B
DaVidoSS
Błąd skype przy próbie uruchomienia
Post autor: DaVidoSS »
Nie mogę za żadne skarby uruchomić Skype.
Próbowałem instalacji na wszystkie sposoby opisane na tym forum ale wciąż Skype, zaraz po zalogowaniu zamyka się wyświetlając błąd:
davidoss@debian-2010:~$ skype
Inconsistency detected by ld.so: dl-open.c: 643: _dl_open: Assertion `_dl_debug_initialize (0, args.nsid)->r_state == RT_CONSISTENT' failed!
Debian:
Linux debian-2010 2.6.32-3-amd64 #1 SMP Wed Feb 24 18:07:42 UTC 2010 x86_64 GNU/Linux
Skype:
skype-debian_2.1.0.81-1_i386.deb
Proszę o pomoc.
Tu jeszcze parę rzeczy jeśli to pomoże:
davidoss@debian-2010:~$ dpkg -l | grep pulse
ii  gstreamer0.10-pulseaudio             0.10.18-1                  GStreamer plugin for PulseAudio
ii  libpulse-browse0                     0.9.21-1                   PulseAudio client libraries (zeroconf support)
ii  libpulse-dev                         0.9.21-1                   PulseAudio client development headers and libraries
ii  libpulse-mainloop-glib0              0.9.21-1                   PulseAudio client libraries (glib support)
ii  libpulse0                            0.9.21-1                   PulseAudio client libraries
ii  pulseaudio                           0.9.21-1                   PulseAudio sound server
ii  pulseaudio-esound-compat             0.9.21-1                   PulseAudio ESD compatibility layer
ii  pulseaudio-module-gconf              0.9.21-1                   GConf module for PulseAudio sound server
ii  pulseaudio-module-hal                0.9.21-1                   HAL to udev transitioning module for PulseAudio sound server
ii  pulseaudio-module-jack               0.9.21-1                   jackd modules for PulseAudio sound server
ii  pulseaudio-module-lirc               0.9.21-1                   lirc module for PulseAudio sound server
ii  pulseaudio-module-x11                0.9.21-1                   X11 module for PulseAudio sound server
ii  pulseaudio-module-zeroconf           0.9.21-1                   Zeroconf module for PulseAudio sound server
ii  pulseaudio-utils                     0.9.21-1                   Command line tools for the PulseAudio sound server
davidoss@debian-2010:~$ dpkg -l | grep alsa
ii  alsa-base                            1.0.21+dfsg-2              ALSA driver configuration files
rc  alsa-source                          1.0.21+dfsg-2              ALSA driver sources
ii  alsa-utils                           1.0.22-1                   Utilities for configuring and using ALSA
ii  alsaplayer-alsa                      0.99.80-5                  PCM player designed for ALSA (ALSA output module)
ii  alsaplayer-common                    0.99.80-5                  PCM player designed for ALSA (common files)
ii  alsaplayer-gtk                       0.99.80-5                  PCM player designed for ALSA (GTK+ version)
ii  gstreamer0.10-alsa                   0.10.28-1                  GStreamer plugin for ALSA
rc  libsdl1.2debian-alsa                 1.2.13-5                   Simple DirectMedia Layer (with X11 and ALSA options)
ii  xmms2-plugin-alsa                    0.6DrMattDestruction-5+b1  XMMS2 - ALSA output
davidoss@debian-2010:~$ cat /proc/asound/modules
 0 snd_hda_intel
 1 snd_usb_audio
 2 snd_ca0106
davidoss@debian-2010:~$ cat /proc/asound/cards
 0 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xfebfc000 irq 18
 1 [U0x4710x329    ]: USB-Audio - USB Device 0x471:0x329
                      USB Device 0x471:0x329 at usb-0000:00:0b.0-2, full speed
 2 [CA0106         ]: CA0106 - CA0106
                      Audigy SE [SB0570] at 0xdc00 irq 16
davidoss@debian-2010:~$ cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version 1.0.21.
