Ostatnio zauważyłem, że mój serwer wyświetla taki błąd na ekranie monitora:
bad: scheduling from the idle thread!Gdzie można szukać rozwiązania?
bad: scheduling from the idle thread!Kod: Zaznacz cały
dmesgKod: Zaznacz cały
Linux version 2.6.30.9-net-system (root@debian) (gcc version 4.3.2 (Debian 4.3.2-1.1) ) #1 Fri Feb 26 13:04:51 CET 2010
KERNEL supported cpus:
Intel GenuineIntel
AMD AuthenticAMD
NSC Geode by NSC
Cyrix CyrixInstead
Centaur CentaurHauls
Transmeta GenuineTMx86
Transmeta TransmetaCPU
UMC UMC UMC UMC
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fe71000 (usable)
BIOS-e820: 000000001fe71000 - 000000001fe73000 (ACPI NVS)
BIOS-e820: 000000001fe73000 - 000000001fe94000 (ACPI data)
BIOS-e820: 000000001fe94000 - 000000001ff00000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
DMI 2.3 present.
last_pfn = 0x1fe71 max_arch_pfn = 0x100000
MTRR default type: uncachable
MTRR fixed ranges enabled:
00000-9FFFF write-back
A0000-BFFFF uncachable
C0000-D7FFF write-protect
D8000-DFFFF uncachable
E0000-E3FFF write-protect
E4000-EFFFF uncachable
F0000-FFFFF write-protect
MTRR variable ranges enabled:
0 base 000000000 mask FE0000000 write-back
1 base 01FF00000 mask FFFF00000 uncachable
2 disabled
3 disabled
4 disabled
5 disabled
6 disabled
7 disabled
init_memory_mapping: 0000000000000000-000000001fe71000
0000000000 - 0000400000 page 4k
0000400000 - 001fc00000 page 2M
001fc00000 - 001fe71000 page 4k
kernel direct mapping tables up to 1fe71000 @ 7000-c000
ACPI: RSDP 000feba0 00014 (v00 DELL )
ACPI: RSDT 000fd4f8 00038 (v01 DELL GX60 00000008 ASL 00000061)
ACPI: FACP 000fd530 00074 (v01 DELL GX60 00000008 ASL 00000061)
ACPI: DSDT fffd7499 02616 (v01 DELL dt_ex 00001000 MSFT 0100000D)
ACPI: FACS 1fe71000 00040
ACPI: SSDT fffd9aaf 000A7 (v01 DELL st_ex 00001000 MSFT 0100000D)
ACPI: APIC 000fd5a4 0006C (v01 DELL GX60 00000008 ASL 00000061)
ACPI: BOOT 000fd610 00028 (v01 DELL GX60 00000008 ASL 00000061)
ACPI: ASF! 000fd638 00067 (v16 DELL GX60 00000008 ASL 00000061)
ACPI: Local APIC address 0xfee00000
0MB HIGHMEM available.
510MB LOWMEM available.
