Podczas instalacji wybrałem opcje ,,system podstawowy'', ,,środowisko graficzne'' i ,,laptop'' (tak na wszelki wypadek, bo jest PCMCIA, choć to komputer stacjonarny). Pakiet pcmciautils jest zainstalowany, jednak nie aktywuje się. Jak próbuję ,,ręcznie'' uruchomić skrypt:
/etc/init.d/pcmciautilsKod: Zaznacz cały
No PCMCIA bridge module specified, failed!dmesg:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-2-686 (Debian 2.6.26-21) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Sat Dec 26 09:01:51 UTC 2009
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000017ffd800 (usable)
[ 0.000000] BIOS-e820: 0000000017ffd800 - 0000000017fffc00 (ACPI data)
[ 0.000000] BIOS-e820: 0000000017fffc00 - 0000000018000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 383MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 98301) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 98301
[ 0.000000] HighMem 98301 -> 98301
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 98301
[ 0.000000] On node 0 totalpages: 98301
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 736 pages used for memmap
[ 0.000000] Normal zone: 93469 pages, LIFO batch:31
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI not present or invalid.
[ 0.000000] ACPI: RSDP 000F6D20, 0014 (r0 PTLTD )
[ 0.000000] ACPI: RSDT 17FFDB26, 0028 (r1 PTLTD RSDT 1 PTL 1000000)
[ 0.000000] ACPI: FACP 17FFDB4E, 0074 (r1 FSC D1107 1 F4240)
[ 0.000000] ACPI: DSDT 17FFDBC2, 203E (r1 FSC D1107 1 MSFT 100000C)
[ 0.000000] ACPI: FACS 17FFFFC0, 0040
[ 0.000000] ACPI: PM-Timer IO Port: 0xf0c8
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 18000000:e7ff0000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] SMP: Allowing 0 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37992 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97533
[ 0.000000] Kernel command line: root=/dev/hda9 ro quiet
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] mapped APIC to ffffb000 (0130d000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 2048 (order: 11, 8192 bytes)
[ 0.000000] Detected 448.633 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Memory: 379844k/393204k available (1770k kernel code, 12848k reserved, 750k data, 244k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xd8800000 - 0xff7fe000 ( 623 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xd7ffd000 ( 383 MB)
[ 0.004000] .init : 0xc037f000 - 0xc03bc000 ( 244 kB)
[ 0.004000] .data : 0xc02baba9 - 0xc0376620 ( 750 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02baba9 (1770 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084605] Calibrating delay using timer specific routine.. 898.95 BogoMIPS (lpj=1797918)
[ 0.084785] Security Framework initialized
[ 0.084811] SELinux: Disabled at boot.
[ 0.084827] Capability LSM initialized
[ 0.084903] Mount-cache hash table entries: 512
[ 0.085535] Initializing cgroup subsys ns
[ 0.085553] Initializing cgroup subsys cpuacct
[ 0.085566] Initializing cgroup subsys devices
[ 0.085656] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.085673] CPU: L2 cache: 512K
[ 0.085688] Intel machine check architecture supported.
[ 0.085706] Intel machine check reporting enabled on CPU#0.
[ 0.085760] Checking 'hlt' instruction... OK.
[ 0.101267] SMP alternatives: switching to UP code
[ 0.120007] Freeing SMP alternatives: 16k freed
[ 0.120007] ACPI: Core revision 20080321
[ 0.127770] ACPI: setting ELCR to 0200 (from 0a00)
[ 0.132008] weird, boot CPU (#0) not listedby the BIOS.
[ 0.132008] SMP motherboard not detected.
[ 0.132008] Local APIC not detected. Using dummy APIC emulation.
[ 0.132008] SMP disabled
[ 0.132008] Brought up 1 CPUs
[ 0.132008] Total of 1 processors activated (898.95 BogoMIPS).
