Zainstalowałem dzisiaj ISPcp 1.0.5 na moim VPS-ie, instalacja przebiegła bezproblemowo, ale jest trudność z odbieraniem maili. Wysyłam z VPS-a to dochodzą ale jak chcę wysłać na adres, który znajduje się na VPS-ie to nic nie ma. Z logów wyczytałem, że:
nie można użyć własnego hostaKod: Zaznacz cały
May 6 15:19:32 94 postfix[339]: fatal: unable to use my own hostname
May 6 21:23:24 94 postfix[16402]: fatal: file /etc/postfix/main.cf: parameter myhostname: bad parameter value: "ossto.orge.pl"
May 6 21:24:16 94 postfix/virtual[16504]: fatal: unable to use my own hostname
May 6 21:26:24 94 postfix[16533]: fatal: file /etc/postfix/main.cf: parameter myhostname: bad parameter value: 94.23.90.133
May 6 21:27:04 94 postfix/virtual[16634]: fatal: unable to use my own hostname
May 6 21:28:19 94 postfix/virtual[16738]: fatal: unable to use my own hostname
May 6 21:29:23 94 postfix/virtual[16848]: fatal: unable to use my own hostname
May 6 21:32:13 94 postfix[16955]: fatal: unable to use my own hostname
May 6 21:32:47 94 postfix/virtual[17052]: fatal: unable to use my own hostname
May 6 21:32:47 94 postfix/virtual[17053]: fatal: unable to use my own hostname
May 6 21:37:47 94 postfix/virtual[17090]: fatal: unable to use my own hostname
May 6 21:37:47 94 postfix/virtual[17091]: fatal: unable to use my own hostname
# Postfix directory settings; These are critical for normal Postfix MTA functionallity
command_directory = /usr/sbin
daemon_directory = /usr/lib/postfix
# Some common configuration parameters
inet_interfaces = all
mynetworks_style = host
myhostname = ossto.orge.pl
mydomain = ossto.orge.pl.local
myorigin = $myhostname
smtpd_banner = $myhostname ESMTP ispCP 1.0.5 OMEGA Managed
setgid_group = postdrop
# Receiving messages parameters
mydestination = $myhostname, $mydomain
append_dot_mydomain = no
append_at_myorigin = yes
local_transport = local
virtual_transport = virtual
transport_maps = hash:/etc/postfix/ispcp/transport
# Delivering local messages parameters
mail_spool_directory = /var/mail
# Mailboxquota
# => 0 for unlimited
# => 104857600 for 100 MB
mailbox_size_limit = 0
mailbox_command = procmail -a "$EXTENSION"
# Message size limit
message_size_limit = 0
biff = no
recipient_delimiter = +
local_destination_recipient_limit = 1
local_recipient_maps = unix :p asswd.byname $alias_database
# ispCP Autoresponder parameters
ispcp-arpl_destination_recipient_limit = 1
# Delivering virtual messages parameters
virtual_mailbox_base = /var/mail/virtual
virtual_mailbox_limit = 0
virtual_mailbox_domains = hash:/etc/postfix/ispcp/domains
virtual_mailbox_maps = hash:/etc/postfix/ispcp/mailboxes
virtual_alias_maps = hash:/etc/postfix/ispcp/aliases
virtual_minimum_uid = 1000
virtual_uid_maps = static:1000
virtual_gid_maps = static:8
# SASL paramters
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain =
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks,
permit_sasl_authenticated,
reject_invalid_helo_hostname,
reject_non_fqdn_helo_hostname
smtpd_sender_restrictions = reject_non_fqdn_sender,
reject_unknown_sender_domain,
permit_mynetworks,
smtpd_recipient_restrictions = reject_non_fqdn_recipient,
reject_unknown_recipient_domain,
permit_mynetworks,
reject_unauth_destination,
reject_unlisted_recipient,
check_policy_service inet:127.0.0.1:12525,
check_policy_service inet:127.0.0.1:60000,
permit
smtpd_data_restrictions = reject_multi_recipient_bounce,
reject_unauth_pipelining
# TLS parameters; activate, if avaible/used
#smtpd_tls_security_level = may
#smtpd_tls_loglevel = 2
#smtpd_tls_cert_file = /etc/postfix/cert.pem
#smtpd_tls_key_file = /etc/postfix/privkey.pem
#smtpd_tls_auth_only = no
#smtpd_tls_received_header = yes
# AMaViS parameters; activate, if available/used
#content_filter = amavis:[127.0.0.1]:10024
# Quota support; activate, if available/used
#virtual_create_maildirsize = yes
#virtual_mailbox_extended = yes
#virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
#virtual_mailbox_limit_override = yes
#virtual_maildir_limit_message = "The user you're trying to reach is over mailbox quota."
#virtual_overquota_bounce = yes