mapped low ram: 0 - 1fe71000
node 0 low ram: 00000000 - 1fe71000
node 0 bootmap 00001000 - 00004fd0
(6 early reservations) ==> bootmem [0000000000 - 001fe71000]
#0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
#1 [0000100000 - 0000831c4c] TEXT DATA BSS ==> [0000100000 - 0000831c4c]
#2 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
#3 [0000832000 - 00008351c0] BRK ==> [0000832000 - 00008351c0]
#4 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
#5 [0000001000 - 0000005000] BOOTMAP ==> [0000001000 - 0000005000]
found SMP MP-table at [c00fe710] fe710
Zone PFN ranges:
DMA 0x00000000 -> 0x00001000
Normal 0x00001000 -> 0x0001fe71
HighMem 0x0001fe71 -> 0x0001fe71
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000000 -> 0x000000a0
0: 0x00000100 -> 0x0001fe71
On node 0 totalpages: 130577
free_area_init_node: node 0, pgdat c075ace0, node_mem_map c1000000
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3968 pages, LIFO batch:0
Normal zone: 989 pages used for memmap
Normal zone: 125588 pages, LIFO batch:31
Using APIC driver default
ACPI: PM-Timer IO Port: 0x808
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
nr_irqs_gsi: 24
Allocating PCI resources starting at 20000000 (gap: 1ff00000:ded00000)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129556
Kernel command line: root=/dev/hda1 ro quiet
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
NR_IRQS:288
PID hash table entries: 2048 (order: 11, 8192 bytes)
Fast TSC calibration using PIT
Detected 2391.559 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Initializing HighMem for node 0 (00000000:00000000)
Memory: 510232k/522692k available (4841k kernel code, 11960k reserved, 1705k data, 376k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfffaa000 - 0xfffff000 ( 340 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xe0671000 - 0xff7fe000 ( 497 MB)
lowmem : 0xc0000000 - 0xdfe71000 ( 510 MB)
.init : 0xc0768000 - 0xc07c6000 ( 376 kB)
.data : 0xc05ba575 - 0xc0764aa8 (1705 kB)
.text : 0xc0100000 - 0xc05ba575 (4841 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop (skipped), value calculated using timer frequency.. 4783.11 BogoMIPS (lpj=2391559)
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 128K
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU: Intel(R) Celeron(R) CPU 2.40GHz stepping 09
Checking 'hlt' instruction... OK.
ACPI: Core revision 20090320
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
net_namespace: 976 bytes
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfbdd9, last bus=1
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: No dock devices found.
ACPI: PCI Root Bridge [PCI0] (0000:00)
pci 0000:00:00.0: reg 10 32bit mmio: [0xf8000000-0xfbffffff]
pci 0000:00:02.0: reg 10 32bit mmio: [0xf0000000-0xf7ffffff]
pci 0000:00:02.0: reg 14 32bit mmio: [0xff680000-0xff6fffff]
pci 0000:00:1d.0: reg 20 io port: [0xff80-0xff9f]
pci 0000:00:1d.1: reg 20 io port: [0xff60-0xff7f]
pci 0000:00:1d.2: reg 20 io port: [0xff40-0xff5f]
pci 0000:00:1d.7: reg 10 32bit mmio: [0xffa00800-0xffa00bff]
pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
pci 0000:00:1d.7: PME# disabled
* The chipset may have PM-Timer Bug. Due to workarounds for a bug,
* this clock source is slow. If you are sure your timer does not have
* this bug, please use "acpi_pm_good" to disable the workaround
pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
pci 0000:00:1f.0: quirk: region 0880-08bf claimed by ICH4 GPIO
pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
pci 0000:00:1f.1: reg 20 io port: [0xffa0-0xffaf]
pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
pci 0000:00:1f.3: reg 20 io port: [0xdc80-0xdc9f]
pci 0000:00:1f.5: reg 10 io port: [0xd800-0xd8ff]
pci 0000:00:1f.5: reg 14 io port: [0xdc40-0xdc7f]
pci 0000:00:1f.5: reg 18 32bit mmio: [0xffa00400-0xffa005ff]
pci 0000:00:1f.5: reg 1c 32bit mmio: [0xffa00000-0xffa000ff]
pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
pci 0000:00:1f.5: PME# disabled
pci 0000:01:08.0: reg 10 io port: [0xec80-0xecff]
pci 0000:01:08.0: reg 14 32bit mmio: [0xff8ffc00-0xff8ffc7f]
pci 0000:01:08.0: reg 30 32bit mmio: [0xff900000-0xff90ffff]
pci 0000:01:0c.0: reg 10 32bit mmio: [0xff8fe000-0xff8fefff]
pci 0000:01:0c.0: reg 14 io port: [0xec40-0xec7f]
pci 0000:01:0c.0: reg 18 32bit mmio: [0xff8c0000-0xff8dffff]
pci 0000:01:0c.0: supports D1 D2
pci 0000:01:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:01:0c.0: PME# disabled
pci 0000:00:1e.0: transparent bridge
pci 0000:00:1e.0: bridge io port: [0xe000-0xefff]
pci 0000:00:1e.0: bridge 32bit mmio: [0xff800000-0xff9fffff]
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 12 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 12 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 9 10 11 12 15)
SCSI subsystem initialized
libata version 3.00 loaded.
