Mam problem z compizem. Jak w terminalu wpiszę:
compiz --replaceKod: Zaznacz cały
root@MichuPC:~# compiz --replace
Checking for Xgl: not present.
xset q doesn't reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:00.0 0300: 10de:0291 (rev a1) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Checking screen 1Comparing resolution (1280x1024) to maximum 3D texture size (4096): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: present.
Checking for FBConfig: present.
/usr/bin/compiz.real (core) - Warn: SmcOpenConnection failed: None of the authentication protocols specified are supported
Backend : ini
Integration : true
Profile : default
Adding plugins
Initializing core options...done
Ale jest różnie bo np. za drugim razem wyświetla się:
michu@MichuPC:~$ compiz --replace
Backend : ini
Integration : true
Profile : default
Adding plugins
Initializing annotate options...done
Initializing zoom options...done
Initializing gnomecompat options...done
Initializing decoration options...done
/usr/bin/compiz.real (core) - Error: Plugin 'core' has ABI version '20090207', expected ABI version '20090619'.
/usr/bin/compiz.real (mousepoll) - Error: InitObject failed
/usr/bin/compiz.real (core) - Error: Couldn't activate plugin 'mousepoll'
Initializing wobbly options...done
Initializing obs options...done
/usr/bin/compiz.real (cube) - Warn: Failed to load slide: /usr/share/gdm/themes/Human/ubuntu.png
Initializing cube options...done
Setting Update "active_plugins"