[ 0.132008] CPU0 attaching sched-domain:
[ 0.132008] domain 0: span 0
[ 0.132008] groups: 0
[ 0.132008] net_namespace: 660 bytes
[ 0.132008] Booting paravirtualized kernel on bare hardware
[ 0.132343] NET: Registered protocol family 16
[ 0.133851] ACPI: bus type pci registered
[ 0.148378] PCI: PCI BIOS revision 2.10 entry at 0xfd994, last bus=1
[ 0.148393] PCI: Using configuration type 1 for base access
[ 0.148409] Setting up standard PCI resources
[ 0.158303] ACPI: EC: Look up EC in DSDT
[ 0.167111] ACPI: Interpreter enabled
[ 0.167126] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.167208] ACPI: Using PIC for interrupt routing
[ 0.179705] ACPI: Device [ECP] status [00000008]: functional but not present; setting present
[ 0.182491] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.183109] * Found PM-Timer Bug on the chipset. Due to workarounds for a bug,
[ 0.183119] * this clock source is slow. Consider trying other clock sources
[ 0.183196] pci 0000:00:07.3: quirk: region f0c0-f0ff claimed by PIIX4 ACPI
[ 0.183212] pci 0000:00:07.3: quirk: region f0b0-f0bf claimed by PIIX4 SMB
[ 0.183649] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.184308] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.190778] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.191182] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.191587] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.192104] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.192786] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.193019] pnp: PnP ACPI init
[ 0.193057] ACPI: bus type pnp registered
[ 0.202184] pnp: PnP ACPI: found 13 devices
[ 0.202200] ACPI: ACPI bus type pnp unregistered
[ 0.202213] PnPBIOS: Disabled by ACPI PNP
[ 0.204152] PCI: Using ACPI for IRQ routing
[ 0.204868] ACPI: RTC can wake from S4
[ 0.205029] system 00:01: ioport range 0x370-0x371 has been reserved
[ 0.205048] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[ 0.205093] system 00:01: ioport range 0xf0b0-0xf0bf has been reserved
[ 0.205109] system 00:01: ioport range 0xf0c0-0xf0cf has been reserved
[ 0.205124] system 00:01: ioport range 0xf0d0-0xf0ff has been reserved
[ 0.237872] PCI: Bridge: 0000:00:01.0
[ 0.237887] IO window: 4000-4fff
[ 0.237901] MEM window: 0xfd000000-0xfecfffff
[ 0.237915] PREFETCH window: 0x0000000020000000-0x00000000200fffff
[ 0.238044] NET: Registered protocol family 2
[ 0.238542] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.239656] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.240257] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.240807] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.240821] TCP reno registered
[ 0.241228] NET: Registered protocol family 1
[ 0.241757] checking if image is initramfs...<7>Switched to high resolution mode on CPU 0
[ 1.526705] it is
[ 2.989992] Freeing initrd memory: 6067k freed
[ 2.993033] audit: initializing netlink socket (disabled)
[ 2.993090] type=2000 audit(1268673480.992:1): initialized
[ 2.993657] Total HugeTLB memory allocated, 0
[ 2.994031] VFS: Disk quotas dquot_6.5.1
[ 2.994180] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.994368] msgmni has been set to 754
[ 2.994967] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.994986] io scheduler noop registered
[ 2.994997] io scheduler anticipatory registered
[ 2.995007] io scheduler deadline registered
[ 2.995067] io scheduler cfq registered (default)
[ 2.995103] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 2.995169] pci 0000:01:00.0: Boot video device
[ 2.997261] isapnp: Scanning for PnP cards...
[ 3.087774] 01:01: card 'SCM SwapBox Plug and Play'
[ 3.087789] isapnp: 1 Plug & Play card detected total
[ 3.105868] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 3.106270] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.106931] serial8250: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A
[ 3.108967] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.109669] 00:0c: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A
[ 3.119531] brd: module loaded
[ 3.120220] PNP: PS/2 Controller [PNP0303:KEYB,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 3.123614] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.123643] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.124594] mice: PS/2 mouse device common for all mice
[ 3.125371] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 3.125413] rtc0: alarms up to one month
[ 3.125654] cpuidle: using governor ladder
[ 3.125668] cpuidle: using governor menu
[ 3.125692] No iBFT detected.
[ 3.127982] TCP cubic registered
[ 3.127999] NET: Registered protocol family 17
[ 3.128084] Using IPI No-Shortcut mode
[ 3.128897] registered taskstats version 1
[ 3.129333] rtc_cmos 00:03: setting system clock to 2010-03-15 17:18:02 UTC (1268673482)
[ 3.130446] Freeing unused kernel memory: 244k freed
[ 3.151373] input: AT Translated Set 2 keyboard as /class/input/input0
[ 3.631199] ACPI: ACPI0007:00 is registered as cooling_device0
[ 5.427933] No dock devices found.
[ 6.251012] SCSI subsystem initialized
[ 6.591420] ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
[ 6.591510] ne2k-pci 0000:00:0e.0: enabling device (0000 -> 0001)
[ 6.592380] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 6.592396] PCI: setting IRQ 11 as level-triggered
[ 6.592408] ACPI: PCI Interrupt 0000:00:0e.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 6.593691] eth0: RealTek RTL-8029 found at 0x5800, IRQ 11, 00:80:c8:f3:6c:70.
