone [THRM] (53 C)
[ 1.032075] usbcore: registered new interface driver usbfs
[ 1.032104] usbcore: registered new interface driver hub
[ 1.056059] usbcore: registered new device driver usb
[ 1.057824] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.057870] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.057881] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.057886] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.057909] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.057956] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000c880
[ 1.058011] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.058014] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.058017] usb usb1: Product: UHCI Host Controller
[ 1.058020] usb usb1: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.058022] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.058107] usb usb1: configuration #1 chosen from 1 choice
[ 1.058142] hub 1-0:1.0: USB hub found
[ 1.058150] hub 1-0:1.0: 2 ports detected
[ 1.058210] alloc irq_desc for 21 on node -1
[ 1.058213] alloc kstat_irqs on node -1
[ 1.058220] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 1.058229] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.058233] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.058242] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 1.058278] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000c800
[ 1.058316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.058319] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.058322] usb usb2: Product: UHCI Host Controller
[ 1.058324] usb usb2: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.058327] usb usb2: SerialNumber: 0000:00:1a.1
[ 1.058392] usb usb2: configuration #1 chosen from 1 choice
[ 1.058423] hub 2-0:1.0: USB hub found
[ 1.058430] hub 2-0:1.0: 2 ports detected
[ 1.058483] alloc irq_desc for 19 on node -1
[ 1.058485] alloc kstat_irqs on node -1
[ 1.058491] uhci_hcd 0000:00:1a.2: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 1.058499] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 1.058503] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.058512] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 3
[ 1.058550] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000c480
[ 1.058589] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.058592] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.058595] usb usb3: Product: UHCI Host Controller
[ 1.058597] usb usb3: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.058600] usb usb3: SerialNumber: 0000:00:1a.2
[ 1.058664] usb usb3: configuration #1 chosen from 1 choice
[ 1.058695] hub 3-0:1.0: USB hub found
[ 1.058702] hub 3-0:1.0: 2 ports detected
[ 1.058757] alloc irq_desc for 23 on node -1
[ 1.058759] alloc kstat_irqs on node -1
[ 1.058764] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.058772] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.058776] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.058790] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.058825] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c400
[ 1.058864] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.058867] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.058870] usb usb4: Product: UHCI Host Controller
[ 1.058872] usb usb4: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.058875] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.058939] usb usb4: configuration #1 chosen from 1 choice
[ 1.058970] hub 4-0:1.0: USB hub found
[ 1.058977] hub 4-0:1.0: 2 ports detected
[ 1.059030] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.059038] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.059042] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.059051] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 1.059079] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c080
[ 1.059115] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.059118] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.059121] usb usb5: Product: UHCI Host Controller
[ 1.059123] usb usb5: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.059126] usb usb5: SerialNumber: 0000:00:1d.1
[ 1.059189] usb usb5: configuration #1 chosen from 1 choice
[ 1.059224] hub 5-0:1.0: USB hub found
[ 1.059231] hub 5-0:1.0: 2 ports detected
[ 1.059282] alloc irq_desc for 18 on node -1
[ 1.059284] alloc kstat_irqs on node -1
[ 1.059290] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.059298] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.059302] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.059313] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 1.059348] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c000
[ 1.059385] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.059388] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.059390] usb usb6: Product: UHCI Host Controller
[ 1.059393] usb usb6: Manufacturer: Linux 2.6.32-3-amd64 uhci_hcd
[ 1.059395] usb usb6: SerialNumber: 0000:00:1d.2
[ 1.059460] usb usb6: configuration #1 chosen from 1 choice
[ 1.059491] hub 6-0:1.0: USB hub found
[ 1.059498] hub 6-0:1.0: 2 ports detected
[ 1.059982] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.059985] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 1.060664] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.060698] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.060702] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.060713] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 7
[ 1.060752] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.064647] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 1.064654] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfcbfbc00
[ 1.113018] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.113067] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.113070] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.113074] usb usb7: Product: EHCI Host Controller
[ 1.113076] usb usb7: Manufacturer: Linux 2.6.32-3-amd64 ehci_hcd
[ 1.113079] usb usb7: SerialNumber: 0000:00:1a.7
[ 1.113181] usb usb7: configuration #1 chosen from 1 choice
[ 1.113218] hub 7-0:1.0: USB hub found
[ 1.113228] hub 7-0:1.0: 6 ports detected
[ 1.113312] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.113340] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.113345] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.113355] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
[ 1.113388] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.117264] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1.157021] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfcbfb800
[ 1.202133] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.202164] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.202167] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.202170] usb usb8: Product: EHCI Host Controller
[ 1.202173] usb usb8: Manufacturer: Linux 2.6.32-3-amd64 ehci_hcd
[ 1.202175] usb usb8: SerialNumber: 0000:00:1d.7
[ 1.202275] usb usb8: configuration #1 chosen from 1 choice
[ 1.202312] hub 8-0:1.0: USB hub found
[ 1.202321] hub 8-0:1.0: 6 ports detected
[ 1.353784] SCSI subsystem initialized
[ 1.496038] usb 7-5: new high speed USB device using ehci_hcd and address 2
[ 1.580017] libata version 3.00 loaded.
