Sterowniki do karty dźwi
wornock
Sterowniki do karty dźwiękowej Asus Xonar DS
Post autor: wornock »
Dobry wieczór.
Szukam sterowników do karty dźwiękowej Asus Xonar DS. Debiana mam od 3 dni więc potrzebowałbym również instrukcji instalacji takich sterowników.
Debiana mam wersje squeeze, jądro 2.6.32-3-amd64
Proszę o pomoc.
Pozdrawiam, Patryk
Przedstaw takie informacje:
http://forum.dug.net.pl/viewtopic.php?p ... 74#p136174
jak w podanym odnośniku.
wornock
chello087207089118:/home/patryk# [B]lspci[/B]
00:00.0 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a1)
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3)
00:02.1 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3)
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1)
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2)
00:07.0 Bridge: nVidia Corporation MCP61 Ethernet (rev a2)
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2)
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
01:07.0 Multimedia audio controller: C-Media Electronics Inc CMI8788 [Oxygen HD Audio]
02:00.0 VGA compatible controller: ATI Technologies Inc RV730XT [Radeon HD 4670]
02:00.1 Audio device: ATI Technologies Inc RV710/730
chello087207089118:/home/patryk# [B]lspci -n[/B]
00:00.0 0500: 10de:03ea (rev a1)
00:01.0 0601: 10de:03e0 (rev a2)
00:01.1 0c05: 10de:03eb (rev a2)
00:01.2 0500: 10de:03f5 (rev a2)
00:02.0 0c03: 10de:03f1 (rev a3)
00:02.1 0c03: 10de:03f2 (rev a3)
00:04.0 0604: 10de:03f3 (rev a1)
00:06.0 0101: 10de:03ec (rev a2)
00:07.0 0680: 10de:03ef (rev a2)
00:08.0 0101: 10de:03f6 (rev a2)
00:09.0 0604: 10de:03e8 (rev a2)
00:18.0 0600: 1022:1200
00:18.1 0600: 1022:1201
00:18.2 0600: 1022:1202
00:18.3 0600: 1022:1203
00:18.4 0600: 1022:1204
01:07.0 0401: 13f6:8788
02:00.0 0300: 1002:9490
02:00.1 0403: 1002:aa38
chello087207089118:/home/patryk# [B]cat /proc/asound/cards[/B]
 0 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xfddfc000 irq 16
chello087207089118:/home/patryk# [B]cat /proc/asound/modules[/B]
 0 snd_hda_intel
chello087207089118:/home/patryk# [B]cat /proc/asound/version[/B]
Advanced Linux Sound Architecture Driver Version 1.0.21.
chello087207089118:/home/patryk# [B]uname -a[/B]
Linux chello087207089118 2.6.32-3-amd64 #1 SMP Wed Feb 24 18:07:42 UTC 2010 x86_64 GNU/Linux
chello087207089118:/home/patryk# [B]dpkg -l | grep alsa[/B]
ii  alsa-base                            1.0.21+dfsg-2                  ALSA driver configuration files
ii  alsa-utils                           1.0.22-1                       Utilities for configuring and using ALSA
ii  libsdl1.2debian-alsa                 1.2.14-6                       Simple DirectMedia Layer (with X11 and ALSA options)
chello087207089118:/home/patryk# [B]dpkg -l | grep pulse[/B]
ii  libpulse-mainloop-glib0              0.9.21-1                       PulseAudio client libraries (glib support)
ii  libpulse0                            0.9.21-1                       PulseAudio client libraries
ilin
Post autor: ilin »
Odpal w jednym terminalu
speaker-test
W drugim
alsamixer
Pobaw się suwakami i przełącznikami (klawisz m na klawiaturze) w alsamixerze.
Być może uslyszysz szum który generuje speaker-test.
Jeśli dxwiek się nie pojawi podaj jeszcze chip karty z alsamixera.
Unit
Post autor: Unit »
Według tej stronki Xonar DS działa z ALSA w wersji 1.0.23 bądź jajem w wersji 2.6.34.
ilin
Post autor: ilin »
Wg tej
Wklejając id karty ze znacznie wcześniejszym ale kto wie być może.
Na razie niech zrobi to co zaproponowałem jak nie będzie dźwięku to będziemy się dalej zastanawiać.
Te najnowsze stery zdaje się nie chcą się kompilować na tym jaju 64bit.
wornock
Zrobiłem tak jak napisałeś. Wybrałem m i żadnych suwaków nie widać.
Po wciśnięciu F6 mam jeszcze coś takiego:
ilin
Post autor: ilin »
Wygląda ze ten sterownik nie radzi sobie z tą kartą.
Spróbuj skompilować najnowszy sterownik
nonnotus
Post autor: nonnotus »
Trochę odkopię temat. Z tej strony:
http://www.alsa-project.org/main/index. ... endor-Asus dowiedziałem się, że xonar ds wymaga innej wersji alsy, niż posiadam (Squeeze). Na tej stronie jest instrukcja jak to trzeba uruchomić żeby działało:
http://www.alsa-project.org/main/index. ... e-virtuoso
Z mojej znajomości angielskiego, zrozumiałem, że mam zainstalować dwa pakiety. Ale potem coś napisane jest o modułach. Niestety nie za bardzo to rozumiem. Czy ktoś może mi wyjaśnić to zagadnienie.
ilin
Post autor: ilin »
Jeśli masz Squeeze to zainstaluj jądro z backportów.
Tam już powinien być sterownik w odpowiedniej wersji.
