- Generuję na użytkowniku:
"bacuser" klucz ssh-keygen -t rsa - Kopiowanie na zdalny serwer dla użytkownika "bacuser"
scp /home/użytkownik/.ssh/id_rsa.pub użytkownik@zdalny_serwer:~/ - Logowanie na zdalny serwer:
ssh użytkownik@zdalny_serwer - Dopisanie klucza:
cat ~/id_rsa.pub >> ~/.ssh/authorized_keys
# Package generated configuration file
# See the sshd(8) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2 - zmieniamy aby bylo mozliwe logowanie (no)
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords - domyslnie chasz i yes
#PasswordAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# UsePAM yes
Po wpisaniu:
debian:/# ssh -i /home/bacuser/.ssh/authorized_keys bacuser[EMAIL="pmielcza@192.168.1.7"]@192.168.1.7[/EMAIL]
Warning: Identity file /home/bacuser/.ssh/authorized_keys not accessible: No such file or directory.
bacuser@192.168.1.7's password:lub:
debian:/# ssh [EMAIL="bacuser@192.168.1.7"]bacuser@192.168.1.7[/EMAIL]