[ 1.583984] ahci 0000:00:1f.2: version 3.0
[ 1.584026] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.584088] alloc irq_desc for 28 on node -1
[ 1.584091] alloc kstat_irqs on node -1
[ 1.584104] ahci 0000:00:1f.2: irq 28 for MSI/MSI-X
[ 1.584142] ahci: SSS flag set, parallel bus scan disabled
[ 1.584174] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 1.584179] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ccc ems sxs
[ 1.584186] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.596924] scsi0 : ahci
[ 1.608803] scsi1 : ahci
[ 1.616740] scsi2 : ahci
[ 1.640093] scsi3 : ahci
[ 1.640438] ata1: SATA max UDMA/133 abar m2048@0xfcbfb000 port 0xfcbfb100 irq 28
[ 1.640443] ata2: SATA max UDMA/133 abar m2048@0xfcbfb000 port 0xfcbfb180 irq 28
[ 1.640446] ata3: DUMMY
[ 1.640448] ata4: DUMMY
[ 1.730957] usb 7-5: New USB device found, idVendor=04f2, idProduct=b036
[ 1.730962] usb 7-5: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 1.730966] usb 7-5: Product: USB2.0 0.3M UVC WebCam
[ 1.730969] usb 7-5: Manufacturer: Chicony Electronics Co., Ltd.
[ 1.730971] usb 7-5: SerialNumber: SN0001
[ 1.731070] usb 7-5: configuration #1 chosen from 1 choice
[ 1.960024] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.961564] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.961754] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 1.961758] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2.013910] ata1.00: ATA-8: ST9500325AS, 0002SDM1, max UDMA/133
[ 2.013914] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.016394] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2.016707] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 2.016711] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2.018558] ata1.00: configured for UDMA/133
[ 2.032119] scsi 0:0:0:0: Direct-Access ATA ST9500325AS 0002 PQ: 0 ANSI: 5
[ 2.128011] usb 6-1: new low speed USB device using uhci_hcd and address 2
[ 2.302358] usb 6-1: New USB device found, idVendor=09da, idProduct=000a
[ 2.302362] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.302365] usb 6-1: Product: USB Optical Mouse
[ 2.302367] usb 6-1: Manufacturer: A4Tech
[ 2.302441] usb 6-1: configuration #1 chosen from 1 choice
[ 2.760024] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.765208] ata2.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 2.765213] ata2.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2.770060] ata2.00: ATAPI: HL-DT-ST DVDRAM GU10N, MR03, max UDMA/133, ATAPI AN
[ 2.775483] ata2.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 2.775488] ata2.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2.780424] ata2.00: configured for UDMA/133
[ 2.799006] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GU10N MR03 PQ: 0 ANSI: 5
[ 2.803544] usbcore: registered new interface driver hiddev
[ 2.803619] usbcore: registered new interface driver usbhid
[ 2.803622] usbhid: v2.6:USB HID core driver
[ 2.826040] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.826095] sd 0:0:0:0: [sda] Write Protect is off
[ 2.826099] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.826127] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.826289] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
[ 2.928109] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.942682] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.942687] Uniform CD-ROM driver Revision: 3.20
[ 2.942800] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.953907] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.953945] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.416683] PM: Starting manual resume from disk
[ 3.416687] PM: Resume from partition 8:6
[ 3.416689] PM: Checking hibernation image.
[ 3.416935] PM: Error -22 checking image file
[ 3.416937] PM: Resume from disk failed.
