Setting up x11-common (1:7.5+6) ...
insserv: warning: script 'K07smfpd' missing LSB tags and overrides
insserv: warning: script 'smfpd' missing LSB tags and overrides
insserv: Starting smfpd depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: There is a loop between service rmnologin and mountnfs if started
insserv: loop involving service mountnfs at depth 6
insserv: loop involving service nfs-common at depth 5
insserv: There is a loop between service rmnologin and checkroot if started
insserv: loop involving service checkroot at depth 3
insserv: loop involving service keyboard-setup at depth 2
insserv: loop involving service urandom at depth 10
insserv: loop involving service gdm at depth 10
insserv: There is a loop between service rmnologin and mountall if started
insserv: loop involving service mountall at depth 5
insserv: loop involving service checkfs at depth 4
insserv: loop involving service hwclockfirst at depth 3
insserv: loop involving service networking at depth 7
insserv: loop involving service hostname at depth 4
insserv: There is a loop between service rmnologin and ifupdown-clean if started
insserv: loop involving service ifupdown-clean at depth 6
insserv: loop involving service mtab at depth 6
insserv: loop involving service module-init-tools at depth 6
insserv: There is a loop between service rmnologin and udev if started
insserv: loop involving service udev at depth 1
insserv: There is a loop at service smfpd if started
insserv: loop involving service mountkernfs at depth 1
insserv: There is a loop between service rmnologin and mountall-bootclean if started
insserv: loop involving service mountall-bootclean at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing x11-common (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
x11-common
A package failed to install. Trying to recover:
Setting up procps (1:3.2.8-9) ...
dpkg: error processing procps (--configure):
dpkg: dependency problems prevent configuration of iceweasel:
iceweasel depends on procps; however:
Package procps is not configured yet.
dpkg: error processing iceweasel (--configure):
dependency problems - leaving unconfigured
Setting up acpid (1:2.0.4-1) ...
dpkg: error processing acpid (--configure):
dpkg: dependency problems prevent configuration of gnumeric:
gnumeric depends on procps; however:
dpkg: error processing gnumeric (--configure):
dpkg: dependency problems prevent configuration of acpi-support-base:
acpi-support-base depends on acpid (>= 1.0.4); however:
Package acpid is not configured yet.
dpkg: error processing acpi-support-base (--configure):
Setting up cron (3.0pl1-110) ...
dpkg: error processing cron (--configure):
Setting up udev (154-1) ...
update-initramfs: deferring update (trigger activated)
dpkg: error processing udev (--configure):
dpkg: dependency problems prevent configuration of xserver-common:
xserver-common depends on x11-common; however:
Package x11-common is not configured yet.
dpkg: error processing xserver-common (--configure):
dpkg: dependency problems prevent configuration of xserver-xephyr:
xserver-xephyr depends on xserver-common (>= 2:1.7.7-1); however:
Package xserver-common is not configured yet.
dpkg: error processing xserver-xephyr (--configure):
dpkg: dependency problems prevent configuration of libsane:
libsane depends on udev (>= 0.88-1) | makedev (>= 2.3.1-58); however:
Package udev is not configured yet.
Package makedev is not installed.
dpkg: error processing libsane (--configure):
dpkg: dependency problems prevent configuration of initramfs-tools:
initramfs-tools depends on udev (>= 0.086-1); however:
dpkg: error processing initramfs-tools (--configure):
dpkg: dependency problems prevent configuration of bluez:
bluez depends on udev | makedev; however:
dpkg: error processing bluez (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-core:
xserver-xorg-core depends on xserver-common (>= 2:1.7.7-1); however:
xserver-xorg-core depends on udev (>= 149); however:
dpkg: error processing xserver-xorg-core (--configure):
dpkg: dependency problems prevent configuration of libudev0:
libudev0 depends on udev (= 154-1); however:
dpkg: error processing libudev0 (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-radeonhd:
xserver-xorg-video-radeonhd depends on xorg-video-abi-6.0; however:
Package xorg-video-abi-6.0 is not installed.
Package xserver-xorg-core which provides xorg-video-abi-6.0 is not configured yet.
xserver-xorg-video-radeonhd depends on xserver-xorg-core (>= 2:1.7.6.901); however:
Package xserver-xorg-core is not configured yet.
dpkg: error processing xserver-xorg-video-radeonhd (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-savage:
xserver-xorg-video-savage depends on xorg-video-abi-6.0; however:
xserver-xorg-video-savage depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-savage (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-fbdev:
xserver-xorg-video-fbdev depends on xorg-video-abi-6.0; however:
xserver-xorg-video-fbdev depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-fbdev (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg:
xserver-xorg depends on xserver-xorg-core (>= 2:1.7); however:
dpkg: error processing xserver-xorg (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-all:
xserver-xorg-video-all depends on xserver-xorg-video-fbdev; however:
Package xserver-xorg-video-fbdev is not configured yet.
xserver-xorg-video-all depends on xserver-xorg-video-savage; however:
Package xserver-xorg-video-savage is not configured yet.
dpkg: error processing xserver-xorg-video-all (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-vesa:
xserver-xorg-video-vesa depends on xorg-video-abi-6.0; however:
xserver-xorg-video-vesa depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-vesa (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-sisusb:
xserver-xorg-video-sisusb depends on xorg-video-abi-6.0; however:
xserver-xorg-video-sisusb depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-sisusb (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-tdfx:
xserver-xorg-video-tdfx depends on xorg-video-abi-6.0; however:
xserver-xorg-video-tdfx depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-tdfx (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-ark:
xserver-xorg-video-ark depends on xorg-video-abi-6.0; however:
xserver-xorg-video-ark depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-ark (--configure):
dpkg: dependency problems prevent configuration of gnome-bluetooth:
gnome-bluetooth depends on bluez (>= 4.36); however:
Package bluez is not configured yet.