davidoss@debian-2010:~$ lspci
00:00.0 Host bridge: nVidia Corporation Device 0800 (rev b1)
00:00.1 RAM memory: nVidia Corporation Device 0808 (rev a1)
00:00.2 RAM memory: nVidia Corporation Device 0809 (rev a1)
00:00.3 RAM memory: nVidia Corporation Device 080a (rev a1)
00:00.4 RAM memory: nVidia Corporation Device 080b (rev a1)
00:00.5 RAM memory: nVidia Corporation Device 080c (rev b1)
00:00.6 RAM memory: nVidia Corporation Device 080d (rev a1)
00:00.7 RAM memory: nVidia Corporation Device 080e (rev a1)
00:01.0 RAM memory: nVidia Corporation Device 080f (rev a1)
00:01.1 RAM memory: nVidia Corporation Device 0810 (rev a1)
00:01.2 RAM memory: nVidia Corporation Device 0811 (rev a1)
00:01.3 RAM memory: nVidia Corporation Device 0812 (rev a1)
00:01.4 RAM memory: nVidia Corporation Device 0813 (rev a1)
00:01.5 RAM memory: nVidia Corporation Device 0814 (rev a1)
00:01.6 RAM memory: nVidia Corporation Device 081a (rev a1)
00:01.7 RAM memory: nVidia Corporation Device 080e (rev a1)
00:02.0 PCI bridge: nVidia Corporation Device 0815 (rev a1)
00:04.0 PCI bridge: nVidia Corporation Device 0817 (rev a1)
00:09.0 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a2)
00:0a.0 ISA bridge: nVidia Corporation MCP55 LPC Bridge (rev a3)
00:0a.1 SMBus: nVidia Corporation MCP55 SMBus (rev a3)
00:0b.0 USB Controller: nVidia Corporation MCP55 USB Controller (rev a1)
00:0b.1 USB Controller: nVidia Corporation MCP55 USB Controller (rev a2)
00:0d.0 IDE interface: nVidia Corporation MCP55 IDE (rev a1)
00:0e.0 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a3)
00:0e.1 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a3)
00:0e.2 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a3)
00:0f.0 PCI bridge: nVidia Corporation MCP55 PCI bridge (rev a2)
00:11.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a3)
00:12.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a3)
00:13.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:14.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:15.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:16.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:17.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:18.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
01:00.0 VGA compatible controller: nVidia Corporation GT200b [GeForce GTX 285] (rev a1)
03:05.0 Multimedia audio controller: Creative Labs CA0106 Soundblaster
05:00.0 FireWire (IEEE 1394): JMicron Technology Corp. IEEE 1394 Host Controller
06:00.0 SATA controller: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 03)
06:00.1 IDE interface: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 03)
07:00.0 PCI bridge: Creative Labs [SB X-Fi Xtreme Audio] CA0110-IBG PCI to PCIe Bridge
08:00.0 Audio device: Creative Labs [SB X-Fi Xtreme Audio] CA0110-IBG
davidoss@debian-2010:~$ lspci -n
00:00.0 0600: 10de:0800 (rev b1)
00:00.1 0500: 10de:0808 (rev a1)
00:00.2 0500: 10de:0809 (rev a1)
00:00.3 0500: 10de:080a (rev a1)
00:00.4 0500: 10de:080b (rev a1)
00:00.5 0500: 10de:080c (rev b1)
00:00.6 0500: 10de:080d (rev a1)
00:00.7 0500: 10de:080e (rev a1)
00:01.0 0500: 10de:080f (rev a1)
00:01.1 0500: 10de:0810 (rev a1)
00:01.2 0500: 10de:0811 (rev a1)
00:01.3 0500: 10de:0812 (rev a1)
00:01.4 0500: 10de:0813 (rev a1)
00:01.5 0500: 10de:0814 (rev a1)
00:01.6 0500: 10de:081a (rev a1)
00:01.7 0500: 10de:080e (rev a1)
00:02.0 0604: 10de:0815 (rev a1)
00:04.0 0604: 10de:0817 (rev a1)
00:09.0 0500: 10de:0369 (rev a2)
00:0a.0 0601: 10de:0360 (rev a3)
00:0a.1 0c05: 10de:0368 (rev a3)
00:0b.0 0c03: 10de:036c (rev a1)
00:0b.1 0c03: 10de:036d (rev a2)
00:0d.0 0101: 10de:036e (rev a1)
00:0e.0 0104: 10de:037f (rev a3)
00:0e.1 0104: 10de:037f (rev a3)
00:0e.2 0104: 10de:037f (rev a3)
00:0f.0 0604: 10de:0370 (rev a2)
00:11.0 0680: 10de:0373 (rev a3)
00:12.0 0680: 10de:0373 (rev a3)
00:13.0 0604: 10de:0376 (rev a3)
00:14.0 0604: 10de:0374 (rev a3)
00:15.0 0604: 10de:0374 (rev a3)
00:16.0 0604: 10de:0378 (rev a3)
00:17.0 0604: 10de:0375 (rev a3)
00:18.0 0604: 10de:0377 (rev a3)
01:00.0 0300: 10de:05e3 (rev a1)
03:05.0 0401: 1102:0007
05:00.0 0c00: 197b:2380
06:00.0 0106: 197b:2363 (rev 03)
06:00.1 0101: 197b:2363 (rev 03)
07:00.0 0604: 1102:7006
08:00.0 0403: 1102:0009
xmaster
Post autor: xmaster »
1. Wywal tego skypa, którego masz
2. Dodaj repozytoria Skypa
3. Zainstaluj z repozytoriów
4. Napisz czy działa
DaVidoSS
Niestety nie mogę znaleźć działającego repozytorium do Skype.