[ 3.453706] kjournald starting. Commit interval 5 seconds
[ 3.453716] EXT3-fs: mounted filesystem with ordered data mode.
[ 5.197376] udev: starting version 154
[ 6.003677] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 6.003964] cfg80211: Using static regulatory domain info
[ 6.003967] cfg80211: Regulatory domain: US
[ 6.003969] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.003973] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 6.003977] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.003980] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.003983] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.003986] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 6.003990] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 6.004001] cfg80211: Calling CRDA for country: US
[ 6.019602] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 6.019661] ACPI: Sleep Button [SLPB]
[ 6.019723] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input4
[ 6.026318] atl1c 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.026334] atl1c 0000:04:00.0: setting latency timer to 64
[ 6.035125] ACPI: SSDT 00000000bdd9c6f0 001C4 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 6.035966] ACPI: SSDT 00000000bdd9c950 00765 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 6.058166] ACPI: Lid Switch [LID]
[ 6.084043] Monitor-Mwait will be used to enter C-1 state
[ 6.095238] agpgart-intel 0000:00:00.0: Intel Mobile Intel® GM45 Express Chipset
[ 6.096515] agpgart-intel 0000:00:00.0: detected 32764K stolen memory
[ 6.102080] ACPI: AC Adapter [AC0] (on-line)
[ 6.124916] atl1c 0000:04:00.0: version 1.0.0.1-NAPI
[ 6.152023] Monitor-Mwait will be used to enter C-3 state
[ 6.152043] Marking TSC unstable due to TSC halts in idle
[ 6.153175] processor LNXCPU:00: registered as cooling_device0
[ 6.153253] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 6.153306] ACPI: Power Button [PWRF]
[ 6.154095] ACPI: SSDT 00000000bdd9c620 000CC (v01 PmRef Cpu1Ist 00003000 INTL 20051117)
[ 6.154652] ACPI: SSDT 00000000bdd9c8c0 00085 (v01 PmRef Cpu1Cst 00003000 INTL 20051117)
[ 6.216042] Switching to clocksource hpet
[ 6.249117] processor LNXCPU:01: registered as cooling_device1
[ 6.340559] ACPI: Battery Slot [BAT0] (battery present)
[ 6.346083] ACPI: WMI: Mapper loaded
[ 6.346832] Asus Laptop ACPI Extras version 0.30
[ 6.356512] input: A4Tech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.2/usb6/6-1/6-1:1.0/input/input6
[ 6.356621] a4tech 0003:09DA:000A.0001: input,hidraw0: USB HID v1.10 Mouse [A4Tech USB Optical Mouse] on usb-0000:00:1d.2-1/input0
[ 6.382414] unsupported model UL80VT, trying default values
[ 6.382417] send /proc/acpi/dsdt to the developers
[ 6.708688] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 6.738570] [drm] Initialized drm 1.1.0 20060810
[ 6.748412] asus_laptop: Asus Laptop Support version 0.42
[ 6.754844] asus_laptop: UL80VT model detected
[ 6.756101] input: Asus Laptop extra buttons as /devices/virtual/input/input7
[ 6.756482] asus_laptop: Brightness ignored, must be controlled by ACPI video driver
[ 6.844209] iwlagn: Intel(R) Wireless WiFi Link AGN driver for Linux, 1.3.27ks
[ 6.844213] iwlagn: Copyright(c) 2003-2009 Intel Corporation
[ 6.844319] iwlagn 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.844355] iwlagn 0000:03:00.0: setting latency timer to 64
[ 6.844456] iwlagn 0000:03:00.0: Detected Intel Wireless WiFi Link 1000 Series BGN REV=0x6C
[ 6.867478] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 6.867493] i915 0000:00:02.0: setting latency timer to 64
[ 6.878658] iwlagn 0000:03:00.0: Tunable channels: 13 802.11bg, 0 802.11a channels
[ 6.878724] alloc irq_desc for 29 on node -1
[ 6.878727] alloc kstat_irqs on node -1
[ 6.878749] iwlagn 0000:03:00.0: irq 29 for MSI/MSI-X
[ 6.887753] mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining
[ 6.887757] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 6.887817] alloc irq_desc for 30 on node -1
[ 6.887820] alloc kstat_irqs on node -1