PCI: Using ACPI for IRQ routing
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:0b: io resource (0x800-0x85f) overlaps 0000:00:1f.0 BAR 7 (0x800-0x87f), disabling
pnp 00:0b: io resource (0x860-0x8ff) overlaps 0000:00:1f.0 BAR 7 (0x800-0x87f), disabling
pnp: PnP ACPI: found 12 devices
ACPI: ACPI bus type pnp unregistered
system 00:00: iomem range 0x0-0x9ffff could not be reserved
system 00:00: iomem range 0x100000-0xffffff could not be reserved
system 00:00: iomem range 0x1000000-0x1fe70fff could not be reserved
system 00:00: iomem range 0xc0000-0xfffff could not be reserved
system 00:00: iomem range 0xfec00000-0xfec0ffff could not be reserved
system 00:00: iomem range 0xfee00000-0xfee0ffff has been reserved
system 00:00: iomem range 0xffb00000-0xffbfffff has been reserved
system 00:00: iomem range 0xffc00000-0xffffffff has been reserved
system 00:0b: ioport range 0xc00-0xc7f has been reserved
pci 0000:00:1e.0: PCI bridge, secondary bus 0000:01
pci 0000:00:1e.0: IO window: 0xe000-0xefff
pci 0000:00:1e.0: MEM window: 0xff800000-0xff9fffff
pci 0000:00:1e.0: PREFETCH window: 0x00000020000000-0x000000200fffff
pci 0000:00:1e.0: setting latency timer to 64
pci_bus 0000:00: resource 0 io: [0x00-0xffff]
pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
pci_bus 0000:01: resource 0 io: [0xe000-0xefff]
pci_bus 0000:01: resource 1 mem: [0xff800000-0xff9fffff]
pci_bus 0000:01: resource 2 pref mem [0x20000000-0x200fffff]
pci_bus 0000:01: resource 3 io: [0x00-0xffff]
pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffff]
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
Simple Boot Flag value 0x87 read from CMOS RAM was invalid
Simple Boot Flag at 0x7a set to 0x1
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 996
alg: No test for cipher_null (cipher_null-generic)
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
alg: No test for fcrypt (fcrypt-generic)
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pci 0000:00:02.0: Boot video device
pci 0000:01:0c.0: Firmware left e100 interrupts enabled; disabling
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
FDC 0 is a post-1991 82077
brd: module loaded
loop: module loaded
Compaq SMART2 Driver (v 2.6.0)
HP CISS Driver (v 3.6.20)
Uniform Multi-Platform E-IDE driver
piix 0000:00:1f.1: IDE controller (0x8086:0x24cb rev 0x01)
pci 0000:00:1f.1: enabling device (0005 -> 0007)
pci 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
piix 0000:00:1f.1: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7
ide1: BM-DMA at 0xffa8-0xffaf
Probing IDE interface ide0...
hda: QUANTUM FIREBALLlct20 20, ATA DISK drive
hdb: WDC WD800BB-22JHC0, ATA DISK drive
hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hda: UDMA/100 mode selected
hdb: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hdb: host side 80-wire cable detection failed, limiting max speed to UDMA33
hdb: UDMA/33 mode selected
Probing IDE interface ide1...
hdc: Lite-On LTN486S 48x Max, ATAPI CD/DVD-ROM drive
hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hdc: UDMA/33 mode selected
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
ide-gd driver 1.18
hda: max request size: 128KiB
hda: 39876480 sectors (20416 MB) w/418KiB Cache, CHS=39560/16/63
hda: cache flushes not supported
hda: hda1 hda2 < hda5 >
hdb: max request size: 128KiB
hdb: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=65535/16/63
hdb: cache flushes supported
hdb: hdb1 hdb2 hdb3
ide-cd driver 5.00
ide-cd: hdc: ATAPI 48X CD-ROM drive, 120kB Cache
Uniform CD-ROM driver Revision: 3.20
Loading iSCSI transport class v2.0-870.