gnome-bluetooth depends on udev (>= 146); however:
dpkg: error processing gnome-bluetooth (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-cirrus:
xserver-xorg-video-cirrus depends on xorg-video-abi-6.0; however:
xserver-xorg-video-cirrus depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-cirrus (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-r128:
xserver-xorg-video-r128 depends on xorg-video-abi-6.0; however:
xserver-xorg-video-r128 depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-r128 (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-neomagic:
xserver-xorg-video-neomagic depends on xorg-video-abi-6.0; however:
xserver-xorg-video-neomagic depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-neomagic (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-nouveau:
xserver-xorg-video-nouveau depends on xorg-video-abi-6.0; however:
xserver-xorg-video-nouveau depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-nouveau (--configure):
dpkg: dependency problems prevent configuration of gvfs:
gvfs depends on libudev0 (>= 0.140); however:
Package libudev0 is not configured yet.
dpkg: error processing gvfs (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-mga:
xserver-xorg-video-mga depends on xorg-video-abi-6.0; however:
xserver-xorg-video-mga depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-mga (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-i128:
xserver-xorg-video-i128 depends on xorg-video-abi-6.0; however:
xserver-xorg-video-i128 depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-i128 (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-s3:
xserver-xorg-video-s3 depends on xorg-video-abi-6.0; however:
xserver-xorg-video-s3 depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-s3 (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-trident:
xserver-xorg-video-trident depends on xorg-video-abi-6.0; however:
xserver-xorg-video-trident depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-trident (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-chips:
xserver-xorg-video-chips depends on xorg-video-abi-6.0; however:
xserver-xorg-video-chips depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-chips (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-intel:
xserver-xorg-video-intel depends on xorg-video-abi-6.0; however:
xserver-xorg-video-intel depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-intel (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-mach64:
xserver-xorg-video-mach64 depends on xorg-video-abi-6.0; however:
xserver-xorg-video-mach64 depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-mach64 (--configure):
dpkg: dependency problems prevent configuration of alsa-base:
alsa-base depends on udev; however:
dpkg: error processing alsa-base (--configure):
dpkg: dependency problems prevent configuration of gnome-applets:
gnome-applets depends on gvfs; however:
Package gvfs is not configured yet.
dpkg: error processing gnome-applets (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-siliconmotion:
xserver-xorg-video-siliconmotion depends on xorg-video-abi-6.0; however:
xserver-xorg-video-siliconmotion depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-siliconmotion (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-tseng:
xserver-xorg-video-tseng depends on xorg-video-abi-6.0; however:
xserver-xorg-video-tseng depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-tseng (--configure):
dpkg: dependency problems prevent configuration of sane-utils:
sane-utils depends on libsane (>= 1.0.11-3); however:
Package libsane is not configured yet.
dpkg: error processing sane-utils (--configure):
dpkg: dependency problems prevent configuration of gvfs-bin:
gvfs-bin depends on gvfs (= 1.6.1-1); however:
dpkg: error processing gvfs-bin (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-sis:
xserver-xorg-video-sis depends on xorg-video-abi-6.0; however:
xserver-xorg-video-sis depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-sis (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-apm:
xserver-xorg-video-apm depends on xorg-video-abi-6.0; however:
xserver-xorg-video-apm depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-apm (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-voodoo:
xserver-xorg-video-voodoo depends on xorg-video-abi-6.0; however:
xserver-xorg-video-voodoo depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-voodoo (--configure):
dpkg: dependency problems prevent configuration of libgudev-1.0-0:
libgudev-1.0-0 depends on libudev0 (>= 146); however:
dpkg: error processing libgudev-1.0-0 (--configure):
dpkg: dependency problems prevent configuration of xserver-xorg-video-s3virge:
xserver-xorg-video-s3virge depends on xorg-video-abi-6.0; however:
xserver-xorg-video-s3virge depends on xserver-xorg-core (>= 2:1.7.6.901); however:
dpkg: error processing xserver-xorg-video-s3virge (--configure):
dpkg: dependency problems prevent configuration of xorg:
xorg depends on xserver-xorg; however:
Package xserver-xorg is not configured yet.
dpkg: error processing xorg (--configure):
dpkg: dependency problems prevent configuration of brasero:
brasero depends on gvfs; however:
dpkg: error processing brasero (--configure):
dpkg: dependency problems prevent configuration of libcheese-gtk18:
libcheese-gtk18 depends on libgudev-1.0-0 (>= 146); however:
Package libgudev-1.0-0 is not configured yet.
dpkg: error processing libcheese-gtk18 (--configure):
dpkg: too many errors, stopping
procps
iceweasel
x11-common
acpid
gnumeric
acpi-support-base
cron
udev
xserver-common
xserver-xephyr
libsane
initramfs-tools
bluez
xserver-xorg-core
libudev0
xserver-xorg
gnome-bluetooth
gvfs
alsa-base
gnome-applets
sane-utils
gvfs-bin
libgudev-1.0-0
xorg
brasero
libcheese-gtk18
Processing was halted because there were too many errors.
E: x11-common: subprocess installed post-installation script returned error exit status 1To sie pojawiło jakiś czas temu i za bardzo nie pamiętam podczas której instalacji pakietów.
Czy X11 ma coś z tym wspólnego?