[ 6.887829] i915 0000:00:02.0: irq 30 for MSI/MSI-X
[ 6.887843] [drm] set up 31M of stolen space
[ 7.335839] input: ImPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio4/input/input8
[ 7.509724] [drm] LVDS-8: set mode 1366x768 e
[ 7.544812] phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 7.583575] Linux video capture interface: v2.00
[ 7.727891] Console: switching to colour frame buffer device 170x48
[ 7.731863] fb0: inteldrmfb frame buffer device
[ 7.731865] registered panic notifier
[ 7.734953] ACPI Warning: _BQC returned an invalid level (20090903/video-631)
[ 7.741182] acpi device:35: registered as cooling_device2
[ 7.741421] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[ 7.741478] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 7.743710] ACPI Warning: _BQC returned an invalid level (20090903/video-631)
[ 7.746441] uvcvideo: Found UVC 1.00 device USB2.0 0.3M UVC WebCam (04f2:b036)
[ 7.750036] input: USB2.0 0.3M UVC WebCam as /devices/pci0000:00/0000:00:1a.7/usb7/7-5/7-5:1.0/input/input10
[ 7.750163] usbcore: registered new interface driver uvcvideo
[ 7.750217] USB Video Class driver (v0.1.0)
[ 7.750430] acpi device:38: registered as cooling_device3
[ 7.750679] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:37/LNXVIDEO:01/input/input11
[ 7.750717] ACPI: Video Device [VGA1] (multi-head: yes rom: yes post: no)
[ 7.750745] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 7.844473] alloc irq_desc for 22 on node -1
[ 7.844476] alloc kstat_irqs on node -1
[ 7.844485] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 7.844554] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 8.337040] hda_codec: ALC269: BIOS auto-probing.
[ 8.337626] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input12
[ 8.339898] HDA Intel 0000:01:00.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 8.339970] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 10.326627] Adding 499704k swap on /dev/sda6. Priority:-1 extents:1 across:499704k
[ 10.499681] EXT3 FS on sda7, internal journal
[ 10.627252] loop: module loaded
[ 11.223293] kjournald starting. Commit interval 5 seconds
[ 11.223747] EXT3 FS on sda5, internal journal
[ 11.223752] EXT3-fs: mounted filesystem with ordered data mode.
[ 12.999791] fuse init (API version 7.13)
[ 17.102236] Bluetooth: Core ver 2.15
[ 17.102283] NET: Registered protocol family 31
[ 17.102286] Bluetooth: HCI device and connection manager initialized
[ 17.102289] Bluetooth: HCI socket layer initialized
[ 17.126958] Bluetooth: L2CAP ver 2.14
[ 17.126961] Bluetooth: L2CAP socket layer initialized
[ 17.150021] Bluetooth: RFCOMM TTY layer initialized
[ 17.150027] Bluetooth: RFCOMM socket layer initialized
[ 17.150031] Bluetooth: RFCOMM ver 1.11
[ 17.432756] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.432759] Bluetooth: BNEP filters: protocol multicast
[ 17.468262] Bridge firewalling registered
[ 17.587374] Bluetooth: SCO (Voice Link) ver 0.6
[ 17.587379] Bluetooth: SCO socket layer initialized
[ 20.822450] lp: driver loaded but no devices found
[ 20.869061] iwlagn 0000:03:00.0: firmware: requesting iwlwifi-1000-3.ucode
[ 20.881439] ppdev: user-space parallel port driver
[ 21.066037] iwlagn 0000:03:00.0: loaded firmware version 128.50.3.1
[ 21.148995] Registered led device: iwl-phy0::radio
[ 21.149032] Registered led device: iwl-phy0::assoc
[ 21.149156] Registered led device: iwl-phy0::RX
[ 21.149192] Registered led device: iwl-phy0::TX
[ 21.161564] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.135211] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none :o wns=io+mem
[ 24.135217] vgaarb: transferring owner from PCI:0000:00:02.0 to PCI:0000:01:00.0
[ 26.094838] alloc irq_desc for 31 on node -1
[ 26.094844] alloc kstat_irqs on node -1
[ 26.094870] atl1c 0000:04:00.0: irq 31 for MSI/MSI-X
[ 26.096151] ADDRCONF(NETDEV_UP): eth0: link is not ready
norbi123, wynik polecenia można przekierować do pliku, a plik w postaci załącznika przedstawić na forum,
dmesg >wynik.txt
