Postfix nie wysy
hajtek
Postfix nie wysyła poczty do interii
Post autor: hajtek »
Witam, mam problem z wysyłaniem maili do interia.pl, wszędzie indziej wysyła np. o2. gmail wp onet. Co do odbierania poczty to odbiera od wszystkich.
Jak probuje wysłać poczte na adres interii to wyskakuje mi:
This is the mail system at host debian.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
                   The mail system
<[url=http://kingcomp.pl/poczta/src/compose.php?send_to=jarusg%40interia.pl]user@interia.pl[/URL]>: host mx.interia.pl[217.74.65.64] said: 504 5.5.2 <debian>:
    Helo command rejected: need fully-qualified hostname (in reply to RCPT TO
    command)
Tu jeszcze daje main.cf:
command_directory = /usr/sbin
mail_owner = postfix
mydomain = kingcomp.pl
myhostname = debian
myorigin = /etc/mailname
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain,
mynetworks = 127.0.0.0/8 95.51.143.210
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relayhost =
#AUTH SMTP
smtpd_sasl_type = dovecot
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions =
    permit_mynetworks,
    permit_sasl_authenticated,
    reject_unauth_destination,
    reject_unknown_recipient_domain,
    reject_non_fqdn_recipient,
#    reject_unknown_hostname,
#    reject_non_fqdn_hostname
    reject_rbl_client dynamic.rbl.tld,
    reject_rhsbl_client revdns.rbl.tld,
    reject_rhsbl_helo revdns.rbl.tld,
    reject_rbl_client sbl-xbl.spamhaus.org,
    reject_rbl_client bl.spamcop.net
smtpd_client_restrictions =
    #reject_unknown_client,
    reject_rbl_client dul.dnsbl.sorbs.net,
    reject_rbl_client list.dsbl.org,
    reject_rbl_client sbl.spamhaus.org,
    reject_rbl_client cbl.abuseat.org
smtpd_sender_restrictions =
    reject_unknown_sender_domain,
    reject_non_fqdn_sender,
    reject_unknown_address
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
mtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
Co może to powodować?
Pacek
Post autor: Pacek »
Żle skonfigurowany DNS. Aby mieć serwer pocztowy zgodny z normami, trzeba mieć prawidłowy rekord MX w DNSie. U Ciebie serwer pocztowy przedstawia się domeną "debian". Niektóre serwery pocztowe (i pewnie tak jest w przyapdku interii) zgodnie ze swoją polityką antyspamową odrzucają pocztę z nieznanych lub nieprawidłowo skonfigurowanych serwerów pocztowych