Błąd [url]http://download.skype.com[/url] stable/non-free Packages
  404  Not Found [IP: 130.117.72.43 80]
ArnVaker
Post autor: ArnVaker »
Bo w repozytorium są tylko paczki pod 32bit. Wersją rozwojową się nie bawiłem (jest gdzieś wątek na forum).
Ale za to ten działa u mnie od kopa => http://www.falooley.org/debian/pool/non ... _amd64.deb
DaVidoSS
Dziękuję. Działa i u mnie ale nie ma dźwięku. Jak przełączam w ustawieniach to się też zamyka.
ALSA lib ../../../src/control/control.c:867 :( snd_ctl_open_conf) Cannot open shared library /usr/lib32/alsa-lib/libasound_module_ctl_pulse.so
ALSA lib ../../src/confmisc.c:1286 :( snd_func_refer) Unable to find definition 'cards.USB-Audio.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib ../../src/conf.c:4154 :( _snd_config_evaluate) function snd_func_refer returned error: Nie ma takiego pliku ani katalogu
ALSA lib ../../src/conf.c:4633 :( snd_config_expand) Evaluate error: Nie ma takiego pliku ani katalogu
ALSA lib ../../../src/pcm/pcm.c:2211 :( snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib ../../../src/pcm/pcm.c:2171 :( snd_pcm_open_conf) Cannot open shared library /usr/lib32/alsa-lib/libasound_module_pcm_pulse.so
giaur
Post autor: giaur »
Problemem jest PulseAudio (jak zwykle zresztą, kolejny raz powtórzę że nie rozumiem sensu istnienia tego czegoś). Wyczyść system ze wszystkich klamotów związanych z tym czymś i zainstaluj najnowszą oficjalną wersję skype. Jeżeli masz system 64-bitowy to bierz wersje 64-bit dla Ubuntu, na Debianie działa bez zarzutu (przetestowane na Sidzie), zreszta nawet developerzy na forum Skype napisali ze nie ma kompilacji amd64 na debiana bo wersja ubuntowa działa również na debianie.
Taka uwaga, jeżeli upierasz się na wersję 32-bit na systemie 64-bitowym, to pewnie będziesz musiał ręcznie pousuwać smieci zwiazane z PulseAudio z katalogu /usr/lib32
DaVidoSS
Mam poważne problemy z dźwiękiem. Odinstalowałem pulseaudio jak przykazano, ale został jeden pakiet którego boję się usunąć:
davidoss@debian-2010:~$ sudo aptitude remove  libpulse0
Budowanie drzewa zależności
Odczyt opisów zadań... Gotowe
Następujące pakiety mają NIESPEŁNIONE zależności:
  kdebase-runtime kmix libasound2-plugins libpulse-mainloop-glib0 libsdl1.2debian-all libxine1-misc-plugins mplayer
Następujące pakiety zostaną USUNIĘTE:
  libpulse0
0 pakietów aktualizowanych, 0 instalowanych, 1 do usunięcia i 0 nie aktualizowanych.
Do pobrania 0B archiwów. Zwolnione po rozpakowaniu: 860kB.