[ 6.676506] usbcore: registered new interface driver usbfs
[ 6.676640] usbcore: registered new interface driver hub
[ 6.676862] usbcore: registered new device driver usb
[ 7.320250] USB Universal Host Controller Interface driver v3.0
[ 7.320404] uhci_hcd 0000:00:07.2: enabling device (0004 -> 0005)
[ 7.321210] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[ 7.321227] PCI: setting IRQ 9 as level-triggered
[ 7.321238] ACPI: PCI Interrupt 0000:00:07.2[D] -> Link [LNKD] -> GSI 9 (level, low) -> IRQ 9
[ 7.321279] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 7.321619] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
[ 7.321678] uhci_hcd 0000:00:07.2: irq 9, io base 0x00007800
[ 7.322106] usb usb1: configuration #1 chosen from 1 choice
[ 7.322262] hub 1-0:1.0: USB hub found
[ 7.322307] hub 1-0:1.0: 2 ports detected
[ 7.334724] libata version 3.00 loaded.
[ 7.357942] Floppy drive(s): fd0 is 1.44M
[ 7.376794] FDC 0 is a post-1991 82077
[ 7.424693] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 7.424713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.424727] usb usb1: Product: UHCI Host Controller
[ 7.424738] usb usb1: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[ 7.424749] usb usb1: SerialNumber: 0000:00:07.2
[ 7.588312] Uniform Multi-Platform E-IDE driver
[ 7.588337] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 7.602000] PIIX4: IDE controller (0x8086:0x7111 rev 0x01) at PCI slot 0000:00:07.1
[ 7.602049] PIIX4: not 100% native mode: will probe irqs later
[ 7.602080] ide0: BM-DMA at 0x7cf0-0x7cf7
[ 7.602108] ide1: BM-DMA at 0x7cf8-0x7cff
[ 7.602125] Probing IDE interface ide0...
[ 7.684137] usb 1-1: new full speed USB device using uhci_hcd and address 2
[ 7.857647] usb 1-1: configuration #1 chosen from 1 choice
[ 7.860923] hub 1-1:1.0: USB hub found
[ 7.862774] hub 1-1:1.0: 4 ports detected
[ 7.888229] hda: MAXTOR 4K040H2, ATA DISK drive
[ 7.972583] usb 1-1: New USB device found, idVendor=058f, idProduct=9254
[ 7.972603] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.972616] usb 1-1: Product: Generic USB Hub
[ 7.972626] usb 1-1: Manufacturer: ALCOR
[ 8.212074] usb 1-2: new full speed USB device using uhci_hcd and address 3
[ 8.356019] usb 1-2: configuration #1 chosen from 1 choice
[ 8.393307] usb 1-2: New USB device found, idVendor=043d, idProduct=0100
[ 8.393326] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.393339] usb 1-2: Product: Lexmark 640 Series
[ 8.393349] usb 1-2: Manufacturer: Lexmark
[ 8.393359] usb 1-2: SerialNumber: 18K640062001260
[ 8.560390] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 8.560682] hda: UDMA/33 mode selected
[ 8.560968] Probing IDE interface ide1...
[ 8.597745] usb 1-1.2: new full speed USB device using uhci_hcd and address 4
[ 8.704022] usb 1-1.2: configuration #1 chosen from 1 choice
[ 8.738129] usb 1-1.2: New USB device found, idVendor=0dda, idProduct=2026
[ 8.738149] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.738163] usb 1-1.2: Product: USB2.0 Card Reader
[ 8.738173] usb 1-1.2: Manufacturer: Generic
[ 8.738183] usb 1-1.2: SerialNumber: 0000001
[ 8.878116] Initializing USB Mass Storage driver...
[ 8.883201] scsi0 : SCSI emulation for USB Mass Storage devices
[ 8.884401] usbcore: registered new interface driver usb-storage
[ 8.884423] USB Mass Storage support registered.