rdac: device handler registered
hp_sw: device handler registered
emc: device handler registered
alua: device handler registered
Adaptec aacraid driver 1.1-5[2461]-ms
scsi: <fdomain> Detection failed (no card)
sym53c416.c: Version 1.0.0-ac
qlogicfas: no cards were found, please specify I/O address and IRQ using iobase= and irq= options<6>QLogic Fibre Channel HBA Driver: 8.03.01-k1
iscsi: registered transport (qla4xxx)
QLogic iSCSI HBA Driver
Emulex LightPulse Fibre Channel SCSI driver 8.3.1
Copyright(c) 2004-2009 Emulex. All rights reserved.
Failed initialization of WD-7000 SCSI card!
DC390: clustering now enabled by default. If you get problems load
with "disable_clustering=1" and report to maintainers
megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
megasas: 00.00.04.01 Thu July 24 11:41:51 PST 2008
GDT-HA: Storage RAID Controller Driver. Version: 3.05
3ware Storage Controller device driver for Linux v1.26.02.002.
3ware 9000 Storage Controller device driver for Linux v2.26.02.012.
nsp32: loading...
ipr: IBM Power RAID SCSI Device Driver version: 2.4.2 (January 21, 2009)
RocketRAID 3xxx/4xxx Controller driver v1.3 (071203)
stex: Promise SuperTrak EX Driver version: 4.6.0000.3
st: Version 20081215, fixed bufsize 32768, s/g segs 256
Driver 'st' needs updating - please use bus_type methods
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
PPP generic driver version 2.4.2
MPPE/MPPC encryption/compression module registered
IMQ driver loaded successfully.
Hooking IMQ after NAT on PREROUTING.
Hooking IMQ before NAT on POSTROUTING.
Fusion MPT base driver 3.04.07
Copyright (c) 1999-2008 LSI Corporation
Fusion MPT SPI Host driver 3.04.07
Fusion MPT FC Host driver 3.04.07
Fusion MPT SAS Host driver 3.04.07
PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
cpuidle: using governor ladder
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Using IPI Shortcut mode
input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: hda1: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 432489
ext3_orphan_cleanup: deleting unreferenced inode 432488
ext3_orphan_cleanup: deleting unreferenced inode 432487
ext3_orphan_cleanup: deleting unreferenced inode 432486
ext3_orphan_cleanup: deleting unreferenced inode 432485
EXT3-fs: hda1: 5 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with writeback data mode.
VFS: Mounted root (ext3 filesystem) readonly on device 3:1.
Freeing unused kernel memory: 376k freed
rtc_cmos 00:05: RTC can wake from S4
rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one day, 242 bytes nvram
Linux agpgart interface v0.103
agpgart-intel 0000:00:00.0: Intel 830M Chipset
agpgart-intel 0000:00:00.0: detected 892K stolen memory
agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xf0000000
intel_rng: FWH not detected
via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
via-rhine 0000:01:08.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
eth0: VIA Rhine at 0xff8ffc00, 00:50:ba:c2:07:95, IRQ 17.
eth0: MII PHY found at address 8, status 0x782d advertising 05e1 Link 41e1.