  mplayer: Wymaga: libpulse0 (>= 0.9.21) którego nie można zainstalować
  libpulse-mainloop-glib0: Wymaga: libpulse0 (= 0.9.21-1) którego nie można zainstalować
  libxine1-misc-plugins: Wymaga: libpulse0 (>= 0.9.21) którego nie można zainstalować
  kdebase-runtime: Wymaga: libpulse0 (>= 0.9.21) którego nie można zainstalować
  libsdl1.2debian-all: Wymaga: libpulse0 (>= 0.9.16) którego nie można zainstalować
  libasound2-plugins: Wymaga: libpulse0 (>= 0.9.21) którego nie można zainstalować
  kmix: Wymaga: libpulse0 (>= 0.9.21) którego nie można zainstalować
Następujące działania rozwiążą problemy z zależnościami:
Usunięcie następujących pakietów:
dolphin
kappfinder
kde-config-gtk-style
kde-minimal
kde-window-manager
kdebase
kdebase-apps
kdebase-bin
kdebase-runtime
kdebase-workspace
kdebase-workspace-bin
kdebase-workspace-kgreet-plugins
kdepasswd
kdesudo
kdm
kfind
kinfocenter
klipper
kmix
konqueror
konqueror-nsplugins
konsole
kpackage
ksysguard
kwrite
libasound2-plugins
libkde4-ruby1.8
libkonq5
libkonqsidebarplugin4
libplasma-ruby
libplasma-ruby1.8
libsdl1.2debian-all
libsmokekde4-2
libsmokeplasma2
libxine1
libxine1-plugins
mplayer
phonon-backend-xine
plasma-dataengines-workspace
plasma-scriptengine-googlegadgets
plasma-scriptengine-javascript
plasma-scriptengine-python
plasma-scriptengine-qedje
plasma-scriptengine-ruby
plasma-scriptengine-superkaramba
plasma-scriptengine-webkit
plasma-scriptengines
plasma-widget-folderview
plasma-widgets-workspace
python-kde4
smplayer
smplayer-themes
smplayer-translations
system-config-printer-kde
systemsettings
Instalacja następujących pakietów:
libsdl1.2debian-esd [1.2.13-5 (testing)]
phonon-backend-null [4:4.3.1-5 (testing)]
Pozostawienie następujących problemów z zależnościami:
gtk-qt-engine poleca kde-config-gtk-style
kdelibs5 poleca kdebase-runtime (>= 4:4.2.95)
mplayer-skin-blue poleca mplayer
Wynik: -14271
Zaakceptować rozwiązanie? [T/n/q/?]
oraz drugi, którego wymaga kmix:
davidoss@debian-2010:~$ sudo aptitude remove  libpulse-mainloop-glib0
  kmix
Do pobrania 0B archiwów. Zwolnione po rozpakowaniu: 238kB.
  kmix: Wymaga: libpulse-mainloop-glib0 którego nie można zainstalować
kmix
Wynik: 119
Po tygodniu grzebania w poszukiwaniu dźwięku w Debianie, odkryłem że alsa instaluje mi kamerkę (mikrofon) domyślnie.
Pogoglowałem i znalazłem rozwiązanie.
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; /sbin/modprobe --quiet snd-seq ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; }
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modprobe --quiet snd-emu10k1-synth ; : ; }
# Prevent abnormal drivers from grabbing index 0
[B]options snd_ca0106 index=0[/B]
options bt87x index=-2
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
# Keep snd-pcsp from beeing loaded as first soundcard
options snd-pcsp index=-2
[B]options snd-usb-audio index=-2[/B]
Oto plik .asoundrc:
pcm.card0 {
    type hw
    card 0
ctl.card0 {
    type hw
    card 0
Niestety zaraz po restarcie robi się kompletny bałagan i muszę wymusić przeładowaniealsy:
davidoss@debian-2010:~$ sudo alsa force-reload
Unloading ALSA sound driver modules: snd-pcm-oss snd-mixer-oss snd-hda-intel snd-usb-audio snd-usb-lib snd-ca0106 snd-seq-midi snd-seq-midi-event snd-seq snd-rawmidi snd-seq-device snd-ac97-codec snd-hda-codec-ca0110 snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc.
Loading ALSA sound driver modules: snd-pcm-oss snd-mixer-oss snd-hda-intel snd-usb-audio snd-usb-lib snd-ca0106 snd-seq-midi snd-seq-midi-event snd-seq snd-rawmidi snd-seq-device snd-ac97-codec snd-hda-codec-ca0110 snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc.
kilka razy aby znowu się poustawiało jak należy czyli tak: (dodam ze za każdym razem jest inaczej)
 0 [CA0106         ]: CA0106 - CA0106
 1 [Generic        ]: HDA-Intel - HD-Audio Generic
 2 [U0x4710x329    ]: USB-Audio - USB Device 0x471:0x329
Ubuntowy Skype amd64 nie działa (ten sam błąd co w wersji dla Debiana).
Ale!
Działa ten co przedstawił ArnVaker, pod warunkiem że alsa poukłada urządzenia audio.
Za każdym razem po restarcie KDE chce usuwać urządzenia audio, gdyż jak twierdzi już nie występują.
Czy zechciałby ktoś pomóc mi z tym dźwiękiem, proszę?
Program konfiguracyjny Alsactl nie działa.
davidoss@debian-2010:~$ sudo alsactl init
alsactl: parse:1655: Unable to open file '/usr/share/alsa/init/ca0106': No such file or directory
davidoss@debian-2010:~$ ls /usr/share/alsa/init
00main  default  hda  help  info  test