[ 8.894402] usb-storage: device found at 4
[ 8.894418] usb-storage: waiting for device to settle before scanning
[ 8.968206] hdc: Hewlett-Packard CD-Writer Plus 8100, ATAPI CD/DVD-ROM drive
[ 9.752199] hdd: LITE-ON COMBO LTC-48161H, ATAPI CD/DVD-ROM drive
[ 9.808241] hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 9.808799] hdc: MWDMA2 mode selected
[ 9.809381] hdd: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 9.809452] hdd: UDMA/33 mode selected
[ 9.809582] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 9.817077] ide1 at 0x170-0x177,0x376 on irq 15
[ 10.045856] hda: max request size: 128KiB
[ 10.058467] hda: 78198750 sectors (40037 MB) w/2000KiB Cache, CHS=65535/16/63
[ 10.058800] hda: cache flushes supported
[ 10.058959] hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 > hda3
[ 10.157039] hdc: ATAPI 24X CD-ROM CD-R/RW drive, 1024kB Cache
[ 10.157067] Uniform CD-ROM driver Revision: 3.20
[ 10.164593] hdd: ATAPI 48X DVD-ROM CD-R/RW drive, 2048kB Cache
[ 11.098419] PM: Starting manual resume from disk
[ 11.236833] kjournald starting. Commit interval 5 seconds
[ 11.236883] EXT3-fs: mounted filesystem with ordered data mode.
[ 13.893796] usb-storage: device scan complete
[ 13.896769] scsi 0:0:0:0: Direct-Access Generic IC1210 CF 1.9C PQ: 0 ANSI: 0 CCS
[ 13.899729] scsi 0:0:0:1: Direct-Access Generic IC1210 MS 1.9C PQ: 0 ANSI: 0 CCS
[ 14.054540] scsi 0:0:0:2: Direct-Access Generic IC1210 MMC/SD 1.9C PQ: 0 ANSI: 0 CCS
[ 14.059481] scsi 0:0:0:3: Direct-Access Generic IC1210 SM 1.9C PQ: 0 ANSI: 0 CCS
[ 14.320996] udevd version 125 started
[ 15.692352] Driver 'sd' needs updating - please use bus_type methods
[ 15.698626] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 15.703576] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 15.708315] sd 0:0:0:2: [sdc] 3842048 512-byte hardware sectors (1967 MB)
[ 15.711311] sd 0:0:0:2: [sdc] Write Protect is off
[ 15.711329] sd 0:0:0:2: [sdc] Mode Sense: 4b 00 00 08
[ 15.711343] sd 0:0:0:2: [sdc] Assuming drive cache: write through
[ 15.723308] sd 0:0:0:2: [sdc] 3842048 512-byte hardware sectors (1967 MB)
[ 15.726304] sd 0:0:0:2: [sdc] Write Protect is off
[ 15.726324] sd 0:0:0:2: [sdc] Mode Sense: 4b 00 00 08
[ 15.726336] sd 0:0:0:2: [sdc] Assuming drive cache: write through
[ 15.726436] sdc: sdc1
[ 15.733747] sd 0:0:0:2: [sdc] Attached SCSI removable disk
[ 15.738623] sd 0:0:0:3: [sdd] Attached SCSI removable disk
[ 22.102656] Linux agpgart interface v0.103
[ 22.131955] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 22.176356] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 22.355621] agpgart: Detected an Intel 440BX Chipset.
[ 22.362303] agpgart: AGP aperture is 64M @ 0xf8000000
[ 22.916102] piix4_smbus 0000:00:07.3: Found 0000:00:07.3 device
[ 23.171699] input: PC Speaker as /class/input/input1
[ 24.064370] input: ImPS/2 Generic Wheel Mouse as /class/input/input2
[ 24.212727] usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x043D pid 0x0100
[ 24.212810] usbcore: registered new interface driver usblp
[ 25.554759] input: Power Button (FF) as /class/input/input3
[ 25.588221] ACPI: Power Button (FF) [PWRF]
[ 25.588536] input: Power Button (CM) as /class/input/input4
[ 25.615856] ACPI: Power Button (CM) [PWRB]
[ 29.901656] parport_pc 00:09: reported by Plug and Play ACPI
[ 29.901712] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 30.004675] parport_pc 00:0a: activated
[ 30.004698] parport_pc 00:0a: reported by Plug and Play ACPI
[ 30.004750] parport1: PC-style at 0x278, irq 5 [PCSPP,TRISTATE,EPP]
[ 30.096950] parport2: PC-style at 0x3bc [PCSPP]
[ 31.273408] ESS ES1938 (Solo-1) 0000:00:0c.0: enabling device (0004 -> 0005)
[ 31.274212] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 31.274228] PCI: setting IRQ 10 as level-triggered
[ 31.274240] ACPI: PCI Interrupt 0000:00:0c.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 31.293330] gameport: ES1938 is pci0000:00:0c.0/gameport0, io 0x7400, speed 1084kHz
[ 34.708022] Adding 265032k swap on /dev/hda8. Priority:-1 extents:1 across:265032k
[ 35.125518] EXT3 FS on hda9, internal journal
[ 35.719378] loop: module loaded
[ 36.712242] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 36.975459] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 37.033829] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 44.632692] NET: Registered protocol family 10
[ 44.634885] lo: Disabled Privacy Extensions
[ 45.208240] lp0: using parport0 (interrupt-driven).
