Skonfigurowałem Bind9 na Ubuntu Server 10.04LTS beta1. Z tego co widzę w pliku named.conf.options w katalogu /var/log/named/ powinienem mieć logi z różnych zdarzeń DNS-a natomiast nie mam katalogu named. Czy nie powien on się utworzyć automatycznie podczas instalacji Bind-a ? W pliku named.conf dodałem wpis
include "/etc/bind/named.conf.options";Kod: Zaznacz cały
options {
directory "/var/cache/bind";
// If there is a firewall between you and nameservers you want
// to talk to, you might need to uncomment the query-source
// directive below. Previous versions of BIND always asked
// questions using port 53, but BIND 8.1 and later use an unprivileged
// port by default.
query-source port * ;
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
auth-nxdomain yes; # conform to RFC1035
// By default, name servers should only perform recursive domain
// lookups for their direct clients. If recursion is left open
// to the entire Internet, your name server could be used to
// perform distributed denial of service attacks against other
// innocent computers. For more information on DDoS recursion:
// http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-0987
version "Microsoft DNS Server v1.5 (WinME)";
logging {
channel security_file { file "/var/log/named/security.log" versions 3 size 30m; severity dynamic; print-time yes; };
channel default_file { file "/var/log/named/default.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel general_file { file "/var/log/named/general.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel database_file { file "/var/log/named/database.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel security_file { file "/var/log/named/security.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel config_file { file "/var/log/named/config.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel resolver_file { file "/var/log/named/resolver.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel xfer-in_file { file "/var/log/named/xfer-in.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel xfer-out_file { file "/var/log/named/xfer-out.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel notify_file { file "/var/log/named/notify.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel client_file { file "/var/log/named/client.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel unmatched_file { file "/var/log/named/unmatched.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel queries_file { file "/var/log/named/queries.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel network_file { file "/var/log/named/network.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel update_file { file "/var/log/named/update.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel dispatch_file { file "/var/log/named/dispatch.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel dnssec_file { file "/var/log/named/dnssec.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel lame-servers_file { file "/var/log/named/lame-servers.log" versions 3 size 5m; severity dynamic; print-time yes; };
category security { security_file; };
category default { default_file; };
category general { general_file; };
category database { database_file; };
category config { config_file; };
category resolver { resolver_file; };
category xfer-in { xfer-in_file; };
category xfer-out { xfer-out_file; };
category notify { notify_file; };
category client { client_file; };
category unmatched { unmatched_file; };
category queries { queries_file; };
category network { network_file; };
category update { update_file; };
category dispatch { dispatch_file; };
category dnssec { dnssec_file; };
category lame-servers { lame-servers_file; };