e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
e100: Copyright(c) 1999-2006 Intel Corporation
e100 0000:01:0c.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
e100 0000:01:0c.0: PME# disabled
e100: eth1: e100_probe: addr 0xff8fe000, irq 18, MAC addr 00:0d:56:91:16:02
udev: renamed network interface eth1 to eth0
udev: renamed network interface eth0_rename to eth1
Adding 875500k swap on /dev/hda5. Priority:-1 extents:1 across:875500k
EXT3 FS on hda1, internal journal
REISERFS (device hdb1): found reiserfs format "3.6" with standard journal
REISERFS (device hdb1): using ordered data mode
REISERFS (device hdb1): journal params: device hdb1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
REISERFS (device hdb1): checking transaction log (hdb1)
REISERFS (device hdb1): replayed 525 transactions in 7 seconds
REISERFS (device hdb1): Using r5 hash to sort names
REISERFS (device hdb2): found reiserfs format "3.6" with standard journal
REISERFS (device hdb2): using ordered data mode
REISERFS (device hdb2): journal params: device hdb2, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
REISERFS (device hdb2): checking transaction log (hdb2)
REISERFS (device hdb2): replayed 510 transactions in 9 seconds
REISERFS (device hdb2): Using r5 hash to sort names
EXT3 FS on hdb3, internal journal
ext3_orphan_cleanup: deleting unreferenced inode 2490402
EXT3-fs: hdb3: 1 orphan inode deleted
e100 0000:01:0c.0: firmware: requesting e100/d102e_ucode.bin
eth1: link up, 100Mbps, full-duplex, lpa 0x41E1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth0: link is not ready
e100: eth0 NIC Link is Up 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth1: no IPv6 routers present
ip_tables: (C) 2000-2006 Netfilter Core Team
nf_conntrack version 0.5.0 (8167 buckets, 32668 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel paramater, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
eth0: no IPv6 routers present
u32 classifier
Actions configured
warning: `proftpd' uses 32-bit capabilities (legacy support in use)
UDP: bad checksum. From 85.48.134.20:6881 to 83.15.24.203:45114 ulen 285
UDP: bad checksum. From 85.48.134.20:6881 to 83.15.24.203:1025 ulen 285
UDP: bad checksum. From 82.53.111.19:32780 to 83.15.24.203:45114 ulen 285
UDP: bad checksum. From 96.55.143.231:57014 to 83.15.24.203:45114 ulen 111
UDP: bad checksum. From 201.151.41.42:62676 to 83.15.24.203:45114 ulen 111
UDP: bad checksum. From 84.224.93.220:25906 to 83.15.24.203:1040 ulen 285
UDP: bad checksum. From 213.106.102.179:51789 to 83.15.24.203:1040 ulen 285
------------[ cut here ]------------
WARNING: at net/sched/sch_generic.c:226 dev_watchdog+0x1d2/0x1e0()
Hardware name: OptiPlex GX60
NETDEV WATCHDOG: eth1 (via-rhine): transmit timed out
Modules linked in: xt_condition xt_limit xt_ipp2p xt_connlimit xt_MARK cls_fw cls_u32 sch_esfq sch_hfsc xt_dscp xt_IMQ ipt_MASQUERADE xt_mac xt_recent ipt_REDIRECT xt_iprange xt_TCPMSS ipt_REJECT xt_state xt_multiport xt_tcpudp iptable_mangle iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack nf_defrag_ipv4 iptable_filter ip_tables x_tables ipv6 e100 via_rhine mii intel_agp agpgart rtc_cmos rtc_core rtc_lib
Pid: 0, comm: swapper Not tainted 2.6.30.9-net-system #1
Call Trace:
[<c0538202>] ? dev_watchdog+0x1d2/0x1e0
[<c01223b6>] ? warn_slowpath_common+0x76/0xd0
[<c012245b>] ? warn_slowpath_fmt+0x2b/0x30
[<c05296fb>] ? dev_hard_start_xmit+0x18b/0x300
[<c0538030>] ? dev_watchdog+0x0/0x1e0
[<c012a98b>] ? run_timer_softirq+0xdb/0x180
[<c012688a>] ? __do_softirq+0x8a/0x150
[<c012697d>] ? do_softirq+0x2d/0x40
[<c0111604>] ? smp_apic_timer_interrupt+0x44/0x80
[<c010338a>] ? apic_timer_interrupt+0x2a/0x30
[<c05b007b>] ? twa_probe+0x52b/0x7c0
[<c0108a85>] ? default_idle+0x55/0xe0
[<c0101e49>] ? cpu_idle+0x29/0x50
[<c07689c5>] ? start_kernel+0x289/0x2ec
[<c0768513>] ? unknown_bootoption+0x0/0x1db
---[ end trace 7ba2c7d503f3b837 ]---
eth1: Transmit timed out, status 0000, PHY status 782d, resetting...