[ 45.208440] lp1: using parport1 (interrupt-driven).
[ 45.208666] lp2: using parport2 (polling).
[ 45.279972] ppdev: user-space parallel port driver
[ 53.795762] Bluetooth: Core ver 2.11
[ 53.801757] NET: Registered protocol family 31
[ 53.801773] Bluetooth: HCI device and connection manager initialized
[ 53.801789] Bluetooth: HCI socket layer initialized
[ 54.147539] Bluetooth: L2CAP ver 2.9
[ 54.147555] Bluetooth: L2CAP socket layer initialized
[ 54.228975] Bluetooth: RFCOMM socket layer initialized
[ 54.229028] Bluetooth: RFCOMM TTY layer initialized
[ 54.229039] Bluetooth: RFCOMM ver 1.8
[ 100.877794] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Module Size Used by
rfcomm 28272 0
l2cap 17248 5 rfcomm
bluetooth 44996 4 rfcomm,l2cap
ppdev 6468 0
lp 8164 0
ipv6 235396 14
battery 10180 0
cpufreq_conservative 5960 0
cpufreq_stats 3776 0
cpufreq_ondemand 6476 0
cpufreq_userspace 3172 0
freq_table 4224 2 cpufreq_stats,cpufreq_ondemand
cpufreq_powersave 1856 0
nls_utf8 1760 4
nls_cp437 5568 4
vfat 9152 4
fat 40864 1 vfat
nls_base 6820 4 nls_utf8,nls_cp437,vfat,fat
loop 12748 0
snd_es1938 16420 1
parport_pc 22500 3
parport 30988 3 ppdev,lp,parport_pc
gameport 10700 2 snd_es1938
snd_pcm 62660 1 snd_es1938
snd_page_alloc 7816 1 snd_pcm
snd_opl3_lib 9344 1 snd_es1938
snd_hwdep 6212 1 snd_opl3_lib
snd_mpu401_uart 6368 1 snd_es1938
snd_seq_midi 5728 0
snd_seq_midi_event 6432 1 snd_seq_midi
snd_rawmidi 18496 2 snd_mpu401_uart,snd_seq_midi
container 3456 0
snd_seq 41456 2 snd_seq_midi,snd_seq_midi_event
snd_timer 17800 3 snd_pcm,snd_opl3_lib,snd_seq
snd_seq_device 6380 4 snd_opl3_lib,snd_seq_midi,snd_rawmidi,snd_seq
button 6096 0
snd 45636 11 snd_es1938,snd_pcm,snd_opl3_lib,snd_hwdep,snd_mpu401_uart,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
usblp 10592 0
soundcore 6368 1 snd
psmouse 32336 0
pcspkr 2432 0
serio_raw 4740 0
i2c_piix4 7216 0
i2c_core 19828 1 i2c_piix4
intel_agp 22524 1
shpchp 25528 0
pci_hotplug 23460 1 shpchp
agpgart 28808 1 intel_agp
evdev 8000 3
sd_mod 22200 2
ext3 105576 1
jbd 39476 1 ext3
mbcache 7108 1 ext3
ide_cd_mod 27684 0
cdrom 30176 1 ide_cd_mod
ide_disk 10496 6
usb_storage 77120 1
piix 6568 0 [permanent]
ide_pci_generic 3908 0 [permanent]
ide_core 96168 4 ide_cd_mod,ide_disk,piix,ide_pci_generic
ata_generic 4676 0
floppy 47844 0
uhci_hcd 18672 0
libata 140448 1 ata_generic
ne2k_pci 7968 0
8390 8256 1 ne2k_pci
usbcore 118192 4 usblp,usb_storage,uhci_hcd
scsi_mod 129548 3 sd_mod,usb_storage,libata
dock 8304 1 libata
thermal 15228 0
processor 32576 1 thermal
fan 4196 0
thermal_sys 10856 3 thermal,processor,fan
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03)
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:07.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01)
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 02)
00:0c.0 Multimedia audio controller: ESS Technology ES1969 Solo-1 Audiodrive (rev 01)
00:0e.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8029(AS)
00:10.0 Multimedia video controller: Auravision VxP524
01:00.0 VGA compatible controller: ATI Technologies Inc 3D Rage Pro AGP 1X/2X (rev 5c)
