Na serwerze założyłem nowe konto i na nim (i tylko na nim, na wcześniej założonych nie ma problemu) mam coś takiego:
grzempa@d104747:~$ ls
ls: unrecognized prefix: do
ls: unparsable value for LS_COLORS environment variable
rkhunter.log
Rootkit 'SHV4'... [ Warning! ]
Found parts of this rootkit/trojan by checking the default files and directories
Please inspect the available files, by running this check with the parameter
--createlogfile and check the log file (current file: /dev/null).
Rootkit 'SHV5'... [ Warning! ]
[15:32:03] *** Start scan SHV4 ***
[15:32:03] - File /etc/ld.so.hash... OK. Not found.
[15:32:03] - File /lib/libext-2.so.7... OK. Not found.
[B][15:32:03] - File /lib/lidps1.so... WARNING! Exists.[/B]
[15:32:03] - File /usr/sbin/xntps... OK. Not found.
[15:32:03] - Directory /lib/security/.config... OK. Not found.
[15:32:03] - Directory /lib/security/.config/ssh... OK. Not found.
[15:32:12] *** Start scan SHV5 ***
[B][15:32:12] - File /etc/sh.conf... WARNING! Exists.[/B]
[15:32:12] - File /dev/srd0... OK. Not found.
[B][15:32:12] - Directory /usr/lib/libsh... WARNING! Exists.[/B]
